Clutch replacement #4 cyl misfire - Mustang Evolution
Old 04-26-2012, 01:35 AM   #1
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
So while I was on vacation I had my clutch replaced by a shop in my 2011 mustang gt. I just got back started it up and 2 problems occurred. 3 error codes showed up as #4 cylinder misfiring. I also have an exhaust leak off one of my manifolds. I did a visual inspection and verified the coils are attached to the plugs I did not verify the other ends however. What are the common idiot checks I can do since the shop couldn't return it right to me? Don't worry I will be calling the shop tomorrow to resolve this but I was wondering if there could be some easy fix since I don't know what they could have done with clutch work to cause a number 4 cylinder misfire. Thanks and my apologizes for being a ghost lately.
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 04-26-2012, 01:44 AM   #2
ColeJohnson's Avatar
Re: Clutch replacement #4 cyl misfire
What they could've done is rag your car out by high-revving constantly while it was in the shop... I used to work at a body shop and when nice loud cars came in they were always high-revved and not treated too great.
They shouldn't have touched the engine if they were simply replacing the clutch. The most they would've done is to remove the TOB on the side of the engine. >.>;
2016 Comp Orange GT (current)
Old 04-26-2012, 06:47 AM   #3
Napoleon85's Avatar
We've been through this before. They need to relearn the flywheel or crank position sensor (don't remember which) after replacing the clutch. If you run a search you'll find a couple threads with all the info.
Old 04-26-2012, 07:55 AM   #4
gregtommy's Avatar
So is the only option to straighten this out a dealer or can this be added to a custom tune?
MOTM DEC 2011
Old 04-26-2012, 08:20 AM   #5
Napoleon85's Avatar
It's not a tune issue from what I understand. I would assume any shop that is competent in working with transmissions should be able to do it, but I'm not sure what the process entails.
Old 04-26-2012, 10:35 AM   #6
It is not a tune issue. And yes basically only ones that can do that relearn is the dealer. Heck just tell them it pops up and t hey will do the relearn anyway.
Old 04-26-2012, 01:57 PM   #7
gregtommy's Avatar
I understand now thanks. It's essentially built in the firmware of the computer. So with that the loading of tunes does not effect it.
MOTM DEC 2011
Old 04-26-2012, 09:35 PM   #8
SSC182's Avatar
It's a manual transmission what is there to relearn. There's no adaptive memory for a CKP or a flywheel sensor which would be the same type of sensor either a magnetic sensor, hall effect, optical or magneto resistive. So what y'all are telling him makes no sense. What does make since is that they probably drove the balls off of your car.
SSC182 is offline   Reply With Quote
Old 04-26-2012, 10:51 PM   #9
11stangGT's Avatar
Region: Arkansas
They prolly know what they're talking about more so than yourself.. If you have a question on an 11-12 5.0 wnt2gofst has had two of them and races with several of them pretty much every week as far as I know.. If he doesnt know I can just about guarantee he will find it out..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 04-26-2012, 11:05 PM   #10
SSC182's Avatar
Ok I guess my ASE certifications dont mean anything since I don't race. I'm not trying to step on anyone's toes im just saying what they said doesn't make sense and just because you can bolt on parts and "race" doesn't make you an expert on automotive. So don't tell me I don't know what I'm talking about I don't know everything but when I do write somthing it's because I know about it.
Old 04-26-2012, 11:25 PM   #11
gregtommy's Avatar
Alright, well here is an update so far, they reloaded the software in the ecu and then they said they conducted the crank reset, however after an hour and a half of driving the check engine light can't back on. I got 2 more error codes one was a random misfire, the other one was a #4 cylinder misfire. They didn't have time to look at it again until Tuesday so that is where I am left at until then. So what next is the dealer did tell me they had another software update they wanted to do. I can tell u by driving the car that I am not really having a misfire issue, the engine is running on all 8 cylinders so if the software only errors out on a sensor error, then it is either a sensor or a fault in the software. Agree? Disagree? Discuss!!
