leak - Mustang Evolution
Old 03-29-2012, 10:50 AM   #1
Supertzi's Avatar
leak
I noticed that my rear end is leaking. Has any one heard of this happening before or know why it could be leaking.
Supertzi is offline   Reply With Quote
Old 03-29-2012, 03:16 PM   #2
Rmag's Avatar
Actually mine is leaking too. I am gonna check it out. Let me know if you find out the problem.
Rmag is offline   Reply With Quote
Old 03-29-2012, 06:22 PM   #3
Supertzi's Avatar
Will do
Old 03-29-2012, 06:30 PM   #4
Rmag's Avatar
I believe it's the differential on mine
Old 03-29-2012, 06:45 PM   #5
FXDWG11bm's Avatar
"spirited" driving pushes out vent..... Yes I have it to.... I hear a different vent will stop it, from gt500 or aftermarket. Dealer had seen it many times, checked level, hadn't pushed much out
FXDWG11bm is offline   Reply With Quote
Old 03-29-2012, 08:47 PM   #6
My leak was not the vent...it was the pinion seal...this is a fairly common leak and is covered under warranty. Cash price to fix is approx $100. Hope this helps!
2011 mustang gt is offline   Reply With Quote
Old 03-30-2012, 07:28 AM   #7
Supertzi's Avatar
How fast should it be fixed to avoid damage?
Old 03-30-2012, 08:22 AM   #8
You don't want all of the fluid to run out, so either keep opening the filler plug and keep checking to make sure you have fluid or bring her in and get it taken care of...if it is the pinion seal. An easy way to tell is to let is sit overnight and then crawl under and carefully look to see if the fluid is dripping down from the top of the pumpkin where the vent is or if it is mainly wet in front where the driveshaft bolts up to the pinion flange area...should be very obvious...you have any pics?
Old 03-30-2012, 09:36 AM   #9
Napoleon85's Avatar
Re: leak
If your diff is leaking it should be covered under warranty and fixed immediately ... this is not "common" or "normal," however, leaking from the vent is both.
Old 03-30-2012, 09:49 AM   #10
Rmag's Avatar
Okay thanks I am bringing it in tomorrow
Fuel leak Quball19 1979-1995 Mustang GT 47 03-22-2012 05:44 PM
Coolant leak Matt5.0 1979-1995 Mustang GT 2 03-04-2012 02:44 PM
Leak Enderthreesix 1996-2004 Mustang GT 4 02-29-2012 03:56 PM
upr x pipe leak 04GTRed_Plague 1996-2004 Mustang GT 23 02-20-2012 12:01 AM
2012 V6 Auto Tranny Leak at 4,900 miles brian123 2011-2014 V6 Mustang 10 02-15-2012 09:35 AM
06:21 PM
