Dyno results!!! - Mustang Evolution
Old 06-30-2012, 12:45 PM   #1
Struego's Avatar
Dyno results!!!
What u guys think? Wms intake with flow master hush power cat back, 4.10 gear and stock tune. Also it's a 95 degree day.
Untill I get sct to resolve my tuner issues, the next runs will hopefully be with the bama tunes.
Struego is offline   Reply With Quote
Old 06-30-2012, 12:55 PM   #2
You have a 5.0 correct? They look like stock numbers. The 4.10's are eating a few ponies on the dyno..
---------- Post added at 01:55 PM ---------- Previous post was at 01:54 PM ----------
And I don't think the intake is doing anything for you.
Old 06-30-2012, 01:26 PM   #3
Struego's Avatar
Yes, it's a 5.0 with 33k miles
---------- Post added at 02:26 PM ---------- Previous post was at 02:17 PM ----------
I'm a bit skeptical on my intake, but untill I get my tuner fixed and load the bama tune, I'm not condemning it yet.
Old 07-01-2012, 01:18 PM   #4
So its a no tune intake?
Old 07-01-2012, 07:22 PM   #5
Struego's Avatar
Not sure what your asking, but the intake I have has a 100 mm maf tube and requires a tune. I ran the car on the dyno with the intake and cat back on a stock tune. Untill I get the sct tuner up and working again, I won't know if I gain any power on the dyno. I know the 4.10 drops the results by about 20 hp, and the 95 degree day was no help. This will be a good way to test how the car does with bolts vs bolt ons and with a tune.
Old 07-01-2012, 07:54 PM   #6
Edens5's Avatar
Correct me if im wrong.. Ur driving with a tune required cai without a tune for the cai?
Edens5 is offline   Reply With Quote
Old 07-01-2012, 08:22 PM   #7
It actually shows the cold air did nothing for you. The gears will not eat 20hp. Maybe 5-7. And heat isn't a factor with sea numbers as they correct for the heat.
---------- Post added at 09:22 PM ---------- Previous post was at 09:21 PM ----------
Ya wondering how that is working. Just shows the cai don't need a tune and as many others it was a waste of money. Showed no gains.
Old 07-01-2012, 08:57 PM   #8
Struego's Avatar
20 hp difference between a 4.10 and 3.55 is about right. Heat plays a big factor and especially when it's almost a 100 degrees.
Old 07-01-2012, 09:04 PM   #9
Edens5's Avatar
Not much diff between 50 and 100 degree weather though. The only thing tht helps is wen its cold out.. N tht is very minor.
Old 07-01-2012, 09:06 PM   #10
Struego's Avatar
Well not really driving the car, I just ran 4 passes on the dyno to get a baseline. Hoping by next week I'll get a tune loaded into the car and we will see if a tune helps. IMO I won't see much difference. The a/f's were around 13.0-1. Seems to me like the factory copperhead ecu is doing its own tuning and correcting regardless. That would be disappointing if the tunes for bolt ons showed no gains.
Old 07-01-2012, 09:09 PM   #11
Edens5's Avatar
Ull see gains with a tune. If u only have a cai n axlebacks dont expect to be blown away.
Old 07-01-2012, 09:11 PM   #12
Of course a tune is going to give you more power and torque. Why do you think a tune won't show gains? And if your looking for a comparison for the intake then you need to run on the dyno with a tune and then on the same dyno same day run with the intake and tune. Comparing a tune required cai with the stock tune and then to a tune is pointless.
2011gt85 is offline   Reply With Quote
Old 07-01-2012, 09:13 PM   #13
Edens5's Avatar
Looking for gains with a new cai is pointless in general.
Old 07-01-2012, 09:13 PM   #14
That is a very lean a/f ratio. Not good really. And there power to.be gained with adding timing.
And as said the heat don't really do much since the dyno corrects for it.
Why trying to compare the 4.10's to 3.55's. 3.73 stock.cars have made 370-385 bone stock.
Old 07-01-2012, 09:15 PM   #15
Struego's Avatar
Cai and cat back. I'm not expecting any gains at all actually. Unless bama changes the target air fuel ratios, and even with that, i can't see more then 5-10 horse power gains. The dyno will tell us hopefully next weekend.
Old 07-01-2012, 09:19 PM   #16
The gains are not going to.come from a/f. They are going to.come from adding timing in the tune. Your car is not at Max timing.
When do dyno do a new before tune and after tune install.
---------- Post added at 10:19 PM ---------- Previous post was at 10:19 PM ----------
Also where you have it dyno at?
Old 07-01-2012, 10:58 PM   #17
Oh really? I gained 8rwhp with my airaid cai and steeda tune over just steeda tune. Same dyno same day. So the 8rwhp(13+hp) awesome sound and awesome looks it was a awesome $300 spent!
---------- Post added at 10:58 PM ---------- Previous post was at 10:56 PM ----------
Don't bother with another dyno. Unless you do it with just tune and then just tune and cai on the same day same dyno the test is pointless. I don't understand why people don't get that?
Old 07-01-2012, 11:03 PM   #18
Edens5's Avatar
8 hp off a cai? Id call airaid and send it back for them to do research on y yours shows 4 more hp than everyone elses haha
Old 07-02-2012, 01:14 PM   #19
8hp is doing nothing on a car. You don't even notice it at all. On the street or track. But hey the sound is cool I guess. Useless sound.
Old 07-02-2012, 02:55 PM   #20
8rwhp is actually like 13+hp
Old 07-02-2012, 03:08 PM   #21
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Re: Dyno results!!!
Attachment 57054
Struego,
377 RWHP is very impressive for a basically stock 5.0, especially when it's damn near 100* outside. An intake with no tune does very little regardless if its tune required or not (8-10hp).
Once you get your tuner up & running again & install the Bama tune you will see a huge gain, you will see more like a 25+ RWHP gain. If you have further questions on tuning, Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 10AM-3PM EST. You can hit them up directly at 888.226.9764 and they'll get you squared away!
Check this out!
DYNO PROVEN #'s!
- Dan
10:29 PM
