Wheels - Mustang Evolution
Old 07-06-2012, 01:16 AM   #1
RuSSiaNStuDD's Avatar
Wheels
I have 2012 5.0 and I want to get some new wheels for it. My only concern is the width. I want the rear once to be wide, at least 305. I saw an older mustang with 315s and it looked sick. So what's the widest I can go on my car. I want to get 19s but if I can't, I will settle for 18s...
RuSSiaNStuDD is offline   Reply With Quote
Old 07-06-2012, 01:26 AM   #2
Zaks06GT's Avatar
To run a 305 or 315 you well neem new rims, and it all depends how much you wanna spend, I have CCW 505A on my GTO and love them but they are not cheap, I run a 19x9 275/35/19 front and a 19x11 out back 335/35/19
Zaks06GT is offline   Reply With Quote
Old 07-06-2012, 04:02 AM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
19" tires are very expensive with a smaller selection. That said I have 19's and I love them. Many people on here are running 305's too do they should definitely fit, just make sure you have a good backspacing
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-06-2012, 07:16 AM   #4
Re: Wheels
if you want a 305-315 wide tire you will need to get a 10.5 -11 in rim (10.5 should work), if you go any smaller (a 10 wide rim a 295-305 is fine) or a 9 wide (265-285).
DONT buy tires that are to wide or to narrow.... that just defeats the purpose to begin with. I have 10 wide with 295's works great, fits great as well.
Just to make it MORE confusing than it already is.... EVERY tire manuf has a different "system" for determining how wide a tire ACTUALLY is. So.... some run more narrorw some are wider. You will have to research to find out depending on what brand you go with.
Old 07-06-2012, 12:57 PM   #5
Well, how wide can I go when it comes to width of the rim? Would it be ok to get 11inch without any rubbing. I just want to go as wide as I can without having any problems
Old 07-06-2012, 02:26 PM   #6
You can have a 305 tire on a 10 inch wide wheels.
2011gt85 is offline   Reply With Quote
Old 07-06-2012, 02:57 PM   #7
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Re: Wheels
RuSSiaNStuDD,
Great choice! I would agree that you need to get a big sticky tire under your stang!
I would recommend a 19x10 & strap a 305 Drag Radial do it, you should hook up great with that & wont have any fitment problems!
A 11in' wide wheel may be difficult to find, especially in a 19in rim. We have never test fit anything bigger then a 10in wide wheel on the 11+ because that is whats most common!
I hope this helps! Best of luck on your decision!
- Dan
Old 07-06-2012, 04:06 PM   #8
ccorlet's Avatar
Re: Wheels
I just got Mickey Thompson ET Street Radial II's P305/35R18 on Dale Earnhardt Jr Killer Wheels for the strip but not every day since they would only last as long as an oil change.
2012 Mustang GT
ccorlet is offline   Reply With Quote
04:37 AM
