Painting Rim Black - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 2010-2014 Mustang GT
Closed Thread
Old 05-07-2012, 10:31 AM   #1
mmike87 is unknown around these parts
Painting Rim Black
OK, so I spent some time searching around and came across many different thoughts on painting rims black.
I know powder coat is the most durable finish, however the inconvenience of removing all 4 wheels and tires is burdensome since my 2012 GT is my daily driver.
I am leaning towards using Duplicolor ... I found a couple of YouTube videos and they show different procedures.
What are y'alls thoughts on this? I have the 19" Brembo wheels that came with the Brembo package. These wheels are already painted, correct? So there is no need for primer or stripping the wheels ahead of time.
Any thoughts / examples / suggestions much appreciated. Thanks.
mmike87 is offline
Old 05-07-2012, 11:13 AM   #2
Be different: Conform.
DWC_SmOziLLa's Avatar
DWC_SmOziLLa is unknown around these parts
The rims come from the factory, powdercoated. If you clean them Extremely well, them sand them real good with scotch brite, take all the shine off. Them clean them again duplicolor makes a good cleaner. Mask them off real good and shoot them when they are warm. You should not have any problems. Just follow the instructions on the can and use good paint. And always let them dry as long as possible in a warm enviroment. Good luck!
Check Out My Garage!!!
2013 Ford Mustang GT/CS 6MT - Just a few Go-Fast goodies
Tuned at Performance Evolution in Smryna, DE
SEPTEMBER 2012 - Mustang of the Month
DWC_SmOziLLa is offline
Old 05-07-2012, 11:56 AM   #3
5LHO is unknown around these parts
Re: Painting Rim Black
The rims come from the factory PAINTED and, not very well at that. I had one replaced within a few hundred ks because of paint adhesion problems.
There's a base coat gloss black, then the gunmetal cover coat, then clear, on a Brembo 19" wheel. This is dumb as having a gloss base coat will promote paint adhesion issues.
5LHO is offline
Old 05-07-2012, 12:13 PM   #4
Edens5's Avatar
Edens5 is unknown around these parts
Do you really want to cut corners on your rims? Rims make or break a car. Get them powder coated or buy new ones.
Edens5 is offline
Old 05-07-2012, 01:04 PM   #5
No ... but I can't be without a car, either. If I could find a shop that could do it turnkey it would already be done.
mmike87 is offline
Old 05-07-2012, 01:24 PM   #6
I should have mentioned this before. I am, and always will be a strong advocate for powdercoating. I work at two powdercoating businesses over the course of 6 years. I do strongly recomend powdercoating. With that said, i underdstand thats its hard or nearly impossible to find a powdercoat shop that can be trusted and reliable enough to be able to remove your tires, tps, strip the existing coating, recoat the wheels, mount and balance your tires and sensors all in one day. While keeping it afordable and doing a good job. These are the problems we face when trying to mod a daily driver. Paint is ok when done properly, thats the hardest part. The good thing is thst you could paint them now and see if you like it. And when you have other means to give up your wheels for a week, they can be coated to last, in whatevet color you choose.
Old 05-07-2012, 01:32 PM   #7
All good suggestions and points. I appreciate the info.
mmike87 is offline
Old 05-07-2012, 01:36 PM   #8
No problem. One more suggestion, i have done this before, it works great. Find another set of wheels and tires. Get them for a good price, get them coated, put them on your car and then sell your full set for what you paid for the second set. Yeah you will have a little money tied up for a week or two. But i highly doubt you will have any trouble getting it back asap. Good luck!
Old 05-07-2012, 03:27 PM   #9
If you're a Brembo guy you can buy the Brembo 19s in black only for ~$225 a wheel from FRPP vendors like buyfordracing.com
5LHO is offline
Old 05-07-2012, 03:55 PM   #10
Loc: Austin,TX
DDTCM's Avatar
DDTCM is just getting started.
Hey Mike,where are you located?
---Dan--
2011 5.0 6MT Black on black premium,3.73 option and some go fast goodies!
*POSTING RULE #1*
Before you post a question, use the forum search feature to determine whether your topic has already been covered.
http://www.mustangevolution.com/foru...ork&page=rules
DDTCM is offline
Old 05-07-2012, 05:35 PM   #11
Fluvanna County, VA
---------- Post added at 07:35 PM ---------- Previous post was at 07:33 PM ----------
Yeah, I am thinking about that, too.
If I could get 3/4 what I paid for the new rims I'd be thrilled ... my current rims have 2900 miles on them and are like brand new.
I'd just hate to get stuck with two sets of rims ... my wife would have a fit.
mmike87 is offline
Old 05-07-2012, 06:30 PM   #12
5pointOh's Avatar
5pointOh is unknown around these parts
Just plastidip them and paint over it whatever color you like. You don't like it..just peel it off, simple as that.
2012 kona blue gt, GT500 exhaust, tinted windows, J&M Panhard bar, Steeda Ultralites, Koni STR shocks and struts, GT500 strut mounts, SR Performance shifter, Steeda Shifter Bracket, 20" Giovanna Monzas..damn I need more money!!
5pointOh is offline
Old 05-11-2012, 09:50 AM   #13
I think I am going to try and snag the new Ford Racing black "Brembo Rims" and sell the current rims to make up some of the cost.
I did some searching, and re-manufactured rims are more than what Ford Racing is selling the black ones for ... that seems excessive.
What do y'all consider a fair price for "like new" Brembo wheels? $150 each? More? Less?
Thanks.
mmike87 is offline
Closed Thread
10:20 PM
