2010 GT Rear view mirror camera - Mustang Evolution
Old 03-14-2012, 05:28 PM   #1
jrny99's Avatar
has anyone installed a switch to operate the camera manually ? if so, how did you go about it.
jrny99 is offline   Reply With Quote
Old 03-14-2012, 10:34 PM   #2
Gibby's Avatar
I think the camera is operated by a ground when you go into reverse... That being said, you would have to find that wire and put a switch in (to manually ground it to make the camera come on)
Gibby is offline   Reply With Quote
Old 03-15-2012, 12:24 AM   #3
11stangGT's Avatar
Region: Arkansas
On all the ones I've done the camera turns on through a positive trigger from your reverse wire.. Only way to do it would be to get a multi-meter( I don't recommend test lights) and go through and test every wire on the back of the radio to see which one switches to 12v when you put the car in reverse.. Then as said cut your wire and add in a switch to cut/give power to your cam...
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Rear speakers arnt working Dylanbest Mustang Audio & Video 3 01-17-2014 01:48 PM
Wheels/Tires Possibly for sale and GT OEM Strut Tower avengnd Mustang Parts for Sale and Wanted 7 03-28-2012 08:07 AM
New noise from the rear 2002VertGT 1996-2004 Mustang GT 7 03-16-2012 08:17 PM
2010 4.0 max speed? Grabber Blue 2011-2014 V6 Mustang 5 03-16-2012 11:32 AM
Gt-v6 exhaust Surffer227 Pre-2005 V6 Mustang 15 03-14-2012 06:10 PM
04:53 AM
