Lowering - Mustang Evolution
Old 06-05-2012, 11:41 AM   #1
CoyoteAce's Avatar
Lowering
I want to lower my 2013 mustang gt w/ brembo package. I want to go with the steeda sport springs. I was also going to pick up and adjustable panhard bar. I didn't want to get shocks at the moment (trying to stay in a budget) I most likely will a few more thousand miles down the road. Is anything else a must have or will I be fine with the springs and the adjustable panhard bar?
CoyoteAce is offline   Reply With Quote
Old 06-05-2012, 01:26 PM   #2
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
You may want to look at control arms. Rear upper and rear lower control arms will be about 350 total. Another thing is when you lower your car you might be interested in new a arms for your front because they make a set of a arms that are specifically designed for lowered mustangs that maintain minimal stress on your ball joints and easier to keep the tire flat to the road. Increases handling and those will run you about 400 bucks from bmr. I am personally looking at steeds anti sway bars and new mounts.
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 06-05-2012, 01:33 PM   #3
CoyoteAce's Avatar
Re: Lowering
Are these needed, or highly recommended?
Old 06-05-2012, 01:36 PM   #4
They are not needed. For the front really all you need is camber bolts. Panhard will fix biggest rear issue of tires not being centered.
But all are really recommended and just make the suspension better.
Old 06-05-2012, 01:37 PM   #5
gregtommy's Avatar
They are recommended I lowered my car 10 months ago and have been going without them for awhile now
MOTM DEC 2011
Old 06-05-2012, 01:42 PM   #6
CoyoteAce's Avatar
Re: Lowering
When you lowered your car, did you just use the lowering springs and panhard bar?
Old 06-05-2012, 01:51 PM   #7
I did on both mine.
Old 06-05-2012, 01:55 PM   #8
gregtommy's Avatar
Just the springs. Pan handle bar will be done sometime soon.
MOTM DEC 2011
Old 06-05-2012, 03:19 PM   #9
CoyoteAce's Avatar
Re: Lowering
Originally Posted by wnt2gofst View Post
I did on both mine.
Do you have the steeda springs, if so how does it ride?
Old 06-05-2012, 07:04 PM   #10
I have eibach sportlines. Ride is good. Not to ridged or bouncey. Just don't allow enough weight transfer for me.
Old 06-05-2012, 07:12 PM   #11
NAVYGUY's Avatar
Re: Lowering
Is it easy enough a novice can do it? Or buy the parts and have a pro install them?
NAVYGUY is offline   Reply With Quote
Old 06-05-2012, 07:31 PM   #12
Its pretty easy. Rear is super easy. Fronts a little harder but you just rent a spring compressor from auto zone to do fronts. Me and buddy did my fronts in about 2 hours taking our time and drinking some beer and cig breaks.
Old 06-05-2012, 07:39 PM   #13
11stangGT's Avatar
Region: Arkansas
It's not too bad really but I do this kinda thing for a living.. And if you go to LMR they have instructions so that you do not have to use a spring compressor.. Easier than using one and less dangerous lol
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 06-05-2012, 07:52 PM   #14
MarkUA322's Avatar
Re: Lowering
I have steeda sports and have adjustable panhard bar but didnt have to adjust it so if you want to wait you should be fine. The ride is so much better than stock it is amazing and i havent even replaced stock shocks.
MarkUA322 is offline   Reply With Quote
Old 06-05-2012, 09:11 PM   #15
gregtommy's Avatar
Make sure you get a front end alignment when it's finished as well.
MOTM DEC 2011
Old 06-06-2012, 04:17 AM   #16
NAVYGUY's Avatar
Re: Lowering
Speaking of shocks, when is a good time to replace them? I've seen recommended intervals, but I've never changed any shocks in any of the 14 cars I've owned over the years.
Old 06-06-2012, 06:16 PM   #17
BossFiveOh's Avatar
I have the eibach prokits and love them once they break in and settle they sit very nice.
BossFiveOh is offline   Reply With Quote
Old 06-08-2012, 09:43 PM   #18
Re: Lowering
I would recommend the Steeda Ultra lights over the Sports. The ford Factory dampers on the Brembo cars are tuned differently than the standard GT and seem to work well with the Steeda set up. The drop is not as severe so camber bolts are not really needed.
2012 Ingot Silver Brembo GT 5.0
Suspension and CAI by Steeda
Custom Tuned by Brenspeed
Wheels by TSW
Exhaust by Magnaflow
vista6019 is offline   Reply With Quote
07:14 PM
