LCA install question - Mustang Evolution
Old 04-27-2012, 01:10 PM   #1
back n a stang's Avatar
Any tips to unhooking cable that runs thru OEM LCA. Havent pulled the wheel off to look so it may be simple.Also if re-using hardware is the tq 118 or what? seems I read that somewhere.Any tips at all on the install is great.Putting BMR's adjustables on that I bought back on black friday.Just have not had time.
Old 04-27-2012, 02:11 PM   #2
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
Re: LCA install question
The way i unhooked the cable from the caliper was to use a screw driver to take the tension off the cable with one hand and a pliers in the other hand to grab it and pull it out. It worked pretty easily but u may have to have al ittle patience with it. Otherwise yes the torque should be the same, it will be listed in the instructions on what to torque it back down to. Don't forget to grease them too, there should be taps in them. The way i went about it was to put a jack stand on the chassis of the car and use the jack under the axle to remove the tension from the lcas. It worked pretty smoothly and will you attach the new ones all you should have to do is raise or lower the jack to get the bolt holes to match back up. Pretty easily installation shouldn't cause you too much hassle. Good luck
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 04-27-2012, 02:19 PM   #3
Napoleon85's Avatar
There is a much easier way to do this....
There is a retaining clip that keeps tension on the cable, it's flat and rusty, pull it out (toward the back of the car). The cable will then slide out from the slot its in and can be rotated and removed from the entire assembly.
Old 04-27-2012, 08:13 PM   #4
Thanks guys.....I thought putting the jack stands under the rear end axle and letting it rest this way and remove jack.This way no movement is likely to happen,which is very important.
Old 04-27-2012, 11:19 PM   #5
Mich mustang's Avatar
Put adjustable Panhard bar on today.the factory bar
---------- Post added at 11:19 PM ---------- Previous post was at 11:18 PM ----------
Oops. The factory bar was half filled with sand and very heavy. What's up with the sand?
Mich mustang is offline   Reply With Quote
10:10 PM
