Lowering the rear end - Mustang Evolution
Old 03-21-2012, 11:06 PM   #1
Have a 2010 V6.... would like to drop it about an inch.... do I need new springs or can a coil be cut?
konabluev6 is offline   Reply With Quote
Old 03-21-2012, 11:24 PM   #2
11stangGT's Avatar
Region: Arkansas
Do not cut springs...
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 03-22-2012, 10:11 AM   #3
Cutting a coil could be done. But it will ride like complete ****. Invest the couple hundred and buy lowering springs.
Old 03-22-2012, 11:15 AM   #4
Re: Lowering the rear end
on a linear spring cutting it a bit wont alter the rate that much, cutting it a bunch will. You have to cut it with a cut off wheel though. As said buy progressive rate springs for all 4 corners and be done with it (install is very easy and get camber bolts as well to get alignment fixed).
As far as panhard bar research and see how low you can go without needing one
Thinking about retiring the roush Rapinator126 Roush Mustang 14 05-26-2014 07:07 AM
Let's play guess what's in the box.. 5pointOh 2011-2014 Mustang GT 21 03-23-2012 07:31 PM
06 gt. The ecm has detected pressure in the EVAP system Silver GT 2005-2010 Mustang GT 3 03-23-2012 09:25 AM
Anyone use the dash inlay kit from yearone? 1995boss 1979-1995 Mustang GT 2 03-21-2012 09:43 PM
Lower end kits? SwatKatz901 1996-2004 Mustang GT 10 03-21-2012 08:28 PM
06:12 PM
