5.0 oil squirters removed in some 2012 and all 2013 models? - Mustang Evolution
Old 05-20-2012, 12:12 PM   #1
guzie's Avatar
I read a couple different articles out there about Ford taking out the oil squirter hardware sometime in the 2012 production run and leaving them out. Ford originally put them in to spray the bottom of the non forged pistons in the 5.0. That was the reason they went with cheaper hypereutic pistons was that the oil squirters would keep them cooler. Now they all of a sudden don't need them? The motor may be fine stock without them but as soon as people start spinning them up hard into the higher rpm with a tune will we see some problems with it down the road? I know the boss has them deleted for windage issues at high rpms but they also put forged pistons in place of the standard ones. This would make me wary of putting a boss intake on a 2012 mid year or 2013 model GT and cranking the rpms up to 7500 where the boss intake comes on strong. I am glad I have them in mine. I even added the ford oil cooler that ford designed for them but skimped on and didn't install except for the boss cars. Oil cooling on these motors without forged pistons you would think would be vital.
guzie is offline   Reply With Quote
Old 05-20-2012, 12:24 PM   #2
the 2012 still have them The 13's don't.
Also didn't see a cooler for the squirters just for tranny for the boss. Autos came with tranny coolers stock.
Old 05-20-2012, 12:34 PM   #3
Rolltide's Avatar
So is this a good thing for 2011-2012 owners? And a bad thing for 2013s?
Rolltide is offline   Reply With Quote
Old 05-20-2012, 12:47 PM   #4
guzie's Avatar
Boss got engine oil coolers stock. They were originally developed for the gt but were cut for cost savings. They left in the design to be able to add them to he program as the bosses have.
Old 05-20-2012, 12:54 PM   #5
Depends..jpc deleted them in there 9 sec stroked out 5.0. Many have them in there cars that are running great. But I think once get to certain point need to be removed.
Old 05-20-2012, 12:56 PM   #6
Rolltide's Avatar
I see, so what is the purpose of them anyway?
Old 05-20-2012, 01:18 PM   #7
To cool the pistons as stated above
Old 05-20-2012, 01:20 PM   #8
Rolltide's Avatar
Im sorry for all the questions but if they cool the pistons isnt that a good thing? Why do people remove them?
Old 05-20-2012, 01:57 PM   #9
Cause they put forged internals in them.
Old 05-20-2012, 02:26 PM   #10
guzie's Avatar
The forged pistons can take the higher temps. High rpms generate a lot of heat. The non forged pistons without oil coolers can heat up to much potentially and that isn't good. Sounds like more penny pinching. The only reason ford took them off the boss was they found when spinning to 8000 rpm they had too much oil going up under piston and moving around in the crankcase. I don't like that they took them out of the gt. I am sure the gt didn't get forged pistons in place of them. They supposedly did this change during the 2012 production run. I will do more digging to find the related articles but I do think some 2012 are affected with this change.
Old 05-20-2012, 03:50 PM   #11
Rolltide's Avatar
Good info! Thanks
05:38 AM
