Panhard Bar Issues - Mustang Evolution
Old 07-02-2012, 05:06 PM   #1
CoyoteAce's Avatar
Panhard Bar Issues
I installed some lowering spring this pass weekend along with the j&m adjustable panhard bar on my 2013 mustang gt. I have adjusted the panhard as much as I can but my rear drivers side is still sticking out an half an inch more than my passangers, im assuming im not doing something right, because i know i should be able to adjust it to where its even, any suggestion. This is the panhard bar i got: J&M Mustang Adjustable Panhard Rod (05-13 All) 23795B
CoyoteAce is offline   Reply With Quote
Old 07-02-2012, 05:56 PM   #2
How are you doing the adjustment? Have car jacked up adjusting and then sitting it back down to check it?
Old 07-02-2012, 05:58 PM   #3
DWC_SmOziLLa's Avatar
This is the panhard bar im looking to get. AM has it onsale this month for $99
Old 07-02-2012, 06:31 PM   #4
CoyoteAce's Avatar
Re: Panhard Bar Issues
My friend works at an alignment shop so i put it on the life by the axles and adjusted it, it did move but it wouldn't adjust any further and the wheels are still off.
Old 07-02-2012, 06:37 PM   #5
5pointOh's Avatar
I have the same panhard bar and I don't have any issues. First I adjusted it to the same length as the OE panhard bar. I then made adjustments with the car on the ground. Make sure you have the locking nuts on each side of the adjustable nut loosened so you can make the adjustments. GL!
2012 kona blue gt, GT500 exhaust, tinted windows, J&M Panhard bar, Steeda Ultralites, Koni STR shocks and struts, GT500 strut mounts, SR Performance shifter, Steeda Shifter Bracket, 20" Giovanna Monzas..damn I need more money!!
5pointOh is offline   Reply With Quote
Old 07-02-2012, 06:42 PM   #6
CoyoteAce's Avatar
So you didnt jack your car up, by the axles? i will try again tomorrow. Thanks
Old 07-02-2012, 06:48 PM   #7
5pointOh's Avatar
Nope, you don't have to. Matter of fact, the instructions that came with the bar said you didn't have to jack it up if I remember correctly. Either way you don't have to..give it a try and keep me posted.
Old 07-02-2012, 07:34 PM   #8
I didn't Jack mine up by axle
.I jacked up on sides. Let hang free. Then adjusted. Then jacked axle up to put tension to check it. Was done in 20 min.
Old 07-02-2012, 08:19 PM   #9
Gibby's Avatar
I adjusted mine with the car on the wheels, worked just fine.
Gibby is offline   Reply With Quote
Old 07-02-2012, 09:06 PM   #10
CoyoteAce's Avatar
Thanks for the suggestions I´m going to check it out, and ill keep ya posted.
06:36 AM
