faux gas cap removal - Mustang Evolution
Old 03-18-2012, 07:10 AM   #1
gtstyles2's Avatar
What's the safest way of getting this off w/o scratching? I'm gonna get vinyl done on the trunk.
Old 03-18-2012, 08:56 AM   #2
Delta vt's Avatar
1)fishing line first to get outside ring of double sided tape. 2) some sort of pry bar(some people use putty knifes, I used a hand towel and a long screwdriver) 3) once you can get your fingers behind it just pull as hard as you can and it with pop off. It's got two plastic mounts in the center and more double sided tape. Just keep pulling and the mounts will either break or let loose.
Delta vt is offline   Reply With Quote
Old 03-18-2012, 09:01 AM   #3
gtstyles2's Avatar
Fishing line is a nice idea thanks... I guess a heat gun works to loosen that double sided tape right? Those plastic mounts, can they be undone? Or I just pull the whole cap off?
Old 03-18-2012, 09:06 AM   #4
Delta vt's Avatar
If the mounts can be undone I have no clue how. I am an engineer and couldn't figure out how so I doubt they can be undone. From what I see it was not designed to be taken off. I've heard goods about a heat gun I just don't have one so I didn't need to use it. But like I said once you can get your fingers behind it just pull like hell and it will give way
Old 03-18-2012, 09:17 AM   #5
gtstyles2's Avatar
OK, once they come off do they go back in easily? Or they just break off? Plus once installing again I'm sure u gotta scrape off All the tape and redo right? I guess u can get a body shop to retape?
Old 03-18-2012, 09:21 AM   #6
Delta vt's Avatar
My mounts didn't break. They just sit in two holes in the trunk and I assume you can just put it back. I didn't put my badge back on but I would just use double sided tape you can buy just about anywhere. But you definitely want to get all the old tape off.
Gas prices D: zeltik The Bar 134 04-28-2012 05:34 AM
89 & 93 Gas BlackHorse1911 2011-2014 V6 Mustang 11 03-21-2012 06:28 PM
What are we going to do when gas gets to $20.00 a gallon 1995boss The Bar 12 03-16-2012 04:41 PM
Boosting gas mileage Mustang 4pt0 AmericanMuscle 10 03-13-2012 03:10 PM
Faux gas cap idea on 65 Dmay65 Classic Mustangs 21 03-12-2012 12:05 PM
04:33 AM
