CAI Gains - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 2010-2014 Mustang GT
Closed Thread
Old 05-14-2012, 04:00 PM   #1
RSW
RSW's Avatar
RSW is unknown around these parts
CAI Gains
Been wanting a CAI but I'm reading here that the gains are minimal... Any thoughts from those who have done it?
RSW is offline
Old 05-14-2012, 04:31 PM   #2
Rapinator126's Avatar
Rapinator126 is unknown around these parts
you will show gains on the dyno thats about it. they have almost been proved worthless on the new 5.0's except for airraid.
---------- Post added at 05:31 PM ---------- Previous post was at 05:31 PM ----------
they still look good though. my personal preff is the carbon jlt just for the "looks"
Rapinator126 is offline
Old 05-14-2012, 06:01 PM   #3
Woodga16 is unknown around these parts
Re: CAI Gains
you're the second person I've seen recommend stock or the airraid. JLT has proven little gains, but has the airraid proven SOME gains?
Previous: '02 GT, '04 GT, '07 GT & a few chevys in between
'13 GT
Woodga16 is offline
Old 05-14-2012, 06:13 PM   #4
yes jlt and the mass airflow readings it puts out why the perdormance is no good.
Old 05-14-2012, 06:17 PM   #5
Re: CAI Gains
I see, So air raid has proved some gains?
'13 GT
Woodga16 is offline
Old 05-14-2012, 06:26 PM   #6
at the track yes. in actually making the car faster.
they will all show on a dyno bc the hood is up. dyno only shows #s real performance will only be showed driving/ at the track
Old 05-14-2012, 07:57 PM   #7
GrayGhost's Avatar
GrayGhost is unknown around these parts
+1 for the Airaid CAI. Even with no-tune you could feel(and hear) the difference. Personally, I returned to the stock box because I thought air/fuel ratio may be slightly off. I was hoping it wasn't running too lean... if going that route, tune it!
2011 Mustang GT Premium 401A Spec- Sterling Gray, aka "Graycie", 6-Speed MT, 3.73, Brembo Brake Package, Current Mods: FRPP-Brakelines/Brake Ducts/Alternator/Radiator/Oil Pan/Oil Cooler/Trans.Scoop/Alum.Axle Cover, Steeda-Sport Springs/3rd Link/Adj.UCA/Alum.LCA/Rel.Brackets/Adj.PHB & Brace/Adj.F&R Swaybars/Adj.Front Endlinks/HD Strut Mounts/X11 Ball Joint/Bumpsteer/CAI, Koni Sport Shocks, ATI Damper, MGW Shifter, Kooks Catback, Wavetrac Diff, Michelin Pilot Super Sport... 93 Octane Performance Tune by VMP
GrayGhost is offline
Old 05-14-2012, 08:00 PM   #8
Re: CAI Gains
I thought the cai gains were debunked. That's why I asked. Thanks.
'13 GT
Woodga16 is offline
Old 05-15-2012, 10:43 AM   #9
GrayGhost's Avatar
I agree for the most part. I think the stock box is very good. Throttle response is pretty good. After I installed the Airaid, throttle response took a hit. If I re-install it, it would be after I decide on a tune...
Old 05-15-2012, 11:19 AM   #10
GE3G's Avatar
GE3G is unknown around these parts
Can u notice if the vehicle is running lean?
GE3G is online now
Old 05-15-2012, 11:30 AM   #11
GrayGhost's Avatar
I'm sure if you have a way of reading the air/fuel ratio, you will know... not waiting on any engine damage to occur.
Old 05-15-2012, 11:56 AM   #12
Terminator Owner
SpectorV is just getting started.
Re: CAI Gains
05+ GT's gain a good bit of power from a CAI with a tune is done at the same time. They gain far more than pre 05 GT's for sure.
SpectorV is offline
Old 05-17-2012, 08:36 AM   #13
Martinkid33's Avatar
Martinkid33 is unknown around these parts
Re: CAI Gains
Regardless of the type of CAI you put in, its always a good idea to tune your car. You will maximize the performance parts you are putting in. Investing in a $380 tuner w/free tunes for life makes it easy. Any parts you want to install after that, you already have the tuner so set it up and go. With CAI and a tune on the new 5.0's you should see "dyno" gains of around 20RWHP+. Anytime you can improve the way your car breathes and exhales its worth it
Martinkid33 is offline
Old 05-17-2012, 11:36 AM   #14
i would stay away from bama tunes they SUCK! go with jon lunds tunes they cost more but are bad ass
Old 05-17-2012, 11:49 AM   #15
Re: CAI Gains
There is a lot of hatred on some of these boards about BAMA. Did you have a bad experience with them?
Old 05-17-2012, 12:55 PM   #16
there hp gains suck compared to lunds tunes.
Old 05-17-2012, 01:34 PM   #17
Marshall2013's Avatar
Marshall2013 is unknown around these parts
I took my stang to a professional that only works on mustangs. I highly recommend finding the same type.
He went through on the dyno and adjusted the air fuel mixture. I have had no issues at all with the tune!
Marshall2013 is offline
Old 05-17-2012, 03:01 PM   #18
Senior Member
wnt2gofst is unknown around these parts
I recommend dyno tune also. But if just cold air its a waste. Once get boss/exhaust best idea completely
wnt2gofst is offline
Old 05-23-2012, 02:25 AM   #19
Senior Member
2011gt85 is unknown around these parts
Wrong. It has been proven over and over that a cai improves airflow an creates more power on the dyno and in real driving. Idk what anyone says I have seen the and done the tests myself an a cai is an improvement over stock for time slips and dyno sheets.
2011gt85 is offline
Closed Thread
cai
11:51 AM
