Bama tune - Mustang Evolution
Old 05-14-2012, 12:03 AM   #1
Bama tune
I got a 2012 GT with a few bolt ons, however its time to make a real change and tune it. Probably gonna go with Bama, unless advised other wise. Is it necessary to get a cai with the tune? I have a k&n drop in filter already. Anyone have any mechanical problems after tuning since it will void the warranty? Any advice is much appreciated.
ercolanom1 is offline   Reply With Quote
Old 05-14-2012, 12:24 AM   #2
11stangGT's Avatar
Region: Arkansas
+1 on the Bama tune.. It won't give you the MOST power but definitely more power and theres the advantage of the #8 cylinder warranty.. Thats what i Have and am satisfied.. Don't waste your money on the CAI.. Virtually no power gains.. 1-3hp MAYBE..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 05-14-2012, 03:36 AM   #3
medicespo's Avatar
Be careful bama tunes run really lean which isn't good at all
2012 GT 5.0
6speed manual
flowmaster super 10's
lethal performance o/r x pipe
BAMA sct tuner
35% tint all the way round
medicespo is offline   Reply With Quote
Old 05-14-2012, 06:15 AM   #4
Napoleon85's Avatar
They shouldn't. If you're running lean you should be sending them datalogs so they can correct it, which you should always do with mail order tunes anyways.
Old 05-14-2012, 06:44 AM   #5
Yellow50's Avatar
How do u send a datalog? Or even record it?
Yellow50 is offline   Reply With Quote
Old 05-14-2012, 07:18 AM   #6
Re: Bama tune
its ALWAYS (I repeat ALWAYS) a great idea to get any tune dyno checked just to be safe, its very cheap insurance and you can do a before/after or just an after to see where you are at. Also, data log it (get with AmericanMuscle for log files) and they can tweek the tune if needed.
Just a major FYI this will void the warranty
Old 05-14-2012, 08:33 AM   #7
There seems to be mixed opinions on getting a Bama tune. I can't afford getting it professionally tuned right now, is it a bad idea to tune it at all then?
Old 05-14-2012, 09:58 AM   #8
Napoleon85's Avatar
Re: Bama tune
You need to install the SCT LiveLink software. Call or email BAMA and they will send you detailed instructions.
---------- Post added at 11:58 AM ---------- Previous post was at 11:55 AM ----------
Bama tunes are fine, just make sure you relearn the idle/fuel trim strategies (I've posted directions for this in no less than two threads and the last few days so it should be easy to find) and send them datalogs to make sure there aren't any issues.
Old 05-14-2012, 10:01 AM   #9
Thanks for all of the advice.
Old 05-20-2012, 01:36 PM   #10
I was thinking of putting the boss intake manifold on before getting a tune, is it worth having it without a tune?
Old 05-20-2012, 01:37 PM   #11
11stangGT's Avatar
Region: Arkansas
You need a tune w the manifold
Old 05-20-2012, 02:04 PM   #12
I guess I'll have to save up a little longer then
Old 05-20-2012, 07:31 PM   #13
11stangGT's Avatar
Region: Arkansas
I feel your pain!
Old 05-20-2012, 07:44 PM   #14
Rapinator126's Avatar
get a tune from lethalperformance or evolution performance. john lunds does all the tunning
Old 05-20-2012, 07:47 PM   #15
Its a better tune?
Old 05-20-2012, 07:47 PM   #16
Its a better tune?
yes
Old 05-20-2012, 07:50 PM   #17
Re: Bama tune
That or call Chris Holmes at HPX Motorsports. He is featured in new MM&FF magazine.
Old 05-20-2012, 08:18 PM   #18
Re: Bama tune
is the SCT livewire firmware capatible with Macs'?
Previous: '02 GT, '04 GT, '07 GT & a few chevys in between
'13 GT
Woodga16 is offline   Reply With Quote
Old 05-20-2012, 08:24 PM   #19
Nope. Have to split hard drive and have one that is windows based.
Old 05-20-2012, 09:08 PM   #20
Untamed5.0's Avatar
Unfortunately no. I ran into this problem myself. You will have to either run virtualization software and run windows that way, parrallels or VMware fusion, or use Bootcamp and run windows that way. This software only runs on crumy windows
Untamed5.0 is offline   Reply With Quote
Old 05-23-2012, 02:09 AM   #21
yes
How is it a better tune? It is a known fact that the lund tunes have the most engine failures to date for mail order tuning.
2011gt85 is offline   Reply With Quote
Old 05-23-2012, 06:30 AM   #22
only reason bama is know is bc of american muscle thats it. only thing they have set records with there tune is a v6. if someone is worried about there motor that bad then leave it stock dont tune. lunds tunes are alot better for the money and are proven
Old 05-23-2012, 06:43 AM   #23
I've decided to wait a few weeks and save up for a custom tune by JDM in Freehold, NJ. They have a great reputation from everything I have read and heard. I would rather have a professional hook it up to a dyno and their computers to tune it as opposed to me doing it from a mail order tune. I can do bolt ons and some mechanical work, but when messing with the computer I'll leave it to the pros. I'll update my profile soon.
Old 05-23-2012, 06:53 AM   #24
good choice just keep a good eye on your air/fuel
Old 05-23-2012, 09:23 AM   #25
??? Most failures huh..proof..I know 1 that has had a failure with a lund. Least 3 with Bama..and a local Guy I know his let go with his stock car.
Old 05-23-2012, 02:00 PM   #26
SilverBullet12's Avatar
Re: Bama tune
I have a lund and a Bama tune. The Bama tune so far has been better with customer service and performance. I data logged my tune and sent it over to Lund and got a revised tune because the orginal wasnt pulling spark in 4th gear, I havent run the new tune at the track yet. The Bama I ran a 12.1, once i run the revised Lund tune ill be sure to post it up. Either direction you go you wont be unhappy.
SilverBullet12 is offline   Reply With Quote
Old 05-23-2012, 03:29 PM   #27
Re: Bama tune
Seems like Lund is extremely busy right now. My vote goes to HPX, he has emailed me back really late just to answer some questions.
'13 GT
Old 05-23-2012, 03:38 PM   #28
bigsmitty24's Avatar
Ive heard u have to have off-road exhaust for a lund tune to work. Is that true?
bigsmitty24 is offline   Reply With Quote
Old 05-23-2012, 05:23 PM   #29
Re: Bama tune
Partially true haha. If you get the cammed tune you need the off road exhaust. Regular tune anything works
---------- Post added at 07:23 PM ---------- Previous post was at 07:21 PM ----------
Im about an hour south of freehold and never heard of them haha. Lemme know how the tune is, I really wanna get my car on a dyno for a tune. Thanks!
Old 05-24-2012, 03:31 PM   #30
I'm about an 35 minutes North of Freehold, in Totowa. I'll keep you posted.
Old 05-24-2012, 04:03 PM   #31
Chris is awesome. He stayed up till 1am datalogging and revising my tranny tune.
Old 05-24-2012, 04:06 PM   #32
How do you monitor that?
Old 05-24-2012, 04:10 PM   #33
You need a aeroforce gauge or some other a/f gauge.
Old 06-06-2012, 06:12 PM   #34
I just got back from JDM after getting my car tuned... I should say my old car bc she is a brand new car now. It's like she hit puberty. JDM was great, very knowledgeable with excellent service. I highly recommend them.
Old 06-06-2012, 08:43 PM   #35
coyote414's Avatar
Since you got a "dyno tune" did you manage to get before/after dyno numbers? That's what the people wanna know
coyote414 is offline   Reply With Quote
« Ford | Lowering »
06:01 PM
