subframe connectors for conv - Mustang Evolution
Old 04-13-2012, 05:45 AM   #1
are their any subframe connectors available for convertibles???
strictly180 is offline   Reply With Quote
Old 04-13-2012, 07:13 AM   #2
Re: subframe connectors for conv
The ones for regular coupe will be the same.
Old 04-13-2012, 07:19 AM   #3
ive been shopping around and all the ones i see say will not fit convertible. only the bmr one will fit but i would have to remove the rear bracing. do you think it will be safe to remove the rear bracing??
Old 04-13-2012, 07:54 AM   #4
Call and talk to bmr. They can give you best advice. And can tell you what to do. Give you pro's and con's.
Old 04-14-2012, 06:15 AM   #5
JimC's Avatar
Why do you think you need sub-frame connectors? The S197 isn't like the SN95 or Fox bodies - they don't flex like those cars did. The frame is pretty stiff to begin with.
JimC is offline   Reply With Quote
Old 04-14-2012, 07:36 AM   #6
actually for some reason i feel as if it not as stiff as it should be. im startin to get some squeeking from the driver door rubbing with the seal.
09:48 PM
