4.10 gears from a 2001 mustang to a 2011 gt? - Mustang Evolution
Old 03-10-2012, 09:29 PM   #1
Yellow50's Avatar
Hi my friend has a set of 4.10 gears from a 2001 gt. question will it fit my 2011 gt? I want to switch to 4.10s regardless i currently have 3.73's and want quicker acceleration and this seems like the ticket + drag radials to help put it down to the floor
Yellow50 is offline   Reply With Quote
Old 03-10-2012, 09:49 PM   #2
Rapinator126's Avatar
Yes they will fit.
Old 03-10-2012, 10:10 PM   #3
Question I take this is for the track? If so what size DR's? Reason is 4.10s will cause you to go into 5th right before traps. 3.90s will keep you in 4th. It all can change it all...lol
Old 03-11-2012, 06:53 AM   #4
Yellow50's Avatar
Yes and no its a dd but ill go to the track once in a while i want to squeeze 285's on the brembo package lol.
Old 03-11-2012, 10:19 AM   #5
Tires will fit depending on brand.
Far as gears it really up to you. I had 4.10s in my 2011 manual. With way tranny is geared 1st gear is basically useless.
Old 03-11-2012, 02:41 PM   #6
Yellow50's Avatar
So would 4.10s improve 0-60 times?
Old 03-11-2012, 03:32 PM   #7
Yes they would
---------- Post added at 03:32 PM ---------- Previous post was at 03:32 PM ----------
If u can get the tires to hook
Old 03-11-2012, 04:38 PM   #8
Yellow50's Avatar
Ok guess im doing it then
Old 03-11-2012, 04:44 PM   #9
You will love it man trust me
Old 03-11-2012, 04:45 PM   #10
11stangGT's Avatar
Region: Arkansas
I wouldn't.. 1st gear is short enough w 3.73s.. And shifting into 5th will kill ya in the 1320!
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 03-11-2012, 04:51 PM   #11
I have 410s with a supercharger and a 5speed and its far from stock 427r. All i have to say is if u know how to drive and can hook up you will tear alot of people a new *** whole lol. So go for it
Old 03-11-2012, 05:15 PM   #12
11stangGT's Avatar
Region: Arkansas
You've also only got 5 gears.. Transmission is geared differently allowing you to actually use 1st.. And if you plan on going w a sc then don't go any lower than 3.73s.. If I had a 5spd then I would prolly also do 4.10s... and would also suggest them to the OP if he had a 5spd...
Old 03-11-2012, 05:19 PM   #13
Do as u wish i have friends with the new 5.0 and they need the lower gear in my opinion
Old 03-11-2012, 05:21 PM   #14
11stangGT's Avatar
Region: Arkansas
What gears do they have? They come w anything from a 3.15 to a 3.73 factory
Old 03-11-2012, 05:21 PM   #15
Re: 4.10 gears from a 2001 mustang to a 2011 gt?
+1111111111111111111111111111111111111
WHy do people try to comment when they have a totally different car? WHy comment if you have no idea what it is like with the 2011+?
A blower on a 2010 prior is what some of us made with bolt ons in 5.0's.
4.10's in the 5.0's is liek having 4.30's in teh 2010 prior basically. I had 4.10's in my manual. And as said it make 1st kinda useless. Even on DR's. DD I would just start off in 2nd gear all the time. At the track you will be shifting to 2nd before you even finish the 60ft basically. Keep the 3.73's or go to a 3.90. If want quicker start then get more power.
If plan on a SC later you will really not want 4.10's. Heck I know guys with 2010 prior that don't want 4.10's cause its a waste. They all run 3.55's or even 3.31's. With mine I will be going to 3.55's.
Old 03-11-2012, 05:24 PM   #16
The reason all you 5.0 guys make the power u do is bc of your high compression. Thats it hands down look at the new 5.0 motor built for boost on the new 5.0 with lower compression 18 lbs + around 650 plus at tires. Same as u will get out of a 4.6 with same boost friendly compression
Old 03-11-2012, 05:29 PM   #17
11stangGT's Avatar
Region: Arkansas
Ur nuts.. I can throw a blower on my car and make 600+whp running minimal boost with only a tune and a couple bolt ons. That's not even goin w diff pulleys..
Old 03-11-2012, 05:31 PM   #18
Yes i know this bc of the high compression thats why take your compression down to a boost friendly 9.1 and you will need 16lbs + to get the same power.
Old 03-11-2012, 05:39 PM   #19
11stangGT's Avatar
Region: Arkansas
So your jealous that you don't have 11:1 compression?? Why have more boost if you don't need it? Lol.. There's a whole lot more diff between our motors other than compression that gives us more power.. 3v vs. 4v... Dohc vs single.. Etc. etc...
