2010 gt vibration - Mustang Evolution
Old 06-19-2012, 10:11 PM   #1
Brian Reynolds's Avatar
2010 gt vibration
Anyone heard of a vibration in the drive train . Happens between 60-70 mph slightly off the gas ? I just road forced balanced all four tires and still there.
Brian Reynolds is offline   Reply With Quote
Old 06-19-2012, 10:18 PM   #2
Struego's Avatar
Any other changes to the vehicle since the vibrations started? Where do you feel the vibrations the most at those speeds?
Struego is offline   Reply With Quote
Old 06-19-2012, 11:12 PM   #3
Project66's Avatar
Have you takin it to ford yet?
Project66 is offline   Reply With Quote
Old 06-20-2012, 04:40 AM   #4
No other changes, feels like under the car like possibly driveshaft area .
---------- Post added at 04:40 AM ---------- Previous post was at 04:27 AM ----------
No not yet. Just wanted to know if this was something common before I take it in the dealer
Old 06-20-2012, 05:05 AM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
Not common, take it to dealer
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-20-2012, 07:29 AM   #6
Napoleon85's Avatar
Re: 2010 gt vibration
Could be anything really. If you feel it mostly in the seat and not in the controls then it's usually an issue with the rear. The front will give you more vibrations in the steering and such.
It could be an issue with uneven tire wear, a bent wheel on the rear, poor balancing job (I had a bad vibration on my car that Ford couldn't/wouldn't fix when I bought it and just taking it to a better shop fixed it). Could even be a rock in the tire tread ...
On to the more unlikely stuff, could be an unbalanced driveshaft or bent axle, but that's pretty unlikely and you would have noticed it before or have done something to cause it.
Old 06-20-2012, 09:45 AM   #7
wheel weights, or out of balance wheels (or out of round). Could be driveshaft as well etc.
Old 06-20-2012, 11:11 AM   #8
Struego's Avatar
What speeds? Does iger worse with higher speed or go away?
Possible bad u-joint
Old 06-20-2012, 11:58 AM   #9
Ucfknight's Avatar
I'm regularly between 80 and 100 with no vibrations. Hopefully ford will solve this for u.
Ucfknight is offline   Reply With Quote
Old 06-20-2012, 09:32 PM   #10
Blogger
99ford's Avatar
Mine freaking does that. I took it to Ford several times, and they couldn't solve the problem.
Old 06-20-2012, 09:42 PM   #11
Jukens's Avatar
My whole car would vibrate at 65+. Ended having 2 bent rear axles.
Jukens is offline   Reply With Quote
Old 06-20-2012, 09:47 PM   #12
It's not me, it's you.
primer2tone's Avatar
My money's on the driveshaft or wheels.
Old 06-24-2012, 07:18 PM   #13
Blogger
99ford's Avatar
I bet wheels. Mine does it. Now it's starting to pull to one side. Agh!! 2 freaking Ford dealers said nothing is wrong with it. I know your frustration, I'd just keep taking to Ford till they get tired of you. it just takes time and patience which I don't have a lot of.
03:25 AM
