05-21-2012, 02:25 PM
#1 | | Registered User
| Tune from SCT question?
I had a 2012 Mustang GT 5.0 with a SCT TUNE AND COLD AIR INTAKE!!! My question is.... Will that tune for a 2012 5.0 work on a 2013 GT 5.0 with out having to have it reprogrammed , or can I download it to the 2013 with no problems!! Any help would be great!! Thanks!!!!!
05-21-2012, 02:37 PM
#2 | | Registered User
| Re: Tune from SCT question?
going to need a reprogram, each car has unique identifier
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
05-21-2012, 11:51 PM
#3 | | Registered User
Can I do that by just getting in touch withSCT ---------- Post added at 12:51 AM ---------- Previous post was at 12:49 AM ---------- And give them the info off the 2013? Also can I take a tune off a 2012 GT5.0 and put onto another 2012 GT5.0??
05-22-2012, 05:10 AM
#4 | | The Blue Dragon
I would not try to use the same tunes on any 2 cars. Like previously mentioned, tunes are specific to each car and could mess something up if you try to reuse a tune on a diff car.
05-22-2012, 06:40 AM
#5 | | Evolution's Finest
Ecu software versions play a role in this as well. It is not good practice to use the same tune on two separate vehicles of two different years based on the fact you have no idea how Ford modified their electronic sensors and diagnostics for throwing CEL codes. The other thing is that in the last two years their are at least five different software versions running around on mustang computers. I have one of the early addition 2011s had to have my crank sensor reset in which they also updated my software. After that I had to contact John Lund to build me a new tune for that software version.
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence) |
05-22-2012, 07:07 AM
#6 | | Registered User
I think that we need a bit more information before answering your questions ...
Which CAI are you running and does it require a tune?
If not, are you running a custom tune or the canned tune on the SCT?
__________________ |
05-22-2012, 07:09 AM
#7 | | Registered User
yes contact bama tunes, or whoever created the tune files
work in progress...
05-22-2012, 10:52 PM
#8 | | Registered User
It's a time from JLT with CIA and tune on a SCT hand held tuner.. Good for 2011 & 2012 Mustang 5.0!! A package deal!!! Hope that helps!!
05-23-2012, 12:01 AM
#9 | | Registered User
| Quote: |
Originally Posted by Tominkc It's a time from JLT with CIA and tune on a SCT hand held tuner.. Good for 2011 & 2012 Mustang 5.0!! A package deal!!! Hope that helps!! | You will need to send jlt the new strategy code from your ecu and have them update the tune. Should be the same process you went through when you ordered it.
I've never ordered tunes from jlt so I can't help you on the specifics of this.
05-23-2012, 11:01 PM
#10 | | Registered User
Thanks for all the help!! Means alot to me!!!!
