jegs wheels - Mustang Evolution
Old 05-28-2012, 11:52 AM   #1
12stang's Avatar
jegs wheels
Does anyone know if the jegs sport II wheels fit on 2012 gt with brembo pkg on back. Specs are 15x8 5.5 bs. They r only 126 per wheel.
12stang is offline   Reply With Quote
Old 05-28-2012, 11:55 AM   #2
DaBluedude's Avatar
15" rim on a s197. Haha. Bad combo there. No they will not come even close to fitting. Your brakes are 13.x" I think the stockers are 19s aren't they???
2003 Mach 1
Old 05-28-2012, 12:19 PM   #3
12stang's Avatar
Haha that is funny considering they would be for the back only and for when i take to the track. Silly me i forgot mustangs are to just to drive around town and look good. I dont know what those guys at brenspeed and american muscle are thinking using 15" racestar wheels at the track. By the way the rotors r 14" in the front and 11" in the back.
Old 05-28-2012, 12:24 PM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
Pretty sure brembos still have the same rear brakes, and rear rotors are NOT 13.xx inches either
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 05-28-2012, 01:08 PM   #5
DaBluedude's Avatar
Then say your looking for rears only. If you want to get all defensive and moody over something go pick a fight with your significant other. If u just want rears go ahead. Although if you want to put any traction down I recommend wider than an 8inch wide rim... which is why I assumed that you were looking for a cheap set all around.
Oh, welcome to the site...
---------- Post added at 12:08 PM ---------- Previous post was at 12:03 PM ----------
Ford calls them 14" the one I just measured was 13.9x" allowing for a little error. I'm happy to say 14" for wiggle room. Either way its splitting hairs.
2003 Mach 1
Old 05-28-2012, 01:15 PM   #6
The Blue Dragon
11.8 inch rear rotors on brembo and non brembo
Old 05-28-2012, 01:52 PM   #7
Re: jegs wheels
15" rims fit in the rear. 15x8 will fit stock easy. 15x10 needs swaybar relocation brackets. for the 15x8 you ned a 5.5 back space. For 15X10 you need a 7.5 backspace.
For fronts you can do a 17". But if have brembo's have to get the Weld rims that are made for it. If willing to swap brakes to a 05-10 model you can fit 15's up front also.
I run 15'' rims all around when go to track.
Old 05-28-2012, 02:39 PM   #8
12stang's Avatar
Thanks for the input everyone. I wasnt tryin to be defensive dablue just didnt understand why u thought it was funny. But thanks again for the input
07:04 PM
