05-06-2012, 11:03 AM
#1 | | Registered User
| Boss intake installed!
I installed my boss intake and x pipe last night,
Thing is a monster now, Can't wait to take it to the track this weekend!
I would like to thank all the users here that have posted valuable info about the intake, made install a lot easier and didn't run into many problems.
Note for anyone planning on installing the boss intake: You definitely need safety goggles when removing the fuel feed line and be extra careful when mounting the purge valve on the front of the block as to make sure it is oriented correctly to where the electrical connection will reach and the plastic is semi delicate so don't break it! Lol
05-06-2012, 11:36 AM
#2 | | Registered User
I love my boss manifold. Couldn't be any happier with it. |
05-06-2012, 12:06 PM
#3 | | Senior Member
Looks good. Love my boss also. |
05-06-2012, 12:20 PM
#4 | | Registered User
| Quote: |
Note for anyone planning on installing the boss intake: You definitely need safety goggles when removing the fuel feed line and be extra careful when mounting the purge valve on the front of the block as to make sure it is oriented correctly to where the electrical connection will reach and the plastic is semi delicate so don't break it! Lol | Did u keep the stock cold air and which tune did u use? Do u feel like it lost torque but gained it back up top?
05-06-2012, 12:23 PM
#5 | | Registered User
| Quote: |
Originally Posted by Ravnus
Did u keep the stock cold air and which tune did u use? Do u feel like it lost torque but gained it back up top? | I didn't really feel any noticeable torque loss. With the amount of gains u get up top whatever was lost isn't even an issue.
05-06-2012, 02:00 PM
#6 | | Registered User
| Quote: |
Originally Posted by wnt2gofst Looks good. Love my boss also.
| I love your Paxton lol ---------- Post added at 01:00 PM ---------- Previous post was at 12:55 PM ---------- Quote: |
Did u keep the stock cold air and which tune did u use? Do u feel like it lost torque but gained it back up top? | I did retain the stock air intake, used a bama 91 race tune(no 93 in my area), and I can barely tell that there is a loss of torque, I love how it smoothed out the power band too. And yes the high end surge of power from around 5 or 6 all the way to 7800 is awesome. Definitely makes up for the minuit amount of torque loss.
05-06-2012, 03:15 PM
#7 | | Registered User
| Re: Boss intake installed!
What redline does bama usually set with the boss intake on NA?
05-06-2012, 03:32 PM
#8 | | Registered User
I'm not sure what they set it for if it's stock or if you don't ask, but I had to ask them specifically on the tune specifics form for 7800.
05-06-2012, 08:27 PM
#9 | | Registered User
Is their #8 cylinder warranty still in effect if the rev limit is raised? I believe my tune is set at 7,500rpm from bama however im going to call them up to raise it as well.
05-06-2012, 09:15 PM
#10 | | Registered User
Do you have any good links to a thorough install? I'm doing one this week, late model restoration did one but I like getting different approaches lol
05-06-2012, 09:25 PM
#11 | | Moddin' ain't easy...
| Quote: |
Originally Posted by coyote414 Do you have any good links to a thorough install? I'm doing one this week, late model restoration did one but I like getting different approaches lol | Here ya go. Install of the Boss 302 intake manifold!
__________________ |
05-06-2012, 09:44 PM
#12 | | Registered User
| Quote: |
Originally Posted by Yellow50 Is their #8 cylinder warranty still in effect if the rev limit is raised? I believe my tune is set at 7,500rpm from bama however im going to call them up to raise it as well. | Not sure but I'm not too worried about it.
05-06-2012, 09:51 PM
#13 | | Registered User
| Quote: |
Not sure but I'm not too worried about it. | I imagine it would be unless they said it wasn't.
05-10-2012, 01:20 PM
#14 | | Registered User
| Quote: |
Originally Posted by Napoleon85
I imagine it would be unless they said it wasn't. | I'd assume the opposite...
05-10-2012, 02:09 PM
#15 | | Registered User
| Re: Boss intake installed! Quote:
Originally Posted by coyote414 I'd assume the opposite... | You assume that AM would revoke a written warranty without any clause in said warranty stating the conditions would do so, and without any written or verbal notification that it had been voided? Exactly why would you assume that?
05-11-2012, 01:55 PM
#16 | | Registered User
| Quote: |
You assume that AM would revoke a written warranty without any clause in said warranty stating the conditions would do so, and without any written or verbal notification that it had been voided? Exactly why would you assume that? | I would verify if they'd still cover it if you ask them to tweak the tune certain ways than they usually would*
05-11-2012, 08:19 PM
#17 | | Evolution's Finest
Very nice!
~ Alan 2012 GT 5.0 Powered by Ford Racing March 2012 Mustang of the Month Garage; Videos: Dyno Track Exhaust (40 Series Flowmasters)
05-11-2012, 08:32 PM
#18 | | Registered User
I'm installing mine this Weekend!
05-11-2012, 08:34 PM
#19 | | Registered User
Originally Posted by Untamed5.0 I'm installing mine this Weekend! | Nice ... let me make one suggestion though. I found it a lot easier to install the fuel rails/injectors after the manifold was seated. Try it whatever way you like, but I had a really hard time trying to put the assembly in whole.
05-11-2012, 08:35 PM
#20 | | Registered User
Any advice is appreciated. I'll try that! |
05-11-2012, 08:38 PM
#21 | | Registered User
Originally Posted by Untamed5.0 Any advice is appreciated. I'll try that!  | When I put the fuel rail/injector assembly back in with the manifold in place, I had to start with them almost upside down, slip it in front of the throttle body opening and just flip it down into place. Worked for me, but some people have had good luck putting it on as one piece as well.
05-13-2012, 04:59 PM
#22 | | Be different: Conform.
Just got mine on. Love it!!!
05-13-2012, 05:59 PM
#23 | | Registered User
Sweet! Where'd you get the fuel rail covers? Did you pay the ridiculous 150+ or did you find a cheap solution?
05-13-2012, 06:01 PM
#24 | | Be different: Conform.
| Quote: |
Originally Posted by Xofferick Sweet! Where'd you get the fuel rail covers? Did you pay the ridiculous 150+ or did you find a cheap solution? | I got connections fool, lol. My dyno guy gets parts at cost thru ford. He hooked it up. I wanted it to look clean. Dont like it without them.
05-13-2012, 06:08 PM
#25 | | Registered User
Lol nice man, I would like to get a set but a couple pieces of plastic for the price is pretty bad. Definitely looks better with them tho.
05-13-2012, 06:09 PM
#26 | | Be different: Conform.
| Quote: |
Originally Posted by Xofferick Lol nice man, I would like to get a set but a couple pieces of plastic for the price is pretty bad. Definitely looks better with them tho. | They are not plastic. They are actually solid high density foam.
05-13-2012, 06:35 PM
#27 | | Registered User
Holy crap.... That's even worse lol jk
05-13-2012, 06:36 PM
#28 | | Be different: Conform.
| Quote: |
Originally Posted by Xofferick Holy crap.... That's even worse lol jk | The sad thing is, the one cost a third of what the other does.
