Lca's - Mustang Evolution
Old 04-07-2012, 09:48 PM   #1
Lca's
Have j and m lca's and I keep having one of the bushings come apart. I'm going to call American muscle on Monday cuz thats who I got them from. If I have to end up getting new ones and I get adjustAble ones will I still need relocation brackets or should I just get regular ones and the brackets?
Big Johnson is offline   Reply With Quote
Old 04-08-2012, 09:59 AM   #2
back n a stang's Avatar
Re: Lca's
Thats a problem with all poly......best to go with BMR solid ends teflon,but you give up the comfort smooth quietness some.Cost you about 260.00 and adjustable.They use them on there track car.I have them and still have not put them on yet.Just to many projects and not enough time.
Old 04-08-2012, 10:48 AM   #3
You will not need the relocation kit if get adjustable ones. Solids are better for a manual car cause of the drive train shock on launch. But it does generate more road noise. Also going with bmr ones with bushings will be better then current ones. Not all are created equal. There is a reason some are way cheaper.
Old 04-08-2012, 10:51 AM   #4
bigsmitty24's Avatar
Ok. So I'm lookin to get a set. Wheel hop is a pain in the @$$. I have a manual. Road noise doesn't bother me that much. Which ones should I buy? Car is used more for FR and occasional drag strippin.
bigsmitty24 is offline   Reply With Quote
Old 04-08-2012, 10:54 AM   #5
Redstang1's Avatar
Well I bought the 100 dollar ones off AM and they solved the wheel hop problem 100% they may be cheaper and not adjustable but they do solve the problem
Redstang1 is offline   Reply With Quote
Old 04-08-2012, 11:22 AM   #6
Re: Lca's
Im mostly just driving it up and down the road not going to the track too much but I will some. so will I probably be better off with the adjustables so I dont have to get the relocation brackets
Old 04-08-2012, 12:45 PM   #7
Buy a solid set.that's adjustable. Bmr/upr..
Old 04-08-2012, 05:06 PM   #8
Re: Lca's
what exactly do you mean by solid set thats adjustable?
Old 04-08-2012, 05:57 PM   #9
Re: Lca's
A good example.....google BMR susp. and look up TCA-020 and thats the ones I bought and used on there track car.Nothing to worry about splitting and quality
Old 04-08-2012, 06:36 PM   #12
Re: Lca's
and I would not need relocation brackets with those correct?
Old 04-08-2012, 08:02 PM   #13
Nope
Old 04-08-2012, 08:05 PM   #14
Re: Lca's
cool. are they a pain to get adjusted?
Old 04-08-2012, 09:24 PM   #15
Nope pull stock one off line them up to same. Put it on.
Old 04-08-2012, 09:25 PM   #16
Re: Lca's
oh I just need them to be the same length as stock?
Old 04-08-2012, 09:51 PM   #17
Yes..until you lower car(big drops) and some other suspension stuff your lca's will not be off
Old 04-09-2012, 04:25 AM   #18
I'm on k springs
Old 04-09-2012, 07:14 AM   #19
M3to5.0's Avatar
Re: Lca's
If you lower the car or already lowered you will need the relocation brackets........... keep that in mind. I have the Eibach adjustables and they are good quality and sturdy... recommend and the relocation brackets I picked up from UMI.
"Got to kill.... Captain Stupid"
M3to5.0 is offline   Reply With Quote
Old 04-09-2012, 07:44 AM   #20
Mweigt07's Avatar
Region: North Dakota
Are the UMI products good? I have been researching and they have a solid on one end and poly on the other. Is that the best choice to go with?
Mweigt07 is offline   Reply With Quote
Old 04-09-2012, 08:02 AM   #21
M3to5.0's Avatar
Re: Lca's
On LCA's I cannot comment as I have Eibach LCA's. The relo brackets are good quality and a perfect fit.
Old 04-09-2012, 11:09 AM   #22
Re: Lca's
If you plan to launch hard you will split the poly types
Old 04-09-2012, 12:11 PM   #23
Agree..ask me how I know.
Old 04-09-2012, 12:32 PM   #24
Mweigt07's Avatar
Anyone know if the ones from UMI split( the ones with one solid and the other one poly)? Does both ends split?
Old 04-09-2012, 01:38 PM   #25
Re: Lca's
The ride is a bit better as for noise transfer,but if you are serious go with solid on both ends.Spherical ends are better than poly but not as good as the good type solid ends....BMR,UPR are IMO the best.JMO man.
---------- Post added at 03:38 PM ---------- Previous post was at 03:36 PM ----------
WNTOGOFST has used poly and had a manual,but now take in consideration he was launching at 6000 with proper rubber.He can tell you.....
Old 04-09-2012, 02:11 PM   #26
gtstyles2's Avatar
I really don't know what to feel for as far as wheel hop... I did the eibach springs along with struts/shocks and the BMR panhard... if I go with poly will it stiffen my ride? I want it as comfortable as possible I use more for street purpose
Old 04-09-2012, 02:43 PM   #27
Mweigt07's Avatar
Well my car is a full dd all summer and all winter and ride quality is pretty high on my list but I will have 305 DRs on the rear come Thursday when I get them in from AM, but I don't want them to bust at the track. Is there anything extra I can do to help the polys from busting?
Old 04-09-2012, 03:10 PM   #28
If you DD it in summer and winter hope you don't get lots rain or snow in winter. That is with DR's on the rear.
Old 04-09-2012, 03:58 PM   #29
Mweigt07's Avatar
Well we don't get enough rain to worry but we get more than enough snow to make up for it but that's why I have the factory wheels on blizzaks right now, the car does better in snow than my ram does so I'm good there.
Old 04-09-2012, 04:35 PM   #30
Well I talked to j and m and I'm gonna send them both back and he said they will rebuild both he said that if you add grease which I did but they will still warranty it
Old 04-09-2012, 10:54 PM   #31
Good stuff.
Lca/shock pointers AgentOrange 1996-2004 Mustang GT 0 02-14-2012 08:41 PM
LCA brackets Big Johnson 2011-2014 Mustang GT 9 12-16-2011 07:23 AM
LCA Relocation Brackets M3to5.0 2011-2014 Mustang GT 14 11-15-2011 03:01 PM
lca which one kickerofdoom Pre-2005 V6 Mustang 15 07-02-2011 04:57 PM
LCA's are ordered!!!!!!!!!!!!!! Rygen Pre-2005 V6 Mustang 2 02-16-2006 03:19 PM
06:26 PM
