05-20-2012, 10:02 PM
#1 | | Registered User
| painted coil covers
I think about it all the time, I see the prepainted AM ones and they seem cool... but if course I don't want to pay $200 for them... so I was wondering where can I get the PQ Race Red paint can and what's the correct prepping and painting procedure on the coil covers... they're already rough on texture, would I need primer to give it a strong base??
__________________ |
05-20-2012, 10:15 PM
#2 | | Registered User
They're only like $90 I think but nonetheless you can paint your own for way cheaper.. I just lightly sanded mine and made sure they were clean using alcohol.. Then a few coats of paint and then a lil clear coat..
__________________ 2011 5.0
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
05-20-2012, 10:22 PM
#3 | | Registered User
| Quote: |
Originally Posted by 11stangGT They're only like $90 I think but nonetheless you can paint your own for way cheaper.. I just lightly sanded mine and made sure they were clean using alcohol.. Then a few coats of paint and then a lil clear coat.. | Yea I don't know anything about painting, but willing to give it a shot... but I wanna take my time and prep and paint correctly, what grit did u sand with? Did u use primer?
05-20-2012, 11:01 PM
#4 | | Registered User
| Quote: |
Originally Posted by gtstyles2
Yea I don't know anything about painting, but willing to give it a shot... but I wanna take my time and prep and paint correctly, what grit did u sand with? Did u use primer? | No primer.. I think I used like a 220 grit.. Then just a spray can of the color I wanted.. Do light coats so it doesn't run.. 15-30 min between coats.. Or instead of sandpaper you can use alcohol to clean them then go over them w adhesion promoter which comes in a spray can then your paint and clear
05-21-2012, 05:15 AM
#5 | | Registered User
| Re: painted coil covers
I washed mine with warm soapy water and let dry very good.Used a air hose to be sure all water was gone.Used engine High temp paint that is the correct blue color and then clear.Look like they came factory.Been on for 5 months and look like they did day one.
__________________  2012 Black Prem. w/ GB insert stripe/stitch , M6 , Brembo , 3.73 , 19" AMR Staggered Drifts, Stock Air-Box Club, 93-R Tune, Borla Catback w/ X-Pipe, FRPP-"K" Springs, BMR PH Bar, BMR Upper support brace, BMR Reloc. Brackets,"CHE" Lca's, Koni's Struts/Shocks, Jlt cc, Saleen grill, Hydrocarbon Center console and stereo surround, Formula One Tint, Video w/ Cam tune on: YOUTUBE: 2012 gt back n a stang
05-21-2012, 05:32 AM
#6 | | Registered User
| Quote: |
Originally Posted by 11stangGT They're only like $90 I think but nonetheless you can paint your own for way cheaper.. I just lightly sanded mine and made sure they were clean using alcohol.. Then a few coats of paint and then a lil clear coat.. | +1 that's what I did to make mine black
05-21-2012, 05:33 AM
#7 | | Registered User
Some pictures.
05-21-2012, 06:21 AM
#8 | | Do The Evolution
I didn't sand mine. I just scrubbed them with soapy water and then wiped them down with alcohol. After they dried, I sprayed one light coat (you could still see some grey) waited about 20 minutes. Then another light coat. I did four coats with a 20 minute dry time between. That was almost a year ago and they still look great.
05-21-2012, 08:00 AM
#9 | | Registered User
| Quote: |
No primer.. I think I used like a 220 grit.. Then just a spray can of the color I wanted.. Do light coats so it doesn't run.. 15-30 min between coats.. Or instead of sandpaper you can use alcohol to clean them then go over them w adhesion promoter which comes in a spray can then your paint and clear | O OK, last night I went on automotivetouchup.com and ordered the Race Red paint... but I got the primer gray which was probably unnecessary and also the clearcoat... I'm looking to get a smooth finish
05-21-2012, 08:03 AM
#10 | | Registered User
I didn't sand min either. Just cleaned them well, let em dry, primed and painted them Ford Blue. they look great, and you cannot tell they didn't come that way.
05-21-2012, 08:20 AM
#11 | | Registered User
| Quote: |
O OK, last night I went on automotivetouchup.com and ordered the Race Red paint... but I got the primer gray which was probably unnecessary and also the clearcoat... I'm looking to get a smooth finish | That should work!
05-21-2012, 08:56 AM
#12 | | Registered User
A quick question seeing as you guys know a few things about painting!.. What if I wanted to repaint a part that's already been painted?... Should I sand it all the way down?... Can I just paint on top of the old starting with primer?..
05-21-2012, 09:49 AM
#13 | | Registered User
| Quote: |
Originally Posted by Eturner A quick question seeing as you guys know a few things about painting!.. What if I wanted to repaint a part that's already been painted?... Should I sand it all the way down?... Can I just paint on top of the old starting with primer?.. | As long as the paint on there is good you should be able to primer then paint..
05-21-2012, 10:37 AM
#14 | | Registered User
| Quote: |
As long as the paint on there is good you should be able to primer then paint.. | Ok cool!.. I've got bit of a project that I'm about to take on and limited funds!.. Lol
05-21-2012, 06:42 PM
#15 | | Registered User
| Quote: |
Originally Posted by 11stangGT They're only like $90 I think but nonetheless you can paint your own for way cheaper.. I just lightly sanded mine and made sure they were clean using alcohol.. Then a few coats of paint and then a lil clear coat.. | The strutbar, is that plastidip? Or matte black paint?? Looks real clean that way
05-21-2012, 08:46 PM
#16 | | Registered User
| Quote: |
The strutbar, is that plastidip? Or matte black paint?? Looks real clean that way | Matte black paint.. Same thing there just lightly sanded then painted paint then clear..
05-22-2012, 07:30 PM
#17 | | Registered User
I used high temp paint on both. Just cleaned well for prep.
05-23-2012, 01:02 AM
#18 | | Senior Member
I just cleaned with soap and water and painted with a high temp engine paint. Holding up great.
