Help with 1st 1/4 mile runs - Mustang Evolution
Old 06-19-2012, 11:54 AM   #1
Mustangreazon50's Avatar
Know this will be a pretty rookie question, but I've gotten plenty different answers on it. I'll be going to the track in about a week and I'm totally new at this. What gears should I pull off in? Should I go normal (1st,2nd,3rd)? Should I pull off in 2nd? Or should I pull off in 1st, skip 2nd and go straight to third? I have a 2012 base gt and I'm completely stock performance wise so I'm not expecting the greatest numbers (since I'm completely new) tips also would be appreciated. Thanks
Mustangreazon50 is offline   Reply With Quote
Old 06-19-2012, 12:55 PM   #2
DaBluedude's Avatar
1-2-3-4 fifth if u need it. No need for a big burnout on stock rubber. Launch low... ~3k rpm... don't dump the clutch, roll out of it. shift quick. have fun. Expect something in the mid to high 13s. Until you get ur launch sorted out.
2003 Mach 1
Old 06-19-2012, 12:55 PM   #3
SilverBullet12's Avatar
Re: Help with 1st 1/4 mile runs
Well first off, you're going to the track, welcome to your new addiction!! haha
I would suggest shifting normal. Dont try and launch the car for the first couple times just roll off the line. Once you get used to it get the tires nice and hot and launch at 2000-2500. I did that and cut a 1'8 60' so its def possible get a good 60' on the stock tires. Dont try and kill it the first time out there and ignore the car next to you, even saying your in a 12' gt chances are theyll be behind you haha. What gears do you have?
SilverBullet12 is offline   Reply With Quote
Old 06-19-2012, 01:25 PM   #4
Above. Launch easy first. Heat the tires real good. Least 5 second burn out. Then launch around 1200rpms to start. Side stepping or slipping the clutch.
Old 06-19-2012, 02:33 PM   #5
Black5.0's Avatar
And leave on the last yellow light. Do not wait for green!
Black5.0 is offline   Reply With Quote
Old 06-19-2012, 03:00 PM   #6
If was racing some one I would agree. But while just practicing it don't matter. Reaction time don't hurt ET.
Old 06-19-2012, 03:11 PM   #7
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
+1 leave as late as you want on the line, the time doesn't start until you are rolling through the beams
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 06-19-2012, 03:14 PM   #8
Black5.0's Avatar
I'm aware, just giving a tip to a first timer if, obviously, he's trying to win the race. See TONS of street cars guys leavin way too late.
Old 06-19-2012, 03:22 PM   #9
He is going for the first time. He needs to.practice before worrying about jumping the light. That is a common mistake people do first time and blow the tires off. Unless its a event of some kind just practice. Who cares about car next to.you.
Old 06-19-2012, 03:39 PM   #10
Black5.0's Avatar
Anyone who wants to win
Old 06-19-2012, 03:39 PM   #11
Your missing the point...
Old 06-19-2012, 03:44 PM   #12
Black5.0's Avatar
No dude, I'm not. I understand it's his first time out. I understand he needs to get a feel for his car, practice his launch. I too drag race, not just you. I'm just giving a tip I learned. He doesn't have to try and cut a good light right off the bat but he can use it down the road. It's just a heads up.
Old 06-19-2012, 08:48 PM   #13
I think I have 3.73 I looked when I first got the car and haven't looked since. Thank u for all the tips, they are awesome please keep em coming.
Old 06-19-2012, 08:58 PM   #14
Lorraine's driver
ab_mach1's Avatar
+1
---------- Post added at 10:56 PM ---------- Previous post was at 10:51 PM ----------
I would concentrate on the launch first and not worry about the reaction time. The 60ft will be the toughest.
---------- Post added at 10:58 PM ---------- Previous post was at 10:56 PM ----------
Concentrate on making the shifts first, them work on speeding up as you get more runs
Instagram: @ab_mach1
09:45 AM
