need help with fluid decision - Mustang Evolution
Old 04-01-2012, 10:28 PM   #1
Hey guys, so i know this is a topic everyone already discussed, but i am
changing my transmission fluid this week and I am deciding between the redline or the amsoil...any preference on which is better to go with or are they both pretty much the same thing, is there anything better ?
Thanks
5.ohhhhh is offline   Reply With Quote
Old 04-02-2012, 04:55 AM   #2
Napoleon85's Avatar
Both are quality oils. I run amsoil mtg in my mt82 and it helped a lot. Both will still be a bit rough in the cold though.
Old 04-02-2012, 07:55 AM   #3
M3to5.0's Avatar
Re: need help with fluid decision
Going with Royal Purple......... since the other 2 are not available at my location...lol
"Got to kill.... Captain Stupid"
M3to5.0 is offline   Reply With Quote
Old 04-02-2012, 07:56 AM   #4
Napoleon85's Avatar
I ordered AMSOIL online direct from them, I'd be surprised if they don't ship to you.
Old 04-02-2012, 08:02 AM   #5
M3to5.0's Avatar
It is the whole thing about shipping petrol products through the APO to Germany...... not allowed
Old 04-02-2012, 08:08 AM   #6
Napoleon85's Avatar
Ahh, that sucks! I didn't know you couldn't ship that kind of stuff through an APO.
Old 04-02-2012, 08:44 AM   #7
drivinglesson's Avatar
For me, I went with Royal Purple due to availability, and have no complaints. The research I did showed Amsoil to be the best.
2016 Mustang GT
drivinglesson is offline   Reply With Quote
Old 04-02-2012, 09:23 AM   #8
being a new car I think amsoil has a better product engine oil wise but no idea on trans. With the trans you have and the issues it has had with fluid... not sure if the issues they had were the wrong weight or the make up (find that out) and if that checks out either will do you good.
Old 04-02-2012, 10:07 AM   #9
I just changed engine oil. Used amsoil in it. My tranny is different then manuals though.
Old 04-02-2012, 10:45 AM   #10
Napoleon85's Avatar
You mean, it shifts properly even when it's cold outside?
Old 04-02-2012, 10:46 AM   #11
Actually yes.. LOL.
Can always trade for an auto...
Old 04-02-2012, 10:47 AM   #12
Napoleon85's Avatar
Actually yes.. LOL.
LOL, I could, but I like driving a manual too much. The AMSOIL has helped, everything is (relatively) smooth other than the first couple shifts on a cold morning.
Old 04-02-2012, 10:57 AM   #13
akmiller's Avatar
Does changing the fluid void the warranty?
akmiller is offline   Reply With Quote
Old 04-02-2012, 11:06 AM   #14
No long as you use a fluid that meets or exceeded original fluid.
Old 04-02-2012, 04:59 PM   #15
gtstyles2's Avatar
I haven't come around to changing my fluid yet... I have 5500 mi how is the access for the fill plug on the manual??
Old 04-02-2012, 08:44 PM   #16
white2011gt's Avatar
The drain plug is sweet, passenger side rear of trans. The fill plug is right above it, but is very tight. Close to the tunnel. ....and right above that is the skip-shift solinoid connector that you should disconnect while you are there....highly recommended!!
white2011gt is offline   Reply With Quote
Old 04-02-2012, 09:03 PM   #17
gtstyles2's Avatar
Yea thank God the tune took care of the skip shift but just wondering what's an easy way to fill the trans when its drained
Old 04-02-2012, 09:39 PM   #18
Napoleon85's Avatar
I pulled the center console off and used tubing/a funnel.
Old 04-02-2012, 11:10 PM   #19
I mean its just my 2nd gear that shifts ruff and sometimes going into 3rd from 2nd...i think im just going to go with the amsoil for now and later do the barton short throw shifter and bracket...thanks guys for all the input
Old 04-03-2012, 08:16 PM   #20
For me, the fluid did smooth shifting out a bit, but I still experience the roughness shifting into second and third. Ford's been using this transmission for a while, so I don't feel it is the problem. Instead, I think the real issue is the clutch. That's what I am going to change next.
2016 Mustang GT
Old 04-04-2012, 08:34 AM   #21
Napoleon85's Avatar
What Ford cars had the Getrag MT82 before the 2011 Mustang?
Old 04-04-2012, 01:16 PM   #22
I will have to read the article again, but I believe it was the Range Rover.
---------- Post added at 07:16 PM ---------- Previous post was at 07:05 PM ----------
http://www.expeditionlandrover.info/gearboxes.htm
May be wrong here, I overlooked that the MT 82 was manufactured by GFT; not sure if they are different than Gettag. If it is the same transmission, it was introduced into the Range Rover vehicles in 2007.
2016 Mustang GT
Old 04-04-2012, 01:43 PM   #23
Not sure on Ford but Mercedes BMW, Porsche and others use/used it.
Old 04-04-2012, 09:00 PM   #24
Napoleon85's Avatar
Land Rover gearbox history
Right ... so:
It is important to note that the current generation Mustang utilizes the MT82 transmission, which is made by Getrag in China. Besides seeing duty in the Ford Mustang, the MT82 is also used in the Land Rover Defender with owners of those vehicle reporting similar problems. To date, no injuries or accidents have been reported to the NHTSA, but a few close calls have occured due to the problem.
NHTSA Opens Investigation Into Ford Mustang Transmission Issues | Autosavant
and...
The MT82 transmission in question is built by Ford and supplier Getrag at a joint venture in Nanchang, China — a point that has only added to the ire of some customers. And it's not the first time owners of that transmission have reported trouble shifting; the same problems were reported by owners of Land Rover Defenders.
Mt82 News, Videos, Reviews and Gossip - Jalopnik
---------- Post added at 10:55 PM ---------- Previous post was at 10:53 PM ----------
So my point is two-fold.
1. The MT82 is not perfect and has had issues outside of the Mustang.
2. Ford does not have prior experience with this trans, this is different than other manufacturers using it, regardless of it's track record.
---------- Post added at 11:00 PM ---------- Previous post was at 10:55 PM ----------
So I have to correct myself slightly, Ford does have prior experience with the MT82 ... in the Transit Van.
Ford Transit Forum • View topic - MT - 82 six speed gearbox
Big Dramas with Mustang MT82 Manual Gearboxes from China
Mid-pipe/catalytic converter/emissions help NeedSomeMods 1979-1995 Mustang GT 18 04-03-2012 01:33 PM
Lost tune cd help ! Noerrors8 2005-2010 Mustang GT 14 04-02-2012 11:48 AM
I need some help dhktactical Pre-2005 V6 Mustang 6 04-02-2012 08:10 AM
help with SCT tuner imhooked 1996-2004 Mustang GT 0 04-01-2012 03:21 PM
69 302 with .519/.523 with GT40p heads five_0_85stang 1979-1995 Mustang GT 2 04-01-2012 02:01 PM
06:38 AM
