AM window tint -- did i just ruin it?? - Mustang Evolution
Old 03-20-2012, 06:56 PM   #1
Long story short I was tinting the fogs and turned them on to see better. I was working out the water on one and glanced over at the other to see a bubbly mess. I turned them off ASAP and sprayed it down with water. I smoothed out at much as I could but there are still a lot of tiny bubbles. Will these go away in a couple days or am I screwed and getting ready to rip these off and try again? Ugh.
FWIW I tinted all the lights without issue. I was running out of light with the fogs and made a stupid mistake.
RickPollock is offline   Reply With Quote
Old 03-20-2012, 07:25 PM   #2
Benzo's Avatar
The only way to find out is to peel it back very gently. If the adhesive is still sticky retry and work the bubbles out if it not sticky your screwed! I didn't use the soapy water just cleaned the lights and applied tint.
Benzo is offline   Reply With Quote
Old 03-20-2012, 07:29 PM   #3
I think I pretty much hosed them but it's supposed to be sunny the next few days. I'll let it bake outside and keep my fingers crossed. I don't have high hopes so my next question will be...what's the best way to remove the tint? Haha just get some tint removal solution?
Old 03-20-2012, 07:37 PM   #4
GE3G's Avatar
You might be lucky cause when i tinted my windows there were a few bubbles and the guy told me dont roll the windows for a couple of days they will vanish on there own and they did =D
GE3G is offline   Reply With Quote
Old 03-20-2012, 08:48 PM   #5
11stangGT's Avatar
Region: Arkansas
That's the advantage of using water.. As long as it hasn't dried out you can peel off and respray w water and try again
---------- Post added at 08:48 PM ---------- Previous post was at 08:45 PM ----------
Those were just water pockets an actual air bible won't come out.. Might get smaller.. But usually you can look right in the middle of the bubble and see a tiny piece of dirt which causes the tint to not stick around it..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 03-20-2012, 09:30 PM   #6
NuckChorris's Avatar
Try using a heat gun.
NuckChorris is offline   Reply With Quote
Old 03-21-2012, 06:41 PM   #7
Well it doesn't look too bad after sitting out in the sun all day. You really can notice anything unless you kneel down and look at it..I could defiantly do better a second time. Everything else looks great!
What did you do today? Qwik Four Six The Bar 20466 01-14-2017 03:24 PM
Just rubbed her down with wax!! Benzo 2011-2014 Mustang GT 87 06-10-2012 10:58 AM
Window Redman4034 2005-2010 Mustang GT 7 03-21-2012 05:38 PM
Anyobe order the steeda spacer and not receive gaskets wit it? Watchawow07SGT 2005-2010 Mustang GT 13 03-21-2012 08:14 AM
Just Ordered a 2013 Convertible! akmiller 2011-2014 Mustang GT 14 03-20-2012 10:04 PM
12:17 AM
