Heading to the Track. - Mustang Evolution
Old 06-15-2012, 09:28 AM   #1
CoyoteAce's Avatar
I'm heading to the track again today. I couldn't get off the line last week. I bought some lower control arms and installed them yesterday. I also was considering lowering the tire pressure a little. (I have the brembo package). Any recommendations of what I should lower it to or anyother recommendations?
CoyoteAce is offline   Reply With Quote
Old 06-15-2012, 09:58 AM   #2
GE3G's Avatar
Warm those tires up... Street tires are very difficult to hook up with dont lower pressure cause i think they ate nitrogen filled
GE3G is offline   Reply With Quote
Old 06-15-2012, 10:18 AM   #3
11stangGT's Avatar
Region: Arkansas
Only if they have a green valve stem cap.. Which I haven't seen one yet.. I would just lower it 5-10lbs.. Somewhere in there
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 06-15-2012, 10:26 AM   #4
CoyoteAce's Avatar
Re: Heading to the Track.
Ok, I'll do that, do you know the tire pressure from the factory?
Old 06-15-2012, 10:46 AM   #5
SilverBullet12's Avatar
I ran my street tires and had them probably unsafe low, around 15-18 lbs i think. I cut a 1.8' 60' doing that. what track you going to??
SilverBullet12 is offline   Reply With Quote
Old 06-15-2012, 11:26 AM   #6
CoyoteAce's Avatar
I'm heading to capital raceway, in crofton md.
Old 06-15-2012, 12:18 PM   #7
The P Zeros hook best at really low pressure, 10-15 pounds...they'll still suck, even there.
Who cares if they're nitrogen filled? So is the air outside, a few % less nitrogen isn't going to do jack. Just pump 'em back up with good old-fashioned air, they'll be fine
Old 06-15-2012, 12:45 PM   #8
As above heat them up good. And don't be scarred to lower tire pressure. Start with a easy launch around 1000rpms slipping the clutch. If hooks then you can get more aggressive with the launch.
Old 06-15-2012, 12:47 PM   #9
11stangGT's Avatar
Region: Arkansas
Its in the inside of your driver door jamb.. Can't remember if it's 30 or 35lbs... I personally wouldn't go below 20lbs myself just bc the tires and wheels are not really meant for it..
Old 06-15-2012, 01:37 PM   #10
CoyoteAce's Avatar
I appreciate all of the suggestions. This is my mustang, and first rear wheel drive car, so I'm just trying to figure things out. My neighbor has an Evo x and I eat him up on the street everytime even giving him a head start, but t the track last week he got me, cuz i could t get off the line, so he's all talkin sh$t now. I told him anyone can drive an awd car.
Old 06-15-2012, 01:58 PM   #11
He can launch a lot easier. Tires can fix that though for you.
Old 06-15-2012, 02:27 PM   #12
CoyoteAce's Avatar
Yep, after I install my steeda lowering springs and adj. panhard bar, the racestars and some slicks will be my next investment.
06:46 PM