Old 03-11-2012, 05:44 PM   #20
Jealos if u say so man. I could get a new 5.0 if i want one trust me thats besides the point im just explaing why the new motor makes the power it does with a blower.
---------- Post added at 05:44 PM ---------- Previous post was at 05:41 PM ----------
For instance my old 03 cobra 4v dual overhead cam at 18lbs made 505 at the tire. Now my 3v making 7lbs is 488 at the tire so that explains a little there.
Old 03-11-2012, 05:44 PM   #21
guzie's Avatar
Sounds like someone has a case of denial. The new 5.0 is much more than upping compression. Do that on yours and you still can't touch the new 5.0. The motor is a whole new beast. The variable cam timing is another real difference.
guzie is offline   Reply With Quote
Old 03-11-2012, 05:48 PM   #22
Then why is the new gt500 650 at the crank with 15lbs out of a 5.8. Which probally is around 580+ at the tires. Now yes you can make that with the new 5.0 at 7lbs probally with the right blower. But all i was trying to do is explain the compression is a big factor on why the 5.0 makes the power it does
Old 03-11-2012, 06:00 PM   #23
11stangGT's Avatar
Region: Arkansas
That's kinda common sense that the compression helps.. Along w the dohc, variable cam timing, more displacement(than your 4.6), and many other things.. It's as big of a factor as all the other things mentioned.. I'd rather be running 7psi @11:1 than 18 psi or whatever you had said @9:1... But really it's 6 of one, half dozen of the other..
Old 03-11-2012, 06:08 PM   #24
Trust me i had no attentions to sound like a *** i was just trying to explain a lil something. I love the new 5.0s and thought about getting one just decided to go with my roush after i sold my cobra to my uncle.
Old 03-11-2012, 06:23 PM   #25
Are you serious? They are dropping the compression so they don't blow the engine. Even at a 9.5:1 compression a nd 16-18lbs of boost these cars are making over 700whp. Look at several cars that run that much boost. Hell mopst them are making closer to 800whp. Its not the compression. Its the bigger engine, better flowing heads, VVT. Not the compression. WHy it helps once they drop it its all in teh bigger/better engine.
Old 03-11-2012, 06:27 PM   #26
You can also make 700 on a 3v with 18lbs my friend. With the right blower
Old 03-11-2012, 06:31 PM   #27
It is a 5.8L with a PD new blower. Froged internals set to handle a lot of boost. Set with a very safe tune. Watch what happens when people get them and do nothing but a tune to them. You will see the new GT500 make 620-630whp with nothing but a tune. As compression plays a role it is a lot more then that.
As far as the 4.6 its limits are aroudn 450whp with a blower on stock internals. While the 5.0 is around 630-650whp. That is a huge difference. And you will not make 580whp with 7lbs on a stock 5.0 with out be on the limits of an unsafe tune.
---------- Post added at 07:31 PM ---------- Previous post was at 07:28 PM ----------
Yep with a turbo. and forged internals and stroking the block. If it was that easy to do with a 4.6 why are that many people not doing it with liitle effort as you make believe? Cause it isn't that simple. Look at JPC/Beefcake/Sean Kelley all make 900whp-100whp on 18lbs-20lbs of boost on a new 5.0. Hell guys are making 650 on 10lbs of boost on stock engines. Let me see you do that with a stock 4.6..Not going to happen at all.
Old 03-11-2012, 06:33 PM   #28
I was just stating what they are power wise with same compression boost friendly they are pretty close. Mine is at 488 with only 7lbs from a little blower. Once my shortblock goes in and the whipple i will up it to 18 with methanol just how my cobra was.
Old 03-11-2012, 06:39 PM   #29
Want 800whp in a 4.6 this is what some of the guys builds looks like. A lot harder then a 5.0.
