Emergency funnel for capless gas tank - Mustang Evolution
Old 03-03-2012, 10:55 AM   #1
The other day I was going to put Seafoam in my tank and went to look for the special funnel that is used in emergency situations and couldn't find it. Is it provided by Ford or do I have to buy one? I looked all around the trunk and no luck. Also, has anyone Seafoamed their Coyote? There appears to be no vacuum tube available without taking of engine cover. Doing it to clean throttle body because of members mentioning them being dirty due to oil consumption.
mongo1970 is offline   Reply With Quote
Old 03-03-2012, 11:10 AM   #2
gtstyles2's Avatar
It should be attached to the lug wrench
Old 03-03-2012, 11:27 AM   #3
11stangGT's Avatar
Region: Arkansas
Mine was where the spare tire would be.. But I have brembo pkg..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 03-03-2012, 12:34 PM   #4
Re: Emergency funnel for capless gas tank
How do you anticipate adding seafoam to the tank will clean your throttle body since the only way into the engine would be via the injectors, downstream of the TB? Even the vac tube method wouldn't help you since there's pressure upstream of the TB and vacuum only after it.
Clean the TB, if you insist, with some good old-fashioned carb clean sprayed into it. Even if the car consumed some oil, the TB would have to be coated in 1/4" of residue before you'd see performance impacted much.
Old 03-03-2012, 01:07 PM   #5
I anticipated on doing the vacuum line method but didn't want to take engine cover off. That's when I decided to put it in my tank. I know it won't clean tb when ran through the tank. That is why I asked question on the emergency funnel. Because of container they put seafoam in its impossible to hold trap door open with screwdriver and pour the seafoam in tank. It will run out the bottom of trap door isn't open. I've used carb cleaner before with a bad experience. It cleaned tb but the crap that came off fouled something in lower intake resulting in a trip to Toyota dealer.
Old 03-03-2012, 02:16 PM   #6
You are right on the fact that Seafoam won't clean a tb since the tb is the first part of the intake. My bad.
Old 03-03-2012, 04:23 PM   #7
it appears you're just remembering a valuable lesson. Cleaning TBs isn't necessary unless their so occluded they are preventing full closure of the throttle plate. look elsewhere for something to do. And don't pour Seafoam in the crankcase if you arrive at that idea.
If you insist, you can have the TB off in about 15 minutes. removing the engine cover is even easier; just tug it off.
I have a small funnel with a long spout I use for motorcycle oil changes. I got it at a local auto shop eons ago but, that suggests they are still out there.
I need MAF conversion for dummies 87blackonblack 1979-1995 Mustang GT 82 04-16-2012 09:40 PM
Faux gas cap idea on 65 Dmay65 Classic Mustangs 21 03-12-2012 12:05 PM
Traded in for 12 GT phobik 2011-2014 Mustang GT 24 03-04-2012 02:27 AM
Looking for suggestions 12" Kicker L7 89GT Stangit50 Mustang Audio & Video 0 03-03-2012 05:56 AM
Putting in wiring for amp 2003SonicBlue Mustang Audio & Video 5 03-02-2012 09:30 PM
09:07 PM
