Anyone bought an MGW Shifter? - Mustang Evolution
Old 02-27-2012, 11:09 PM   #1
SkoSter06's Avatar
I am about to buy a shifter and it looks like the best one out on the market is the MGW. Has anyone got it yet and could give me some feedback before I yank out this flimsy stock shifter? Thanks guys!
SkoSter06 is offline   Reply With Quote
Old 02-28-2012, 02:45 AM   #2
DaBluedude's Avatar
The mgw is the shirtest throw and has the greatest range.of adjustibility and different sized handles. That all said it can be a bit of a workout at times. The steeda tri ax is comprable and I find it a little more precise. Its my choice.
---------- Post added at 02:45 AM ---------- Previous post was at 02:44 AM ----------
Sorry. I thought this was under a different set of years. I'm speaking from sn95 cars. Gl.
2003 Mach 1
Old 02-28-2012, 04:45 AM   #3
Have heard all good about the mgw and the Barton. Can't go wrong with either.
Old 02-28-2012, 06:22 AM   #4
avengnd's Avatar
Re: Anyone bought an MGW Shifter?
I have the MGW and it will be installed this weekend. I'll give feedback next week.
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 02-28-2012, 09:56 AM   #5
mgw is great in my 03 cobra vs the steeda i used to have and b&m before it
Old 02-28-2012, 12:17 PM   #6
back n a stang's Avatar
All indications are....the MGW is the best one out there for 11+ period! It will be no doubt the one I buy.
Old 02-28-2012, 01:13 PM   #7
CZYFAST's Avatar
I just bought mine last night no joke, I am getting rid of my steeda tri ax and I can't wait!!!
IN SALEEN WE TRUST!!!
CZYFAST is offline   Reply With Quote
Old 02-28-2012, 01:16 PM   #8
SkoSter06's Avatar
Cool thanks! Yeah I've looked at every shifter and wanted something that came with the entire assembly. I don't see the point of replacing half a shifter. I hit gears hard and need something precise that will hold up!
Old 02-28-2012, 01:26 PM   #9
CZYFAST's Avatar
Yeah I know what you mean I hit them hard too and when I first got my tri ax it was the best and then about 4 months its not as precise as it was so I'm getting the quality of the MGW!!!!
Old 02-28-2012, 05:14 PM   #10
2012Coyote's Avatar
I have the Barton short throw with the bracket. I'm happy with it and it also has a 40% reduction over the others 27%.
If I wasn't so impatient and could have waited I would probably have went with the MGW. With Either one I believe you will be happy, With the MGW you get the whole assembly but does cost just a little more.
2012Coyote is offline   Reply With Quote
Old 03-01-2012, 02:08 PM   #11
I just drove over to MGW and bought me a shifter...I will do the install Sat...and will post up about what I think about it..
2012 6 speed GT with a 8psi Hellion Single Turbo Kit tuned by BBR, GFB Geforce II controller, ID1000 injectors, BAP, GT500 Mufflers no cats, MGW shifter, Dual Aeroforce Interceptor gauges and AMR Wheels. BMR upper control arm and bracket, Whiteline panhard brace, BBR LCA's and Panhard Bar. 552/597 at 7.8 psi
6SpeedFreak is offline   Reply With Quote
Old 03-01-2012, 02:28 PM   #12
^ do a how to with tons of pics
Old 03-01-2012, 08:21 PM   #13
Just received mine yesterday and it looks likes a masterpiece.
Kona Blue 2012 GT Premium, Brembo, 3.73, Accessory pkg 5, GT500 Axelbacks, Boss Pod w/ Prosport Gauges, Boss/CS F&R facsia'a, Boss Brake cooling ducts, Boss splitter, Roush side splitters, Saleen Grill & Roush CAI(non tune). More to come
Devildog1679 is offline   Reply With Quote
Old 03-01-2012, 08:51 PM   #14
CZYFAST's Avatar
I should get mine on March 6th, I can't wait to get it!!!!!
Old 03-01-2012, 09:51 PM   #15
GrayGhost's Avatar
I have the MGW... Unfortunately for me, I have yet to install it on my ride! Looks like a very well thought out piece, though.
2011 Mustang GT Premium 401A Spec- Sterling Gray, aka "Graycie", 6-Speed MT, 3.73, Brembo Brake Package, Current Mods: FRPP-Brakelines/Brake Ducts/Alternator/Radiator/Oil Pan/Oil Cooler/Trans.Scoop/Alum.Axle Cover, Steeda-Sport Springs/3rd Link/Adj.UCA/Alum.LCA/Rel.Brackets/Adj.PHB & Brace/Adj.F&R Swaybars/Adj.Front Endlinks/HD Strut Mounts/X11 Ball Joint/Bumpsteer/CAI, Koni Sport Shocks, ATI Damper, MGW Shifter, Kooks Catback, Wavetrac Diff, Michelin Pilot Super Sport... 93 Octane Performance Tune by VMP
GrayGhost is offline   Reply With Quote
Old 03-02-2012, 07:39 AM   #16
2012Coyote's Avatar
There is already an install video.
