Do my new tires require a tune?? - Mustang Evolution
Old 05-08-2012, 01:14 AM   #1
Edens5's Avatar
I bought a staggered set of rims and tires this weekend and it just occurred to me that i may need a tune, which will suck. I have 18x9 with 255/45 up front and 18x10 275/40 in the back. Anyone know if i need to blow another paycheck this month haha. Thanks.
Edens5 is offline   Reply With Quote
Old 05-08-2012, 02:47 AM   #2
torch1's Avatar
Long term the answer is yes. You would need a tune if the overall diameter of the tires change. The tune would adjust your speedometer. If you have a gps or something that uses gps to gauge your speed can work until then
torch1 is offline   Reply With Quote
Old 05-08-2012, 07:59 AM   #3
Edens5's Avatar
Which tune would u recommend. N how does that work? I buy it, they mail it to me n i plug it in?
Old 05-08-2012, 07:59 AM   #4
Napoleon85's Avatar
Re: Do my new tires require a tune??
You don't need a tune for new tires. Your speedo might be off a bit, but I think that can be fixed by Ford or maybe a tire shop without voiding your warranty.
Old 05-08-2012, 08:00 AM   #5
Edens5's Avatar
What size are your tires napolean
Old 05-08-2012, 08:01 AM   #6
Napoleon85's Avatar
305/45/18 in the rear and 275/40/18 up front.
Old 05-08-2012, 08:21 AM   #7
Edens5's Avatar
Are you using a tune?
Old 05-08-2012, 09:56 AM   #8
Napoleon85's Avatar
Yes, but I was before the new tires. Drove around without adjusting the tune for a few weeks and it was fine, just the speedo was off a bit.
Old 05-08-2012, 10:56 AM   #9
BossFiveOh's Avatar
I switched to wider tires as well and got it retuned. Not sure by how much the speedo was actually off, but still feels the same.
BossFiveOh is offline   Reply With Quote
Old 05-08-2012, 11:56 AM   #10
Edens5's Avatar
Wen u guys say re tuned, do u mean u got like a bama kit or took it to a performance shop
Old 05-08-2012, 12:00 PM   #11
Rmag's Avatar
So a tune should be used when your changing the wheel size only? The width doesn't matter?
Rmag is offline   Reply With Quote
Old 05-08-2012, 12:12 PM   #12
do the math, see if the overall tire height is different, if so why did you buy the wrong size tires?
take a tire number
245/45/17
the first number is MM wide (how wide in MM the tire is and ever 25.4mm = 1 inch)
the second number is a percent 45% of 245 = sidewall height (in MM)
the last number is rim width the tire fits
so if you have a 245/45/17 tire and you want to run a 275 wide tire you want a 275/40/17 so the sidewall height of the tire is about the same (245 * .45 is about 275 * .40)
if you go from 17 to an 18in rim then you need a shorter sidewall to make up for the extra rim. For one inch gain in rim size you need to drop the sidewall .5 inches~
Old 05-08-2012, 12:15 PM   #13
Edens5's Avatar
American muscle didnt really give me a choice, i jus click checkout and they do the rest haha
Old 05-08-2012, 03:40 PM   #14
Rolltide's Avatar
Its not really a tune that you need. You need to recalibrate your speedo if its off. The dealership can do this for you. If you buy a tuner from american muscle or such, I believe the tuner is equipped with the recalibration feature for your speedo. Hope that helps
Rolltide is offline   Reply With Quote
Old 05-08-2012, 04:41 PM   #15
11stangGT's Avatar
Region: Arkansas
What were your factory Wheels? I'm assuming the standard 19s.. If so you had 245/45-19s.. Which is only .25 mm (.0098in) taller than your 275/40s... That being said you do not need to change your speedo or tune or anything bc that isn't enough to effect anything.. There can be twice that much difference just between different brands or styles of tires that are the same size..
---------- Post added at 05:41 PM ---------- Previous post was at 05:31 PM ----------
Forgot that you switched wheels sizes.. So basically w your 18s your tires are almost exactly 1" shorter than your previous set.. Which can make a difference.. Can affect your speedo and mileage accuracy..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 05-09-2012, 01:27 AM   #16
Edens5's Avatar
Well nbd. Ill have my buddy do all that wen i take it in next. As long as its not going to hurt my car, i doubt the 20 miles i drive it a week is going to have an impact lol.
Old 05-09-2012, 07:01 AM   #17
Send a message via AIM to Borii
The difference won't be TOO much. Gears are what REALLY throw off the car. Otherwise you'll be ok unless a few MPH is strict where you live.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 05-09-2012, 09:20 AM   #18
Edens5's Avatar
Like i said i should be ok for a month before i take her to the shop
Old 05-09-2012, 09:41 AM   #19
Napoleon85's Avatar
Yup, nothing to worry about.
02:45 AM
