LIvernois 9 sec ZL1(1st one) - Mustang Evolution
Old 05-11-2012, 11:55 PM   #1
Mods:
Livernois Motorsports In-House CNC LSA Cylinder Heads
Livernois Motorsports Stage 2C High Lift Camshaft
Livernois Motorsports LSA Head Studs (Available soon)
Livernois Motorsports Exclusive Heat Exchanger (Available soon)
Livernois Motorsports Solid Supercharger Coupler
Livernois Motorsports Supercharger Pulley
Livernois Motorsports Exclusive Steel Idler Relocation Bracket w/ Metco Pulleys (Available soon)
Livernois Motorsports Spec’d Injectors
Livernois Motorsports Dual Fuel Pump Upgrade
Precision Industries Converter Built to Livernois Specs
Metco Oversize Crank Pulley Ring
Innovators West Oversize Balancer
Rotofab/Livernois Cold Air Intake (Available soon)
Stainless Works Longtube Headers & Connection Pipe
Hardened Pushrods
NGK TR6 Spark Plugs
160 Degree T-Stat
GM 90mm Throttle Body
Bogart 17” Wheels w/ Slicks & Skinnies
Livernois Motorsports Dyno Tune
Dyno Results Stock:
476 RWHP / 476 RWTQ
The best pass 100% stock with 110 miles on the odometer was 12.41 @ 115.9 mph. It was traction limited and the track was extremely busy, so I didn’t get a good feel for the car and how to launch it.
Dyno Results Modified:
707 RWHP / 680 RWTQ (Roughly 850 crank HP)
Package just like they ran the 9 would be about 16k once add stall/heat exchanger/bigs-littles. Still ****ing nasty. Peopel have way more in the 5,0's that run 9's.
Oh and Livernois is know for work on Mustangs more then Camaro's.
Old 05-12-2012, 12:02 AM   #2
vinnygt's Avatar
That thing sounds fierce! I guess this proves that u don't really need a bunch of hp to be fast. U just need to be able to put it to the ground.
vinnygt is offline   Reply With Quote
Old 05-12-2012, 12:54 AM   #3
Pretty much.
Old 05-12-2012, 08:43 AM   #4
Re: LIvernois 9 sec ZL1(1st one)
Impressive, especially for the mega-curb weight.
MPH is pretty good too, showing it's really putting out the power the dyno claims.
you see how straight that thing fires out of the hole? Nice, no drama.
Old 05-12-2012, 10:07 AM   #5
Honestly it is impressive for the weight.
Old 05-12-2012, 10:50 AM   #6
Untamed5.0's Avatar
Wow that's sick!
Untamed5.0 is offline   Reply With Quote
12:44 PM
