Aeroforce Interceptor Gauges Install Question - Mustang Evolution
Old 06-18-2012, 05:42 PM   #1
bellski's Avatar
I just installed a set of the dual Aeroforce Interceptor gauges in a dual piller mount in my 11 GT. Everything went well with the install, except that they stay on when the ignition key is shut off, and just flat do not shut off. I am assuming that I need to utilize the included 3 connector cables and wire the red wires to a switched 12V source. Can anyone confirm this please?
Thanks
bellski is offline   Reply With Quote
Old 06-18-2012, 05:47 PM   #2
NuckChorris's Avatar
Try wiring to a 12v power source that cuts off with the key. Like the blower motor
NuckChorris is offline   Reply With Quote
Old 06-18-2012, 05:48 PM   #3
bellski's Avatar
Re: Aeroforce Interceptor Gauges Install Question
yeah, that's what I meant. Did you do this on yours?
Old 06-18-2012, 05:56 PM   #4
I don't have them. But I have wired up a lot of other stuff that were similar. If you wire them to a source that's killed when the key is turned off you should be ok. Just remember a lot of things on this car have sustained power like the radio/windows that hold power for a bit after the key is off. The blower motor is killed instantly from what I remember. So that should be a good source.
Old 06-18-2012, 06:07 PM   #5
bellski's Avatar
Just did it. Same problem- won't shut off
Old 06-18-2012, 06:12 PM   #6
Do you have a test light or multi meter to check the source you're hooked into to make sure it's dead with the key off?
Old 06-18-2012, 06:18 PM   #7
They should plugged right into the obd2 port. Mine did
Old 06-18-2012, 06:45 PM   #8
They obviously plug into the obdll port lol but the problem is the port still gets power even when the key is off.
---------- Post added at 06:45 PM ---------- Previous post was at 06:42 PM ----------
Guys on another forum I am on have said there's do this as well but will shut off after so many minutes.....
2011gt85 is offline   Reply With Quote
Old 06-18-2012, 06:48 PM   #9
If they're getting their power from a source that's dead with the key off then they should die immediately.
Old 06-18-2012, 06:52 PM   #10
I don't think the other wires are for getting power but used for adding other sensors....the obdll port is still providing the power.
Old 06-18-2012, 06:52 PM   #11
bellski's Avatar
If the obdII port is always on, then how would wiring a power line to a switched source help me? Will that override the "always on" power of the obd port???
Old 06-18-2012, 06:57 PM   #12
If the obdII port is always on, then how woyld wirung a power line to a switched source help me? Will that override the @alwatys on" poer of the obd port???
I don't think it will...the other wires aren't for power. And the obdll port isn't always on, it stays on for a bit but then shuts off. Guys have said it stays on for like 10 mins and shuts off and will randomly turn on again and off all while the key is off. Never drains the battery though, some guys have just unplugged it when the car is off and plugged it back in when needed to stout from coming on and off.
Old 06-18-2012, 06:57 PM   #13
If it's hooked to the obdII and that's where it's getting it's power then it'll stay on until that source has no power.
Old 06-18-2012, 06:59 PM   #14
bellski's Avatar
Hmm, well i think i will leave it plugged in overnight and see if it stays on
Old 06-18-2012, 07:00 PM   #15
Leave it plugged in and check on it like every 15 mins and see how long it stays on for.
Old 06-18-2012, 07:01 PM   #16
It should shut off after you pull the key out. That is how mine is. If I open door it will make my gauge flash. Mine take a min or so to power down after shutting car off.
Old 06-18-2012, 07:53 PM   #17
avengnd's Avatar
Yep plug and play and take a few to turn off. You shouldn't have to use any other wires unless your doing boost or something like that.
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 06-18-2012, 08:14 PM   #18
bellski's Avatar
Just went out to the garage to check. After 15 minutes with the ignition off the gauges are still lit
Old 06-18-2012, 08:41 PM   #19
Then something might be wrong with the gauges. Did you open the door to check them?
Old 06-18-2012, 08:43 PM   #20
bellski's Avatar
Nope, i am peeking thru the passenger window
Old 06-19-2012, 04:13 AM   #21
avengnd's Avatar
Do you have the connection right in the rear of the gauges? Seems strange I would think something is wrong with them as wtn2gofst mentioned.
2014 Shelby GT500
Old 06-19-2012, 05:24 AM   #22
bellski's Avatar
There is actually only one way that the cable plug will connect with the gauges
Old 06-19-2012, 05:34 AM   #23
avengnd's Avatar
Very true. I just know there is a couple of other slots in the back of them. Hopefully you just got a bad set and they can send you out a new one.
2014 Shelby GT500
Old 06-19-2012, 05:59 AM   #24
bellski's Avatar
I just sent an email to Aeroforce's service email address and posted on their in-house forum. Let's see what I find out...
Old 06-19-2012, 06:07 AM   #25
avengnd's Avatar
cool...good luck.
2014 Shelby GT500
Old 06-19-2012, 08:03 AM   #26
bellski's Avatar
Finally got it figured out (and do I feel like a dumb s***). Turns out, while you are in Setup mode the gauges stay powered. Once you finish with Setup and go into Scan mode they operate in synch with the ignition switch. Glad I got that figured out- thank goodness for the online User Manual that I downloaded, the instructions that came with the gauges are crap...
Old 06-19-2012, 09:06 AM   #27
Good deal man. You're not the 1st person I've heard say the instructions sucked to download the online manual either.
Old 06-19-2012, 02:03 PM   #28
avengnd's Avatar
Awesome!! Yeah they are crap, and it isn't like the ones online are much better.
2014 Shelby GT500
Old 06-19-2012, 02:08 PM   #29
bellski's Avatar
amen brother!
2011 GT M6 Premium- Mechanical upgrades include: Boss 302 Intake, JLT CAI, JPC LT Headers, Off Road X Pipe, and mufflers, 410 Gears, Granatelli Hot Street Coil Packs, 93 Octane Ghost Cam Tune by Jon Lund,Eibach ProKit Springs,shocks, struts and sway bars, BMR LCA's, Strut Tower Brace, and adjustable Panhard Bar, Maximum Motorsports Camber/Caster Plates, Barton Shortshifter and bracket, Wilwood Superlight Brakes w/6 and 4 piston calipers, Steeda Spyders- 9-1/2X20 with 275/35 and 11X20 with 315/35 Nitto Invos.
Old 06-19-2012, 02:16 PM   #30
Gibby's Avatar
Post a pic of the gauge and how you have it mounted. I'll be ordering one soon.
Gibby is offline   Reply With Quote
Old 06-19-2012, 03:07 PM   #31
avengnd's Avatar
I have some pics here of mine mounted. Curious to see how others are doing it if differently.
Aeroforce Gauges
2014 Shelby GT500
Old 06-19-2012, 09:09 PM   #32
bellski's Avatar
Here is a pic of mine mounted- glare from the flash makes the faces look silver but they actually are black
Old 06-20-2012, 03:45 AM   #33
avengnd's Avatar
Looks good.
2014 Shelby GT500
Old 06-20-2012, 01:25 PM   #34
bellski's Avatar
OK- more Aeroforce venting here- as I said above, I got them mounted, programmed and all is good there. Today I thought I would look through the owners manual I downloaded to see how I can program one of the gauges so that the red lights work as a shift light. I know this can be done, but that doggone owners manual is written in fricking Greek! Very frustrating...
Old 06-20-2012, 04:47 PM   #35
Struego's Avatar
Will this gauge display engine hp or torque?
Struego is offline   Reply With Quote
04:15 AM