MOTM DEC 2011
Old 04-26-2012, 11:40 PM   #12
11stangGT's Avatar
Region: Arkansas
I never said you dont know what your talking about.. Just that mainly he prolly knows a considerable amount more than you when it comes to 11-12 5.0s.. After you've been on here as long as I have you'll figure that out.. He's pretty much the go to guy on the forum.. There are PLENTY of ASE certified mechanics and whatever other certifications that know very very little about a '11+ 5.0s...
---------- Post added at 11:40 PM ---------- Previous post was at 11:34 PM ----------
Don't get me wrong I'm not saying anyone's right or wrong cuz I don't know enough about it.. I'm not certified it sh*t lol.. But given the car is hitting on all cylinders it's gotta be a sensor or tuning/software issue..
Old 04-27-2012, 09:19 AM   #13
Could be sensor. Or the computer. They ended up replacing my computer.
---------- Post added at 09:19 AM ---------- Previous post was at 08:58 AM ----------
I will say you don't have no clue what you are talking about and yoru ASE Cert means jack. Any one can study a book and take a test. And Being i have had the ASE books I knwo they don't cover **** with teh Modular engines. And these was teh latest books. And my buddy just used them to get certified.
Right from Ford's TSB's and Oasis
21474 SOME VEHICLES COULD EXHIBIT MISFIRE CODES AFTER CERTAIN REPAIRS - MULTIPLE VEHICLE LINES
SOME VEHICLES EQUIPPED WITH ON BOARD DIAGNSTICS (OBD) MISFIRE MONITOR NEUTRAL PROFILE LEARNING CAPABILITIES MAY EXPERIENCE THE MIL ILLUMINATING ACCOMPANIED BY ONE OR MORE ENGINE MISFIRE CODES P030X IF THE CRANKSHAFT POSITION SENSOR PROFILE (MP_LRN) IS NOT RELEARNED FOLLOWING CERTAIN HARD ENGINE REPAIRS. THE MP_LRN DATA IS NO LONGER CLEARED WITH A KAM RESET OR BATTERY DISCONNECT. REPAIRS THAT REQUIRE RELEARNING THE MP_LRN DATA: CRANK SENSOR,CRANK SENSOR, TRIGGER WHEEL, ENGINE TIMING, DAMPER, CRANKSHAFT, ENGINE, FLYWHEEL/FLEXPLATE, CLUTCH (MANUAL TRANS), PRESSURE PLATE (MANUAL TRANS),TORQUE CONVERTER (AUTO TRANS). FROM THE IDS TOOLBOX SELECT "POWERTRAIN", THEN "SERVICE FUNCTIONS", THEN "MISFIRE MONITOR NEUTRAL PROFILE CORRECTION" AND FOLLOW THE PROMPTS.
EFFECTIVE DATE: 08/26/2010
1463 2010-2011 5.0L/6.2L - MISFIRE CODES P0300-P0316
SOME 2011 MUSTANG VEHICLES EQUIPPED WITH A 5.0L ENGINE AND 2010 F150 AND 2011 SUPER DUTY VEHICLES EQUIPPED WITH A 6.2L ENGINE MAY EXHIBIT THE MALFUNCTION INDICATOR LAMP ILLUMINATING ACCOMPANIED BY ONE OR MORE DIAGNOSTIC TROUBLE CODES P0300 THROUGH P0316. IT IS RECOMMENDED THAT THE CRANKSHAFT POSITION SENSOR PROFILE (MP_LRN) BE RELEARNED PRIOR TO PERFORMING THE PC/ED PINPOINT TESTS FOR THESE CODES. FROM THE IDS TOOLBOX SELECT "POWERTRAIN", THEN "SERVICE FUNCTIONS", THEN "MISFIRE MONITOR NEUTRAL PROFILE CORRECTION" AND FOLLOW THE PROMPTS. IF ONE OR MORE OF THE MISFIRE CODES RETURN AFTER PERFORMING THE RELEARN PROCEDURE, REFER TO THE PC/ED PINPOINT TESTS.
EFFECTIVE DATE: 08/17/2010
ALso guess all thee people to include me know not what we are talking about.
