06-26-2012, 09:42 PM
#1 | | Registered User
| Leathal prefirmance off road x pipe
Is it a direct bolt up? Or will I need to have it welded in?
2012 GT 5.0
6speed manual
flowmaster super 10's
lethal performance o/r x pipe
BAMA sct tuner
35% tint all the way round |
06-26-2012, 10:35 PM
#2 | | Senior Member
Bolts right up. No welding needed.
06-26-2012, 10:41 PM
#3 | | Registered User
| Quote: |
Originally Posted by wnt2gofst Bolts right up. No welding needed. | Thank you sir...is the one side have clamps? I see the Bolt holes on the other side
2012 GT 5.0
6speed manual
BAMA sct tuner
06-27-2012, 12:08 PM
#5 | | Registered User
| Quote: |
Originally Posted by Boomer | It did very much so thank you
2012 GT 5.0
6speed manual
BAMA sct tuner
06-27-2012, 12:33 PM
#6 | | Registered User
| Re: Leathal prefirmance off road x pipe Quote:
Originally Posted by medicespo It did very much so thank you | No problem!
06-27-2012, 04:21 PM
#7 | | Registered User
I have lethal performances x pipe and didnt like it. It is the cheapest on the market though.
06-27-2012, 04:27 PM
#8 | | Registered User
| Quote: |
Originally Posted by Yellow50 I have lethal performances x pipe and didnt like it. It is the cheapest on the market though. | Why didn't you like it? Wana sell it?
2012 GT 5.0
6speed manual
BAMA sct tuner
06-27-2012, 05:17 PM
#9 | | Registered User
It's currently welded into my exhaust system so that's not possible.
Pros- lighter than stock cats
- hasn't rusted yet
-direct bolt on
Cons- looks like a two year old welded it together-biggest gripe
-metal scraps still in exhaust
-Oil all over pipes when I got it
I cleaned the pipes in the parts cleaner, then dried it off and welded the point where the two halfs of the X meet
06-30-2012, 09:09 PM
#10 | | Registered User
Any tips for the install?
2012 GT 5.0
6speed manual
BAMA sct tuner
07-01-2012, 08:33 PM
#11 | | The Blue Dragon
I have the lethal offroad x and had very little issue with mine. Only problem was bolts given to me for the one side that needs to be bolted (drivers side?) weren't long enough and I had to get my own.
Tips - PB blaster or something similar and lots!! (Bare minimum 2ft of extensions, I used probably 3) to get the passenger side cats bolts out.
07-01-2012, 08:36 PM
#12 | | Registered User
| Quote: |
Originally Posted by GrabberBlue5.0 I have the lethal offroad x and had very little issue with mine. Only problem was bolts given to me for the one side that needs to be bolted (drivers side?) weren't long enough and I had to get my own.
Tips - PB blaster or something similar and lots!! (Bare minimum 2ft of extensions, I used probably 3) to get the passenger side cats bolts out. | Thank ya.... Anything helps I will be doing this when I get back from vacation I am hoping it will sound good with the flow master super 10's I think it is going to be quite loud
2012 GT 5.0
6speed manual
BAMA sct tuner
07-01-2012, 10:03 PM
#13 | | Registered User
| Quote: |
Originally Posted by Yellow50 It's currently welded into my exhaust system so that's not possible.
- hasn't rusted yet
-direct bolt on
I cleaned the pipes in the parts cleaner, then dried it off and welded the point where the two halfs of the X meet | So all the issues with it came from the installer and not the part itself
2008 4.0 SOLD (I will miss my first stang forever)
2011 5.0 black on black with 3.73 manual  and I still get over 26 mpg
07-01-2012, 10:06 PM
#14 | | Registered User
| Quote: |
Originally Posted by stangaroo
So all the issues with it came from the installer and not the part itself | Deff good to know haha
2012 GT 5.0
6speed manual
BAMA sct tuner
07-03-2012, 09:18 AM
#15 | | Registered User
| Quote: |
So all the issues with it came from the installer and not the part itself | How are the issues from the installer??? I didn't weld the pipes now did I? My exhaust shop does a great job compared to this X pipe which wasn't welded professionally or cleaned up.
