Fuse Panel Problems - Mustang Evolution
Old 05-15-2012, 08:31 PM   #1
Untamed5.0's Avatar
Fuse Panel Problems
No matter which fuse I plug my hot wire into, underneath the passenger kick panel, it always stays hot even after the car is shut off and locked. What gives?
Untamed5.0 is offline   Reply With Quote
Old 05-15-2012, 08:36 PM   #2
It's not me, it's you.
primer2tone's Avatar
Well, heres a thought. When you turn the car off and remove the key, all your accessories stay on for a certain amount of time or until the door is opened. It's got some kind of relay that keeps everything powered. So have you tried checking for ignition power with the keys out and the door open?
Old 05-15-2012, 08:41 PM   #3
Untamed5.0's Avatar
Well here's what I did; I ran a wire from the fuse labeled left low beam to the volt meter illumination bulb. It works! However when the low beams aren't on it's still on. When the car is turned off and I hit the lock button and the car honks its still on. 5 minutes after that when nothing is lit up or appears to be powered on, the volt meter illumination bulb is still lit up. It's got me puzzled.
Old 05-15-2012, 09:01 PM   #4
gtstyles2's Avatar
Are u running a hardwire for radar detector??
Old 05-15-2012, 09:03 PM   #5
Untamed5.0's Avatar
No radar detector at all
Old 05-15-2012, 09:24 PM   #6
NuckChorris's Avatar
Try running it to the radio fuse. Anytime I've ever installed speakers and an amp I use the radio fuse.
NuckChorris is offline   Reply With Quote
Old 05-15-2012, 10:08 PM   #7
11stangGT's Avatar
Region: Arkansas
What you should do is get a digital mutlimeter and test every fuse till you find one that gives you 12v when you turn the key on.. And then goes to 0v when the key is turned off.. Make sure headlights radio lights and all accessories are off while doing this... It's possible that one of those fuses will not work and then you will have to either check at fuse box under hood or find an acc/ignition wire by testing the same way..
---------- Post added at 11:08 PM ---------- Previous post was at 11:07 PM ----------
Which would be under steering column.. What are you hooking up again?
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 05-16-2012, 05:32 AM   #8
Untamed5.0's Avatar
I'm just hooking up an autometer volt gauge
---------- Post added at 06:32 AM ---------- Previous post was at 06:30 AM ----------
Tried that. Same thing happened. Like I said this is weird.
Old 05-16-2012, 02:56 PM   #9
Untamed5.0's Avatar
I found one! The fuse for the blower motor is the ticket! I WIN!
Old 05-16-2012, 03:05 PM   #10
DWC_SmOziLLa's Avatar
Congrats. That sounded like a cluster****.
Old 05-16-2012, 03:13 PM   #11
That's because the blower motor cuts off immediately when the key is turned off as opposed to staying powered up for a bit like the radio and windows do. I should've thought of that before.
Old 05-16-2012, 03:27 PM   #12
That's about the jist of what I said. The relay must be after the fuse block explaining why almost everything has constant power. :/
Old 05-16-2012, 05:45 PM   #13
11stangGT's Avatar
Region: Arkansas
It's called retained accessory power just FYI...
Old 05-16-2012, 07:56 PM   #14
Untamed5.0's Avatar
Smile Re: Fuse Panel Problems
Which just goes to show, we all learn something new every day. Thanks for the replies!
08:17 PM
