Boss Intake or Fuel Problem? - Mustang Evolution
Old 04-03-2012, 10:27 AM   #1
SilverBullet12's Avatar
Alright so Im sure your sick of seeing threads from me by now but Im just trying to figure this out through process of elimination.
At first I thought it was the MAF sensor.....
Then I thought it was the Tune......
Then I thought it was the CAI........
Well its not any of those things.....
could it be it was this big black plastic thing on top of my motor that says Boss?!?
I know people are 50/50 on here about the Boss Intake. Could this be the problem causing my car to "fall flat on its face" on the launch? Yes I launch my car high enough at 6000rpm, but could it be that loss of torque causing the car to bog with only 3.73's.
Or
Is is the fuel sloushing back in the tank. I have run with a half tank of fuel so Im not to sure that is the problem.
My BEST 1/4 ET with the car is 12.6 with DR's, Boss Intake, Tune, and JLT CAI. The car is 6MT, which im sure a lot of you know haha. Then I see guys doing 12.3's without the boss.....
Below is a link to a youtube video of me doing a burnout and then launching which you can hear it falling flat on his face....
SilverBullet12 is offline   Reply With Quote
Old 04-03-2012, 11:12 AM   #2
michael81's Avatar
Re: Boss Intake or Fuel Problem?
Looks like a Traction Control issue to me.
michael81 is offline   Reply With Quote
Old 04-03-2012, 11:27 AM   #3
traction control button held for 5 seconds turned off for every run.
Old 04-03-2012, 11:32 AM   #4
11stangGT's Avatar
Region: Arkansas
What Rpms are you takin it to? Needs to be at least 7500
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 04-03-2012, 11:37 AM   #5
Launching at 6k and shifting at 7400-7500 which isnt a problem.
Old 04-03-2012, 03:31 PM   #6
Notorious_rob's Avatar
R u using ur traction control during launch? If so turn it off...
Notorious_rob is offline   Reply With Quote
Old 04-03-2012, 03:40 PM   #7
nope, turned off 100%
Old 04-03-2012, 04:29 PM   #8
May sound stupid but you are not lifting on gas are you. I had this issue. The launch caused me to pull up on gas. I moved my seat a little closer then normal.
Next have you checked for air leaks? Or data logged to make sure tune is perfect?
Old 04-03-2012, 04:31 PM   #9
Loc: Austin,TX
Skip shift?
Old 04-03-2012, 04:39 PM   #10
Originally Posted by DDTCM
Skip shift?
Not launching at 6000rpm's.
Old 04-04-2012, 09:02 AM   #11
haha doesnt sound stupid, your the 5th person to ask me that haha. Put it this way if the airbag went off id be in a world of hurt haha. I got a new tune in today from Mike at Bama and talked to him on the phone so were on the road to gettin it squared away.
Old 04-05-2012, 12:34 AM   #12
erillerstang's Avatar
Region: New Mexico
I have the boss intake also. I bought and installed last summer when it first came out. There is no clear place for the purge valve and I thought it didn't need it. So I didn't put in back on. After about a month of going back and fourth with American muscle with the CIA, the tune, finally took it to someone that had enough since to call American muscle and found out they did not foldout with a mount for the valve connection for the boss. They have one now it about 200$$ waist of $$ cause I mounted it to the block. The instructions for the boss...well there was none. So because there was no place for the valve I thought it didn't use it. I was wrong. But that's why I don't work on cars for a living. Anyways does you car have trouble starting after you get gas? If so that's your problem. Now that I got everything going right I pull low 12s in the 1/4 . The boss does it business in the 4-7500 Range. Happy driving!!!
erillerstang is offline   Reply With Quote
Old 04-05-2012, 12:37 AM   #13
Put stock intake back on. Adjust tune for it and see if still have issue.
Old 04-05-2012, 06:01 AM   #14
Napoleon85's Avatar
When you loaded your tune, did you take the car through the idle/fuel trim relearn process? Not doing this can cause the car to run like crap and idle poorly. It's in the owners manual somewhere between page 283 and 288 depending on the revision. I'd post it but I'm using my phone to post this.
Old 04-05-2012, 11:15 AM   #15
Take the jlt off. As you seen Jay is in denial. Funny he brought up Lund. Kdanner and Lund are really good friends.
Show me your boss Mord Fustang Boss Mustang 340 05-27-2016 12:54 PM
2012 or 2013 Mord Fustang Boss Mustang 6 04-13-2012 09:16 AM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
2013 boss bigsmitty24 2011-2014 Mustang GT 5 04-03-2012 04:31 PM
slp problem br10301 1996-2004 Mustang GT 4 04-02-2012 10:45 PM
10:03 AM