It was easy to install all my bolts lined up fine
07-03-2012, 10:37 AM
#16 | | Registered User
| Quote: |
Tips - PB blaster or something similar and lots!! (Bare minimum 2ft of extensions, I used probably 3) to get the passenger side cats bolts out. | Wait you got the cats to work with the o/r x?
07-03-2012, 10:40 AM
#17 | | The Blue Dragon
| Quote: |
Originally Posted by NicholasP
Wait you got the cats to work with the o/r x? | No, I'm just saying that you have to use lots of extensions to get to the cat bolts because it is easiest to get to them from top of motor, it's just a long way down
07-03-2012, 11:19 AM
#18 | | Registered User
| Quote: |
Thank ya.... Anything helps I will be doing this when I get back from vacation I am hoping it will sound good with the flow master super 10's I think it is going to be quite loud | That is the same set up I was going for which was an off road X pipe, maybe BBK and flow master 10's. Please make a video when all is done..thanks
07-03-2012, 10:46 PM
#19 | | Registered User
| Quote: |
Originally Posted by DarkHorse_5.0
That is the same set up I was going for which was an off road X pipe, maybe BBK and flow master 10's. Please make a video when all is done..thanks | Can do it will probably be fri night I am super excited about
2012 GT 5.0
6speed manual
BAMA sct tuner
07-04-2012, 11:15 PM
#20 | | Registered User
So my x pipe will be here tomorrow....would it hurt it to run it for a day with out a tune? Or should I just wait? I won't have the time to install everything on fri so I may have to wait
2012 GT 5.0
6speed manual
BAMA sct tuner
07-05-2012, 04:10 AM
#21 | | Registered User
Originally Posted by medicespo So my x pipe will be here tomorrow....would it hurt it to run it for a day with out a tune? Or should I just wait? I won't have the time to install everything on fri so I may have to wait | I just installed the O/R X-Pipe .Of course," you have to have a tune". You could drive it and just throw a code,but IMO it's not all that smart and I would personally not do that. I Had the tune for it and my other mods already in my SCT before I even went to the lift to do the job. Be sure to have some ZEP or PB.I would go ahead and hit the 4 nuts and the 02's now. Then when you get ready to do it,Spray some more on all the spots.If you are a man who has plenty of tools, like I fortunately do, since I am a Independent Mobile automotive tool man for a living,I would use 1/2" drive to get it off. 20'' extentions will be ok,but 24" is better.If not you can do it with 3/8 drive stuff. You for sure need swivel's (sockets) 15mm.You need a O2 sensor socket,but if you don't have one,you surely got a good wrench that will do it.Be careful with them.You don,t want to cross thread when you install in your new O/R X.Careful removing.I recommend Un-plug them then take them on out.
As for putting your new pipe on......I would use bolts that are 1-1/2".I would use a washer on each side and a lockwasher before throwing the nut on.Probably be using 14mm on these nuts and bolts,but just depends on where you buy them and what you pick.The install,once done, makes for a much easier access and can all be done from under neath the car.I like that because I will have to pull mine once a year but will not be bad.I went ahead and bought some new nuts..... OEM look a likes.
Good luck with install.Pm me if I can be of any help.If you ever need any tools or speciality tools look me up.I can beat Snap-on,Matco,Cornwell or Mac prices 99 times out of 100. Usually stuff made by the same company.And yes most evrything has a lifetime warranty.
Got to get my A** to work. Later!
__________________  2012 Black Prem. w/ GB insert stripe/stitch , M6 , Brembo , 3.73 , 19" AMR Staggered Drifts, Stock Air-Box Club, 93-R Tune, Borla Catback w/ X-Pipe, FRPP-"K" Springs, BMR PH Bar, BMR Upper support brace, BMR Reloc. Brackets,"CHE" Lca's, Koni's Struts/Shocks, Jlt cc, Saleen grill, Hydrocarbon Center console and stereo surround, Formula One Tint, Video w/ Cam tune on: YOUTUBE: 2012 gt back n a stang
07-06-2012, 02:07 PM
#22 | | Registered User
O/R x pipe is on there with my flow master super 10's....I can't stop smiling everytime I start her up...exhaust clip tomorrow!!!!
2012 GT 5.0
6speed manual
BAMA sct tuner
