Plasti-Dip Heat Extractors 2013 - Mustang Evolution
Old 06-27-2012, 07:18 PM   #1
BlueDemon's Avatar
Region: New Mexico
here ya go guys as promised
1. remove the hood heat shield tabs to access the heat extractors
2. remove the nut that holds the heat extractors in place. (only one nut holds it in place)
3. squeeze the tabs as you push the heat extractors through the hood. (towards the sky)
4. clean and spray
5. reverse engineer the process.
only advise is clean your heat extractors after you remove them with dish soap to remove all oil/wax/grease ect. let dry and get the edges good with the plasti-dip. also let the stuff dry a little before applying the different coats. One can will do both extractors. I run it through the car wash and no problems.
pry bar was bought at Harbor Freight for like 5 bucks the set of 5.
ID:	56744   Click image for larger version
ID:	56746   Click image for larger version
ID:	56748   Click image for larger version
ID:	56750   Click image for larger version
ID:	56752   Click image for larger version
2013 5.0, 6 speed manual, Brembo Pckg, 3.73 gears, American Thunder 40 series Flowmasters, 1 inch Lowering springs from Roush, J&M LCA, J&M Adj.Panhard bar, 20% Tint all around.
BlueDemon is offline   Reply With Quote
Old 06-28-2012, 09:07 AM   #2
NAVYGUY's Avatar
Re: Plasti-Dip Heat Extractors 2013
Thank you. Simple enough!
2010 GT Prem 400A Kona Blue
Manual, TrackPack, Electronics, Comfort, 3.73 & Security Packages, HID's
Mods: Flowmasters, GT/CS Rear Spoiler, Steeda Underdrive Pulleys, JLT Oil Separator, MMD Hood struts, ... more parts on their way
NAVYGUY is offline   Reply With Quote
Old 06-29-2012, 09:36 PM   #3
lilredgt's Avatar
Thank you! I think even I can do that! I can't wait to see how mine look when i'm finished.
lilredgt is offline   Reply With Quote
10:22 PM
