Tips/advice for O/R X-Pipe install - Mustang Evolution
Old 03-19-2012, 12:42 PM   #1
OrganDonor's Avatar
Well my Lethal Performance X-Pipe just showed up, i will be installing tonight or tomorrow morning. Anyone that has installed an aftermarket mid pipe have any advice or tips, i would really appreciate it. I have a jack and 4 stands so my fat *** can get under there safely, will i need a torque wrench or any special tools? I haven't been under the car yet, so not sure what all will be involved in taking stock pipe off and adding this one. Thanks in advance for the tips.
2014 Shelby GT500...
OrganDonor is offline   Reply With Quote
Old 03-19-2012, 01:38 PM   #2
tc x 4's Avatar
it's the 1 on a scale of 1 to 10 I think you need a 15 millimeter socket and ratchet maybe a hammer it could be a 13 millimeter socket not sure
Old 03-19-2012, 01:47 PM   #3
OrganDonor's Avatar
Re: Tips/advice for O/R X-Pipe install
Perfect.. Those are the kind of projects i can handle.. Think ill put it on tonight so i can crank it up nice n late, while the wife is sleeping.. I love waking her up..
Old 03-19-2012, 03:55 PM   #4
Napoleon85's Avatar
I posted a write up on this a while ago, you should be able to find it if you search for something along the lines of x pipe install notes.
Old 03-19-2012, 04:41 PM   #5
Your going to need a really long extension or a couple 10" put together for the passenger side bolt closest to fender on cats.
Old 03-19-2012, 04:51 PM   #6
tc x 4's Avatar
Your rite, I spaced that part.
Old 03-19-2012, 07:58 PM   #7
When put O2 sensors back in twist them so when go to put in they untwisted.
Also no torque wrench needed. Good and tight works fine.
I also see they changed their design.
Old 03-20-2012, 09:34 PM   #8
OrganDonor's Avatar
Holy F_c_Tits... I am so glad my little 2 1/2 ton jack couldn't get car high enough for my fat_ss to work under there. Instead of going out and getting a bigger jack, i borrowed one from a bud, and he insisted on helping me. I am so glad he did.
Napoleon, thanks for the write up you did, sure did come in handy..
I did go out and buy a 20 inch extension before starting. defiantly needed for the one on the passenger side that you have to get to from engine compartment. .
as for braking the nuts loose, 1st we tried without the penetrating oil, but like everyone said, it is needed. we used Kano Kroil, i truly believe it is the best in the world. Spray a little of that on, waited about 2 minutes and the nuts broke loose. no problems.
From start to finish, took 2 1/2 hours but that included a 30 minute dinner break, When the wife cooks, everyone must stop what they are doing and eat.
Everyone has told me it would be crazy loud with Roush AB's and O/R X-Pipe..
On the cold start it is.. it is real loud until it warms up a bit and idles down, Then it's not much louder than before. Leisurely driving down the road isn't too loud, not much louder than before. But when i jump on it, Holy Sh_t snacks... it sounds so Bad_ss..
All of my neighbors are old.. hope they took their hearing aid out before they went to bed cause i leave for work at 0430..
Old 03-21-2012, 12:07 AM   #9
tc x 4's Avatar
Kano kroil is by far the best. Works when a torch an cherry red doesn't .
Old 03-21-2012, 12:32 AM   #10
Mich mustang's Avatar
Probably a dumb question.... Why do you need the rear sensors if running a tune. The tune turns off rear sensors no? Confused. And eager to lose cats!!
Mich mustang is offline   Reply With Quote
Old 03-21-2012, 06:47 AM   #11
Napoleon85's Avatar
Glad the write-up helped. Those bolts are total PITA to break loose. We used ZEP penetrating lubricant and it's the best stuff I've ever used but I might have to check out this Kain Kroil stuff.
I think the loudness is just about right. It's not ridiculous with the exception of a cold start (which tends to put the fear of God into people) and when you get heavy on the throttle. Just cruising around town (2500RPM or less) I doubt many people would think it's any kind of crazy exhaust setup.
For lack of a better answer, I'm going to go with "because you don't want to have holes in your exhaust, and you may need them some day and dont want them to get damaged by dangling off the car."
Vote For Most Riced Out Mustang meano1 General Car Discussion 64 04-15-2012 12:51 PM
Anybody a little Hungry for Ricers!!?? SwatKatz901 General Car Discussion 22 04-09-2012 05:34 AM
Need advice urgent! Mustana Classic Mustangs 13 03-25-2012 09:02 PM
Best 18" wheels for a white 2005 Mustang GT?? Texas nightmare Mustang Wheels & Tires 10 03-25-2012 08:54 PM
05:32 AM
