Spark Plug Replacement on a Supercharged Car? - Mustang Evolution
Old 04-28-2012, 07:27 AM   #1
CZYFAST's Avatar
I don't want to seem like an idiot but I was wondering how many miles roughly should you change out your spark plugs on a supercharged car? I mean is it the same as a NA car or should you replace them sooner? I am not sure when you should because I usually just pull a spark plug and see if they need to be replaced but I wasn't sure if their was an actual mile or something of replacement, try not to bash me too bad because I seriously just don't know if it's the same as any other car or what.
IN SALEEN WE TRUST!!!
CZYFAST is offline   Reply With Quote
Old 04-28-2012, 08:08 AM   #2
tc x 4's Avatar
Should b the same. I never changed a plug by miles. I pull them also.
Old 04-28-2012, 10:12 AM   #3
A lot depends on how hard you run the car, what type fuel you are running. I would check them about every 10,000 miles.
Old 04-28-2012, 10:16 AM   #4
CZYFAST's Avatar
Yeah I play quite a bit and I always run 91 because that's the best I get in California so you would check every 10,000 huh ok then I should probably check them pretty soon and just make sure the gap is still good and make sure they aren't white or anything but yeah I was just curious if their was a certain time to check them and if running a supercharger made that speed up the process
12:04 AM
