2013 (another TPMS) flat tire question / thought / boo on the goo! - Mustang Evolution
Old 05-25-2012, 10:01 AM   #1
I am wondering if any 2013 owners have had flats and used the inflator/green slime kit. I ask this as I imagine the goo would foul up the TPMS sensor, and doing so, the TPMS sensor is/is not covered by Ford? OR, is the included slime "safe" for TPMS? I remain skeptical. I am fixing to order a 2013 GT with Brembo and am wondering if I should factor in a rim/spare tire as well. Seems like a no-win solution to me!
Twinarrow99 is offline   Reply With Quote
Old 05-25-2012, 11:13 AM   #2
bigsmitty24's Avatar
Not sure about the 13 but I used my pump on a friends car. It SUUUUUXXXX. If i had the room I would definitely get the spare. Probably the worst thing I've found with my Brembo package.
bigsmitty24 is offline   Reply With Quote
Old 05-25-2012, 01:41 PM   #3
Napoleon85's Avatar
Re: 2013 (another TPMS) flat tire question / thought / boo on the goo!
Don't use it, you'll be on the hook to get a new TPMS sensor and get all the gook cleaned off before mounting a new tire.
Old 05-25-2012, 04:28 PM   #4
fordfan100's Avatar
The 13's come standard with a spare tire. The pump is a option. At least that is what I have seen on the order form
fordfan100 is offline   Reply With Quote
Old 05-25-2012, 05:04 PM   #5
poloka's Avatar
If you have the pump stay away from the goo. If you use it you have to replace tire and TPM. If just a nail you can get a patch for $15. But if in the middle of nowhere you do what you gotta.
2011 GT 5.0 Supercharged Phase 2 TVS2300
http://www.mustangevolution.com/forum/f376/t290294/
poloka is offline   Reply With Quote
Old 05-25-2012, 05:33 PM   #6
thanks all for your responses. The 2013 GT Premium w/Brembo I drove did not have a spare - did have the pump - appeared to have the standard well for a spare. I think I will procure a spare tire/rim and ditch the pump. Pump and goo would be useless with a blowout anyway...
Old 05-25-2012, 09:19 PM   #7
guzie's Avatar
Spare doesn't fit over brembo brakes. They give you the pump with fix a flat instead.
guzie is offline   Reply With Quote
Old 05-26-2012, 10:06 AM   #8
poloka's Avatar
True. I have a friend that found a stock wheel/tire someone was selling and put in the trunk just laying partial in wheel well for extended trips. Local he figured he could get it if needed. It's what I do. I got aftermarket wheels but kept original in basement in case I need one.
Old 05-26-2012, 10:20 AM   #9
It's not me, it's you.
primer2tone's Avatar
Did you jack the tire up off the ground first? I used the pump to air up my f150's tire and it worked great!
Old 05-26-2012, 12:09 PM   #10
poloka's Avatar
I've aired up my wife's tire when on ground and did just fine.
Old 05-26-2012, 12:30 PM   #11
Region: Oregon
Thanks everyone for the input. My Boss came with the pump, no other option available. AAA here I come.
Terrell is offline   Reply With Quote
10:16 AM