Old 03-02-2012, 05:33 PM   #17
Well finished the install..took about 2 hrs and that was with me stopping to answer the phone several times...As for how to...it is super easy...between the paper instructions and the videos online it is a cake walk...This shifter fixes the missing third issue I was having with the stock one too...Will drive it over the weekend and see what I think..
Old 03-04-2012, 08:32 AM   #18
dailey's Avatar
I bought a after market shift knob from grabber pony ...if i by the MGW shifter, will my new shift knob work on it? Is the pattern for it to screw on still the same?
dailey is offline   Reply With Quote
Old 03-04-2012, 10:50 AM   #19
you have two optiions with the mgw...they have a shaft for the stock shift knob and one for a aftermarker one...so you just pick the one you want....and the shifter is great...and my nvh isn't much more but I got the heat shield too....Although the most notiable difference is when I start the car..the starter is much louder but that is the only thing I really notice...but it is a great shifter for driving.
Old 03-04-2012, 01:27 PM   #20
dailey's Avatar
so stock shaft is what i would want...i definitely want to keep my shift knob...since it fits the factory one.
Old 03-04-2012, 03:46 PM   #21
yeah I am still using the stock shift knob with mine...I have no regrets on the shifter..It is a great piece.
Old 03-07-2012, 10:47 AM   #22
CZYFAST's Avatar
Just got my shifter in yesterday and gonna put it in this weekend, I can't wait until Saturday!!!
Old 03-07-2012, 06:21 PM   #23
dailey's Avatar
i ordered mine today
Old 03-07-2012, 07:37 PM   #24
CZYFAST's Avatar
I have the steeda tri ax in right now but it just doesn't seem to hold up to my type of driving. I will be able to compare them after I install it but I'm not going to say anything until the MGW shifter has been in for awhile because the tri ax was great for about 4 months and then just feels sloppy so I'm hoping it doesn't happen with this shifter.
Old 03-08-2012, 08:20 PM   #25
Nichg's Avatar
Just ordered my shifter today. from all my research I think this is the best shifter on the market. What do you guys think? Will it do what it says it will?
Nichg is offline   Reply With Quote
Old 03-08-2012, 08:58 PM   #26
CZYFAST's Avatar
I hope so I put mine in Saturday over the steeda tri ax shifter so I hope it is better then the steeda! I have been looking into it and I am confident that the MGW shifter is the best so I hope I'm not wrong LOL
Old 03-10-2012, 03:36 PM   #27
CZYFAST's Avatar
I got my shifter installed and I love it, wish I knew about MGW before I bought my steeda one, but the install was pretty easy took about 2 hours and that includes answering phone and text messages. I am very impressed, just hope it doesnt crap out like the steeda one did after 4 months!!!
Old 03-11-2012, 09:12 AM   #28
tc x 4's Avatar
I was gonna go with mgw. I caught the pro 50 on clearance at lms ,now I know why. It sux, really hard to hit 5 an rev. Other than that It's great. Don't settle for less than the best. Mgw's are pricey for a reason. Now I can add $240 to the price ( money I waisted ) of a mgw.
Old 03-11-2012, 10:01 AM   #29
CZYFAST's Avatar
Yea I think most parts do the same thing, but when it comes to a shifter everyone has a personal preference and my tri ax was awesome at first then it got sloppy, I know why because when I removed it the blue seal was ripped and all the grease came out which is what happened the first time. I think the MGW will be better but only time will tell. I have been driving with it and it feels better but I might adjust the throw but it feels really smooth and crisp through the gears, so I would say happy customer for now unless something happens with it
Old 03-11-2012, 10:32 AM   #30
It will definately do what it says it will....This is a great shifter!
Old 03-11-2012, 05:13 PM   #31
Nichg's Avatar
Have to wait three weeks before my shifter ships, can't wait till I can install it and run through the gears. Does anyone know how long the breakin period is?
Old 03-11-2012, 06:33 PM   #32
CZYFAST's Avatar
I didn't know their was a break in period for the shifter, I haven't really hammered it hard though, but you will be happy with it, I just drove my car today and I couldn't be happier with how well it shifts into the gears!
anyone have nitrous? frank07stanggt 2005-2010 Mustang GT 7 03-02-2012 01:21 PM
hurst shifter bigsmitty24 2011-2014 Mustang GT 9 02-26-2012 01:03 AM
351w in an 85 mustang with a carb and fuel regulator five_0_85stang 1979-1995 Mustang GT 7 02-24-2012 08:32 AM
Barton Industries shifter Bracket FXDWG11bm 2011-2014 Mustang GT 12 02-24-2012 05:28 AM
11:20 AM