WWW.S197FORUM.COM
WWW.S197FORUM.COM
WWW.S197FORUM.COM
WWW.S197FORUM.COM
WWW.S197FORUM.COM
Old 04-27-2012, 02:48 PM   #14
SSC182's Avatar
Sorry didn't know you would get your feelings hurt by words on the Internet and thanks for proving my point that the CKP doesn't have adaptive strategies the PCM does.
Old 04-27-2012, 03:18 PM   #15
Fact is you said basically had nothing to do.
Old 04-27-2012, 03:40 PM   #16
avengnd's Avatar
Glad to see you back online. Sorry to hear about the Pony, you must be going nuts...
---------- Post added at 08:40 PM ---------- Previous post was at 08:39 PM ----------
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 04-27-2012, 03:43 PM   #17
gregtommy's Avatar
Yeah I had a friend take it back to the dealer again today. So we will see this time around if the dealer has success. The other reason for my urgency is because I want to get my headers and supercharger installed this weekend and I am not making that move until the check engine lights r clear. Anyway thanks its great to be back.
MOTM DEC 2011
Old 04-27-2012, 03:54 PM   #18
BLOWER MMMMM POWA!
Old 04-27-2012, 06:18 PM   #19
gregtommy's Avatar
YES!!! Exactly right, then I will be blown on my car and my truck, although its easy with a truck since it is diesel. Check Engine light is clear again...they said they found the procedure i told them to do yesterday when i came in. So i think the problem will remain solved now
MOTM DEC 2011
Old 04-27-2012, 06:43 PM   #20
avengnd's Avatar
Good to hear. Look forward to pics of the new mods.
2014 Shelby GT500
Old 05-12-2012, 10:08 PM   #21
gregtommy's Avatar
A few pics as promised however it is still sitting there until they get the right tune to me.
ID:	50324   Click image for larger version
MOTM DEC 2011
Old 05-13-2012, 08:08 AM   #22
Napoleon85's Avatar
Looks great! That STB just barely clears, doesn't look like it could be any closer.
Old 05-13-2012, 10:05 AM   #23
avengnd's Avatar
Fracking Awesome!!! Looks great!!!
2014 Shelby GT500
Old 05-13-2012, 10:38 AM   #24
gregtommy's Avatar
Yeah that's the truth. It barely clears the 123 mm air intake but the stb will cover up to a 2.9L whipple and it is sold by steeda. As far as I know it is the only strut tower brace sold that will fit a Mustang GT modded with an sc.
Thanks bud, now only if they could get the tune right i would have driven it into work today. Right now its just the most beautiful paper weight I have ever seen
MOTM DEC 2011
Old 05-13-2012, 02:06 PM   #25
avengnd's Avatar
GT500 STB will fit as well what I have in mine.
LOL that is expensive.
2014 Shelby GT500
Old 05-13-2012, 02:18 PM   #26
gregtommy's Avatar
that's cool i didn't manage to find one of those.
Yeah expensive to say the least lol, just can't wait to get the tune loaded so i can put all my woes asside. I put new exhaust, a new aluminum drive line and a supercharger in and haven't been able to test any of them out yet to make sure they don't need to be tweaked.
MOTM DEC 2011
Old 05-13-2012, 03:26 PM   #27
avengnd's Avatar
Nice some great mods. I'm guessing the drive line is drive shaft? I'm curious to know what you think of that when you get her all up and running.
2014 Shelby GT500
Old 05-13-2012, 03:31 PM   #28
gregtommy's Avatar
I will definitely let u know it just looks better being a one piece plus no carrier bearing. Yes it is an aluminum drive shaft from American muscle.
MOTM DEC 2011
Old 05-13-2012, 05:05 PM   #29
avengnd's Avatar
Great. I'll have to check it out.
2014 Shelby GT500
Old 05-22-2012, 09:52 AM   #30
gregtommy's Avatar
Just to let u know the driveshaft is amazingly smooth. No vibrations minimal moving parts compared to the stock one and just plain looks better
MOTM DEC 2011
10:58 AM
