Different Tire Size and Traction Control/ ABS Issues - Mustang Evolution
Old 07-03-2012, 05:48 PM   #1
Hey everyone how is it going. I am having a problem with my 2011 Mustang GT ABS/ Traction Control System.
I recently upgraded my rear tires to 305/40 R18 these tires are about 3/4" taller then my front tires which are 255/40 R19
According to a tire size calculator online it says that my new tire is 2.2% slower then my original tire.
Now when i'm on the track my car is breaking randomly on its on. Even if i turn off traction control my car starts breaking on its own.
Last track event i had to unplug the ABS fuses to run the road course.
does anyone have any idea of whats going on?
Some people suggested my replacing the front tires so they are identical in height to the back.
will this fix my problem?
Thanks any help would be great.
TimeMachine is offline   Reply With Quote
Old 07-03-2012, 07:27 PM   #2
DWC_SmOziLLa's Avatar
Get it tuned. You can calibrate it for different tire sizes.
Old 07-03-2012, 07:28 PM   #3
Re: Different Tire Size and Traction Control/ ABS Issues
your system is reading the different wheel speed front to rear and thinks your in a skid and is reacting
Lugnut is offline   Reply With Quote
Old 07-03-2012, 07:28 PM   #4
The Darkside's Avatar
That's not good, I wanna go 315s, I guess that will be a problem
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 07-03-2012, 07:40 PM   #5
I've talked to a couple of people and they all recommend me to find tires that will make the same height. you can put the 315's but you have to change the front tires accordingly to match the size.
use this calculator to find the right tire. Tire size calculator
i will put 275/45/ R18 in the front now to fix the problem.
Old 07-03-2012, 09:25 PM   #6
The Blue Dragon
GrabberBlue5.0's Avatar
Do you have both TC AND SC completely off??
To do this you must have the brake pedal pressed down and hold the TC/SC button down for 6 seconds
New quick exhaust video
AUGUST 2012 MOTM!!!!
GrabberBlue5.0 is online now   Reply With Quote
Old 07-03-2012, 09:52 PM   #7
What's s/c?
Beelzebubba is offline   Reply With Quote
Old 07-03-2012, 09:55 PM   #8
That defeated the look I wanted. I want it staggered
i bleed Race fuel!
Old 07-03-2012, 11:00 PM   #9
back n a stang's Avatar
First I would not want 18 and 19 mixed no matter the matching of heights and what not.If it was me I would get with my turner if you want to test with current set-up,but after that I would be going to the same size wheel all around.You can get wider for the back so you can have the tires in the back.Staggerred looks good,but get the 18 or 19 all around man.JMO P.S. I like 19 and they are staggered but 18 is more practical for tire selection and price of tires.I am happy with 19'' staggered set-up for DD for the most part but I want some Weld or Race Stars for playing and tracking.I could just get the 15's for the back and run 265 or 275 M/T drag radial for some fun.I would like to have some 17's for the front and skinnies on them,but that is alot of wishful thinking right now.Slicks and a track about October would be great too.....LOL!
Old 07-04-2012, 06:55 AM   #10
The Blue Dragon
Originally Posted by Beelzebubba
What's s/c?
SC is stability control
Old 07-04-2012, 11:42 AM   #11
Shut advance trak off and you will be fine. Same thing happens on a dyno if not off.
Old 07-04-2012, 11:44 AM   #12
Merben50's Avatar
When you switched your tires did they use a new tpsm? or did they,tune the tpsm to your car for those tires? Tire pressure sensor monitor (tpsm) probaly wrote IT wrong.
Merben50 is offline   Reply With Quote
Old 07-04-2012, 11:52 AM   #13
Yea. so you are sure if i press the break pedal and hold down the TC SC it will dissable everything ?
Old 07-04-2012, 12:21 PM   #14
Yes. Hold brake pedal down while in gear. Then press hold TC button and, after about 7 seconds it so it will say advance trak off.
Old 07-04-2012, 12:44 PM   #15
Merben50's Avatar
I tjought it was hold break when cars on press tc twice or hold it .
Old 07-04-2012, 01:33 PM   #16
Hold it down. Pressing twice puts in sport mode. Which it will still be on.
Old 07-04-2012, 05:22 PM   #17
there is detailed instruction's in the owners manual on how to over ride the system on the 2013 proably other years to
Old 07-05-2012, 12:08 AM   #18
Angry Re: Different Tire Size and Traction Control/ ABS Issues
Hey everyone. I have done some research and i've found out more info about my problem.
I am going to the track this saturday so i will fully test what was the real problem.
However i have found this:
There are actually 4 modes:
Traction Control On & AdvanceTrac On: Default
Traction Control Off & AdvanceTrac On: Single Button Press
Traction Control On & AdvanceTrac On: Sport Mode Double Button Press with Brakes
Traction Control Off & AdvanceTrac Off: Button Press 5 sec with Brakes.
I already ordered new rims and tires to try and fix the problem. However i dont think i needed to get the extra rims and tires.
I think deactivating fully the traction control is what will fix my problem.
Too bad i found out now that i've spend close to 1000 more bucks on rims and tires...
Anyways. i guess i'll have use for these rims and tires sooner or later.
But i think the real problem is the AdvanceTrac. This features restricts throttle and applies breaks when the car is cornering and its slipping.
08:26 PM
