Clutch slipping? - Mustang Evolution
Old 04-17-2012, 07:17 AM   #1
Gibby's Avatar
Clutch slipping?
This mornin on my way to work I was merging onto the freeway and rolled on the throttle in 4th and the clutch seemed to slip a lil. I tried to make it do it again and it wouldn't. : / anyone else have anything like this happen?
Gibby is offline   Reply With Quote
Old 04-17-2012, 07:26 AM   #2
Napoleon85's Avatar
Re: Clutch slipping?
Is your car a Job1 (built before mid august) 2011? If so, you might want to have the throw-out bearing checked.
Old 04-17-2012, 07:46 AM   #3
Gibby's Avatar
I'm not sure I'll have to check. Was there a recall or warranty with the throw out bearing?
Old 04-17-2012, 08:02 AM   #4
Napoleon85's Avatar
I think that there was a TSB about it, but I can't find it. Something about the bolts not being tight enough and coming loose. I've heard that it can be ugly if it fails, so keep an eye on it.
Old 04-17-2012, 08:08 AM   #5
It's not me, it's you.
primer2tone's Avatar
It's like a tick that you can feel in the pedal when you clutching in and out. The dealer tried to make me pay for it. They said it was from abusive clutching. I laughed in their face and told them to cover it or they can have the car back. I had only had it less then two months back in 6/10.
Old 04-17-2012, 08:09 AM   #6
Napoleon85's Avatar
Might have been the pressure plate, not throwout bearing. I can't keep track of the 20 or so TSBs there are for the 11-12 stangs =\
Old 04-17-2012, 08:14 AM   #7
Gibby's Avatar
I'll try and google it. Thanks for the help. By the way mine is a 2010
Old 04-17-2012, 08:26 AM   #8
Napoleon85's Avatar
I have no idea then ... you might want to check with in the 05-09 section since they have the same engine/trans as you do. The 11+ setup is completely different.
Old 04-17-2012, 08:41 AM   #9
Gibby's Avatar
I posted it here cause its the 2010-2014 section. But I'll check there. Thanks again
Old 04-17-2012, 08:47 AM   #10
Napoleon85's Avatar
I know, it's a bit confusing. They group the cars by body style here, not mechanical makeup.
Old 04-17-2012, 08:53 AM   #11
Gibby's Avatar
Gotcha
10:28 AM