ENGINE
05 up Ford alum. 4.6 block
Manley 18cc Dish pistons 9.0/1 .30 with ceramic coated tops and dry film coated skirts
Manley billet pro series rods coated with Poyldyn PD14
Kellogg stroker crank coated with Polydyn PD14
Federal/Mogul Race series bearings Dry film coated
ARP main studs
Livernois VCT lockouts
Comp custom grind cams Lift-490 in. 475 ex.. Dur. 222 in. 231 ex. @.50 with 114 LSA
Comp Beehive springs moly coated with titanium retainers
Ported heads with 35mm in and 38.5mm ex . ss valves with all ports, valves, and combustion chanbers ceramic coated
ARP 3v head studs
Steeda CMDP deletes
MMR Billet crank gear
MMR Billet rear main support
MMR windage tray
Ford oil pump
Ford head gaskets
New Ford timing chain, guides and, tentioners
Moroso 7qt. oil pan coated with Polydyn PD14 inside
Miziere elec. Water pump
Autolight HT0 plugs
MSD cops
Inovators West Balancer with custom Procharger crank pulley
Intake plentum, valve covers, and timing cover all coated with Polydyn matalic silver urathane coating
POWER ADDER
Procharger F1-A with 8 rib 3.9 Richard pulley. Blower inlet and all piping ceramic coated outside and PD 14 coated inside with Procharger pro surge valve and 4” intercooler
EXHAUST
Hooker ceramic coated long tubes
Ceramic coated O/R X pipe
Flowmaster Axle back
FUEL SYSTEM
Duel Ford GT with duel -6 to -8 fuel line to Areomotive fuel rails with 83lb Simon Delph injectors
Diablo Mafia
MSD BAP
GT 500/ V-10 TB
---------- Post added at 07:39 PM ---------- Previous post was at 07:36 PM ----------
I am taking you have full exhaust?
I made 620whp with a 10lbs boost and completely stock exhaust. Add off road x pipe and hit 643whp. Still with only 10lbs boost on 93. I will be adding E85 soon and go to 15lbs of boost. From what we figured and others made I will make close to 750whp. Never going to happen on a stock 4.6. And I will not use Methanol. Don't want to be like the nitrous guys and be like oh my bottle(tank) is not filled you have t o wait till i get it filled to race and I am at full tilt.
Old 03-11-2012, 06:40 PM   #30
Blackcat's Avatar
I have a 2010 and it took my mechanic alot of work to get my car to get to 600 rwhp it can do alot more but I have it for a dd so yes it's alot easier for a 5.0 to make more power hands down my next car will be a 5.0 or a Shelby cause its easier to make alot more power
Blackcat is offline   Reply With Quote
Old 03-11-2012, 06:41 PM   #31
My buddy laid down 543 with 5.6lb on his new 5.0 cause of a BOV being jacked up. That isn't close. Even with lower compression it will be a good difference just because of the bigger engine, better heads. Not to mention if we add exhuast and stuff into it.
Old 03-11-2012, 06:41 PM   #32
ENGINE
ARP main studs
ARP 3v head studs
Steeda CMDP deletes
MMR windage tray
Ford oil pump
Ford head gaskets
Autolight HT0 plugs
MSD cops
POWER ADDER
EXHAUST
FUEL SYSTEM
Diablo Mafia
MSD BAP
GT 500/ V-10 TB
Im not going for 800 im only going for 650 at the tires on my 4.6. And i know what the prochargers can do that is what is on our fox its a f1r making 30lbs and is 1200 at the tires. The pics of it are on my profile as well as my old cobra. New bypass valve was just installed on the f1r to safely have the 30psi. It is also a chevy motor
Old 03-11-2012, 06:45 PM   #33
Shelby!
My next car will be a Vette or GTR(maybe a used 2013/2014 GT500). I will keep the 5.0 for track duty though. By that time I will have no issue putting a cage in it and what not.
---------- Post added at 07:44 PM ---------- Previous post was at 07:42 PM ----------
Biggest thing. lots of CU IN. LOL
At track here guy had a LS1 stroker Turbo set up in his fox. Drove it to track ran a bunch of 9.1-9.3@150+ and then drove home
Also y ou said you was at 488 now with a blower. I made 464whp with bolt ons on my manual 5.0 and ran lower 11's. Hadn't even broke engine open yet.
ANYWAY! BAck on topic.
GEARS!
Old 03-11-2012, 06:46 PM   #34
The fox is also a street car has made 1 pass down the track and cant make another due to regulations needs a cage. Has stock interior
Old 03-11-2012, 06:50 PM   #35
Blackcat's Avatar
Yea my car now will be my sons when he gets older I've put alot of money in the engine and suspension drivetrain everything mechanical and if i put the same amount of money in a 5.0 I would have at least 8 to 1000 hp cause of the motor the 5.0 will handle more with less boost
2001 mustang, 2011 gt
4.10 gear trouble 99redgt 1996-2004 Mustang GT 5 03-28-2012 03:08 PM
New from Kansas Mezmer New Member Introductions & Greetings 9 03-19-2012 09:08 PM
Change oem GT Brembo Calipers to red? M3hunter 2011-2014 Mustang GT 4 03-13-2012 04:17 AM
New Mustang 06REDF1RE 1996-2004 Mustang GT 14 03-11-2012 11:30 AM
Best investment to insure a longer life Blackedout Pre-2005 V6 Mustang 8 03-10-2012 03:39 PM
01:03 PM
