Just laid on a coat of wax on Kona blue - Mustang Evolution
Old 05-18-2012, 07:23 PM   #1
bellski's Avatar
I justlaid a coat of wax on my Kona Blue 2011 GT. I used Tuttle Wax Ice Synthetic Polish for the very first time and I am a believer. This stuff is amazing- goes on so easy and no white residue at all- you can (and should) use it on plastic and rubber surfaces as well as your paint- it is amazing- can't wait to see how long it lasts! Anyway here are 4 pics of my car- hope you like 'em.
ID:	50919   Click image for larger version
ID:	50922   Click image for larger version
bellski is offline   Reply With Quote
Old 05-18-2012, 07:36 PM   #2
Babystang's Avatar
Wow awesome looking stang man.
Babystang is offline   Reply With Quote
Old 05-18-2012, 07:37 PM   #3
kjunitalian's Avatar
Now thats nice
kjunitalian is offline   Reply With Quote
Old 05-18-2012, 07:46 PM   #4
Re: Just laid on a coat of wax on Kona blue
Verrryyy nice. Im gonna take some cues from you for my stang. What wheels are those? Any suspension lowering? How do you like those pop out rear windows?
I really like the look of the rear window louver, ive also got a gt500 style spoiler so i was curious about the mix with the louvers, looks great though!
the_stig is offline   Reply With Quote
Old 05-18-2012, 07:55 PM   #5
tbonz2869's Avatar
Looks great rims are ba
tbonz2869 is offline   Reply With Quote
Old 05-18-2012, 08:07 PM   #6
bellski's Avatar
The rims are Steeda Spyders, they are 9-1/2x20 front and 11x20 rear with 275/35 front and 315/35 rear Nitto Invos. The car sits on Eibach ProKit springs and ProDamper springs, struts and shocks. Rear window louvers are from MRT.
Old 05-18-2012, 08:36 PM   #7
Konawin's Avatar
Beautiful wax job on that Kona Blue!!!
Konawin is offline   Reply With Quote
Old 05-18-2012, 11:06 PM   #8
Tha twin's Avatar
Car is looking very clean
Tha twin is offline   Reply With Quote
Old 05-19-2012, 08:58 AM   #9
guzie's Avatar
What front end is on yours? I like the splitter. I too just started using the ice wax. Great stuff.
guzie is offline   Reply With Quote
Old 05-19-2012, 11:02 AM   #10
bellski's Avatar
Rousch grille, GT/CS fascia, MRT splitter
Old 05-19-2012, 12:16 PM   #11
Rmag's Avatar
Looks great. No rubbing or anything with the 11s in the rear?
Rmag is offline   Reply With Quote
Old 05-20-2012, 09:06 AM   #12
bellski's Avatar
Oh no, zero rubbing even tho my car is lowered. You would never know this rim/tire combo didn't come this way from the factory.
---------- Post added at 10:06 AM ---------- Previous post was at 10:00 AM ----------
Oh and also, the pop out rear windows are really trick- I like them but at $800 the kit is a bit pricey and the install is definitely not for the faint hearted. It is a well designed mod and they always draw attention at shows and even if it is just parked somewhere people ask me if they are factory. They are particularly nice if you are parked somewhere in the sun with the front windows up and the doors locked- keeps the black interior from getting too fricking hot...
Old 05-20-2012, 09:21 AM   #13
vinnygt's Avatar
The rear windows are awesome!!! I almost thought they were stock!
vinnygt is offline   Reply With Quote
Old 05-20-2012, 09:59 AM   #14
poloka's Avatar
315 on rear? I'm running Nitto NT555 285/30R20 on a 10.5. Told if I went wider I'd have to roll the fender. And you didn't? No spacer?
2011 GT 5.0 Supercharged Phase 2 TVS2300
http://www.mustangevolution.com/forum/f376/t290294/
poloka is offline   Reply With Quote
Old 05-20-2012, 10:36 AM   #15
11stangGT's Avatar
Region: Arkansas
Shouldn't.. A lot of it has to do w the offset of the wheel too
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 05-20-2012, 11:01 AM   #16
poloka's Avatar
Yeah, I wondered what the back spacing was.
Old 05-20-2012, 07:06 PM   #17
bellski's Avatar
315' on 11 rims- no clearance problems at all, no rubbing- the fit is perfect- no need for any spacers. I'm not sure what the backspacing on the rims is, but you could easily get that off Steeda's website.
315's on 11's look absolutely ba from behind- that's a bunch of rubber on the road.
BTW- no reason to roll the fenders- they are already rolled from the factory...
Old 05-21-2012, 04:02 AM   #18
I belive the offset for the rear steeda wheel is 59 mm.
El Fufi is offline   Reply With Quote
Old 05-21-2012, 09:26 AM   #19
poloka's Avatar
Hmm, I called Vossen on mine and they said the 9 was a 38 offset and the 10.5 wears 45.
Old 05-21-2012, 10:25 AM   #20
guzie's Avatar
If you want to see what will fit on the current rim you have just measure the space you have between the current tire sidewall and the vehicle body at its closest point. Now take the width you want say 315 and subtract the current tire width then divide that by 2. The resulting number is how much wider on each side it will be. Compare that to the gap you just measured on the car. You don't need to compare your rim offset to what he has. Measure your own car to be sure.
Old 05-21-2012, 10:30 AM   #21
poloka's Avatar
Sounds simple enough. My only concern is on compression will the top of the wheel well have a concave to it I may hit? Haven't really stuck my head in there to look if that is of concern.
Old 06-03-2012, 03:12 AM   #22
NAVYGUY's Avatar
Im grabbing some of that turtle stuff and tackling my kona next weekend. Thanks for the pics got me jazzed to really detail mine.
NAVYGUY is offline   Reply With Quote
Old 06-03-2012, 02:12 PM   #23
GE3G's Avatar
I started using this stuff and its great
GE3G is offline   Reply With Quote
Old 06-03-2012, 04:22 PM   #24
bellski's Avatar
Can you use that stuff on plastic trim, etc without leaving white residue?
Old 06-03-2012, 04:56 PM   #25
I tried the Ice and it seemed to streak ... I didn't like it on the paint. It looked awesome on the black plastic trim pieces ... hell it even looked good on the tires. But I went back to good ole' carnuba wax for the paint.
But if it works for you, great ... your pics look awesome.
---------- Post added at 06:56 PM ---------- Previous post was at 06:55 PM ----------
I was having a hell of a time keeping my deck lid looking good ... Ice did the trick. I used it on all the plastic.
mmike87 is offline   Reply With Quote
Old 06-03-2012, 04:58 PM   #26
bellski's Avatar
Yep, I have nO issues with it. Good stuff in my book!
08:28 AM
