Tire question - Mustang Evolution
Old 04-09-2012, 06:09 AM   #1
Rolltide's Avatar
Tire question
Does anyone know if it is possible to mount 275 35 20 tires on 20x8.5 wheel up front? I will be lowering the car 1 inch up front and was concerned with rubbing. Anyone here have similar setup? Currently I have 255 35 20 Invos mounted up front but just look to narrow and appears that the tires are stretched. Thanks pics below
ID:	46402   Click image for larger version
Rolltide is offline   Reply With Quote
Old 04-09-2012, 06:17 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
275 seems pretty wide for an 8.5. Those nitto 255 seem a little small on there, but tires are kinda like shoes: a Nike size 10 might be the same size as an Adidas size 12. Size will vary from manufacturer to manufacturer.
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-09-2012, 06:24 AM   #3
Napoleon85's Avatar
Re: Tire question
I'm not sure if this helps, but here are what 275/40/18 look like on an 18x9 wheel:
---------- Post added at 08:24 AM ---------- Previous post was at 08:22 AM ----------
Also, the Nitto website says you need at least a 9.0" wheel for the 275/35/20 INVOs, and a 9.5" wheels is recommended. A tire shop MIGHT be able to squeeze it on there, but it might not be safe and you would definitely have a chunk of tread that would not be in contact with the ground.
Old 04-09-2012, 06:46 AM   #4
Rolltide's Avatar
Yeah I hear ya, the only thing that I can think of is that the INVOs running narrow may help out that 275 on the wheel. I wish they made a 265 but its only available on the nitto 555 which is not as good a tire as the INVO. The 255 looks stretched out and I an worried any curb will damage that wheel big time
---------- Post added at 06:46 AM ---------- Previous post was at 06:45 AM ----------
Good point and that is exactly my thinking. A 275 invo may be really close in size to a 255 in another brand. Not sure just guessing
Old 04-09-2012, 07:49 AM   #5
Rolltide's Avatar
Anyone else?
Old 04-09-2012, 08:04 AM   #6
Loc: Austin,TX
Re: Tire question
Yeah that 255 does look stretched. The KDWs don't look stretch at all in a 255. You should be just fine. There is a guy on S197 running 275s all the way around with no issues at all.
Old 04-09-2012, 08:04 AM   #7
Re: Tire question
8.5 a 265 would look better on it but a 275 will of course work. If the brand is known to run more narrow a 275 would of course work better in this case.
Old 04-09-2012, 08:19 AM   #8
Rolltide's Avatar
I think I saw that on the S197 forum. Was he running that size in 8.5 wide rims? I guess I could go with the 265 nitto 555 it just bugs me to run different tires.
---------- Post added at 08:19 AM ---------- Previous post was at 08:17 AM ----------
The 265 only comes in the nitto 555. Not sure if I want to run different tires. I do believe the Invo is a quieter tire and longer lasting thread
Old 04-09-2012, 08:19 AM   #9
Loc: Austin,TX
Re: Tire question
Originally Posted by Rolltide View Post
I think I saw that on the S197 forum. Was he running that size in 8.5 wide rims? I guess I could go with the 265 nittio 555 it just bugs me to run different tires.
I think he was running them on the brembo wheels and it was a AutoX car. What size do you have in the rear?
Old 04-09-2012, 08:23 AM   #10
Rolltide's Avatar
Rear is 20x10 with 295 35 tires. The brembo wheels are 19x9 correct?
---------- Post added at 08:23 AM ---------- Previous post was at 08:21 AM ----------
You are right, your 255s look perfect!
Old 04-09-2012, 08:31 AM   #11
Re: Tire question
yea if you have to choose between 255 and 275 then I would also go with a 275 as well
Old 04-09-2012, 08:38 AM   #12
Rolltide's Avatar
The 275 may be the better choice. That 255 looks to small for my taste. Discount tire told me they will swap them with no problem. That is really nice of them.,Hopefully I can still drop my car and not have rubbing issues
Old 04-09-2012, 09:00 AM   #13
Napoleon85's Avatar
Re: Tire question
With 275s you might. There is a steering rack stop from Roush for lowered cars with 20" wheels.
Roush Mustang Steering Rack Stops (05-12) 404476 - Free Shipping!
Old 04-09-2012, 09:03 AM   #14
Rolltide's Avatar
Thanks, I am going to install the tires first then see if I need this part. How about tge fender? Think it will clear the fender?
Old 04-09-2012, 09:05 AM   #15
Napoleon85's Avatar
Re: Tire question
No clue ... but I would think so unless it's really tall. What's the overall diameter and how much are you going to lower it?
Old 04-09-2012, 09:07 AM   #16
Rolltide's Avatar
I want to say its about 1/2 taller than the 255. The drop will be 1 inch up front
Old 04-09-2012, 09:16 AM   #17
The Blue Dragon
I am running 19x9's on all four corners and have 275 kdw's on all four with zero issues... But I am not lowered
Old 04-09-2012, 09:18 AM   #18
Napoleon85's Avatar
Re: Tire question
You should be good man. I'm running a 29" tall tire in the rear with a 1.5" drop, which made it level with the front that got a 1" drop and there is still room.
Old 04-09-2012, 09:44 AM   #19
Rolltide's Avatar
Good deal, by the way your wheel tire combo looks good
---------- Post added at 09:44 AM ---------- Previous post was at 09:44 AM ----------
Thanks bud for the input
Old 04-09-2012, 09:45 AM   #20
Napoleon85's Avatar
Re: Tire question
Thanks! I can't believe AM discontinued these wheels ...
Old 04-09-2012, 09:59 AM   #21
Rolltide's Avatar
They did? Wonder why
Old 04-09-2012, 10:10 AM   #22
Napoleon85's Avatar
Would have to assume lack of demand. Can still get them in chrome and black but no more hypercoated.
Old 04-09-2012, 11:01 AM   #23
Rolltide's Avatar
Alright, well at least you were able to buy a set. Soon those wheels will be worth more because of the rarity
Old 04-09-2012, 11:41 AM   #24
Loc: Austin,TX
Re: Tire question
Is it going to be a 275/35 up front?
Old 04-09-2012, 11:49 AM   #25
Rolltide's Avatar
Yeah, 275 35 20 up front
Old 04-09-2012, 07:19 PM   #26
Rolltide's Avatar
275s installed up front, hopefully I made the right choice
ID:	46455   Click image for larger version
Old 04-09-2012, 09:11 PM   #27
Loc: Austin,TX
Re: Tire question
Looks good,you will be fine.
Old 04-09-2012, 09:13 PM   #28
Rolltide's Avatar
Thanks bud, it feels different for sure. Traction up front changed big time. I get more of a soft cushion float feeling. Not sure if that is good or bad
04:18 AM
