Exhaust - Mustang Evolution
Old 07-08-2012, 09:14 PM   #1
Exhaust
Is there any way to make my exhaust tips sit further back into the rear diffuser? I feel like my tips extend pretty far out on my 2013. They are also not exactly centered and it's driving me crazy. Any info on how to correct would be helpful!
Mikeyt03 is offline   Reply With Quote
Old 07-08-2012, 10:52 PM   #2
Is it the stock exhaust? I know on my Borla catback I could move the tips forward or back a bit by loosening the clamps from the cats to x pipe and from the mufflers to the over axle pipes and moving them in or out, and the tips I had a friend hold the tips where I wanted them then I tightened the clamps back down. If you have the sock setup you could try to loosen the mufflers from the over axel pipes and try to move them In a little and wiggle the tips to where you want them and tighten re tighten them.
2011gt85 is offline   Reply With Quote
Old 07-09-2012, 05:23 AM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
As said above, loosen them from over axle pipes and adjust, I actually had to loosen my overaxle pipes from my xpipe too, so keep that in mind
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-09-2012, 02:04 PM   #4
CaptainBeyond's Avatar
I have pypes axlebacks. They kept going all crooked so i ended up putting small hose clamps on my exhaust hangers on either side the rubber to keep my mufflers from moving out again. Works good, the tips are still centered.
---------- Post added at 03:04 PM ---------- Previous post was at 03:03 PM ----------
Oh yes. Did have to loosen the clamps and re center the mufflers too
Life's a garden, dig it
CaptainBeyond is offline   Reply With Quote
exhaust
11:44 AM
