Brembo GT-R Brakes? - Mustang Evolution
Old 07-09-2012, 06:54 PM   #1
AGG
Brembo GT-R Brakes?
I have a 2013 mustang and what to equip it with some brembo brakes. I got into their website and found out about the GT-R braking system. Do you suggest I buy this braking system or do you recomend something else. ( I take my mustang to the track once in a while). Thanks
AGG is offline   Reply With Quote
Old 07-09-2012, 09:13 PM   #2
Yellow50's Avatar
Why?
Yellow50 is offline   Reply With Quote
Old 07-09-2012, 09:17 PM   #3
AGG
Why not
Old 07-09-2012, 09:19 PM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
What's the difference in the 2 kits?
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-10-2012, 05:02 AM   #5
Yellow50's Avatar
What are you trying to do by switching to brembo brakes. For appearance or braking power or lower lap times or what?
Old 07-10-2012, 05:22 AM   #6
Tyoung68's Avatar
Go wilwood
Old 07-10-2012, 10:13 AM   #7
AGG
I want them for beter lap times and better performance
Old 07-10-2012, 11:12 AM   #8
mustangman5345's Avatar
I've heard good things about the Shelby Baer ones but can't go wrong with the brembo system.
mustangman5345 is offline   Reply With Quote
Old 07-10-2012, 11:15 AM   #9
DaBluedude's Avatar
Brembo is way too expensive for what you get. Willwood or baer make great kits for much less. Also remeber you will likely need new rims and tires with most big brake kits...
2003 Mach 1
Old 07-10-2012, 11:38 AM   #10
Yellow50's Avatar
Brembo brakes are not going to make you faster on the track time. Just use that money for seat time. Coming out of a corner is way more important than braking for it.
Old 07-10-2012, 01:31 PM   #11
Region: Oregon
Re: Brembo GT-R Brakes?
I respectfully disagree ... if your brakes are starting to fade (and the stock brakes on our cars have repeatedly been called out in performance testing for fading quickly under hard driving), this WILL affect your lap times.
A car is a system, and that system includes both the accelerator AND the brakes -- both need to be functioning well and operated expertly to get the best times around any track.
12gtpdx is offline   Reply With Quote
Old 07-10-2012, 02:41 PM   #12
Yellow50's Avatar
A good set of track pads have done wonders for many.
Old 07-10-2012, 02:51 PM   #13
Region: Oregon
Excellent! Then we agree that improved braking (whether through pads or new brakes) benefits track times.
Old 07-11-2012, 02:25 PM   #14
DaBluedude's Avatar
The 2500$ you would spend on brakes would be better spent on suspension and tires. Once that is done, then sure go for brakes. Brembos are still overpriced.
2003 Mach 1
Old 07-11-2012, 03:11 PM   #15
Region: Oregon
Completely agree on the order of upgrades.
Old 07-11-2012, 11:24 PM   #16
I agree as well but you could always get some track pads and slotted rotors? That'll be a whole lot cheaper and may give you that extra braking you're looking for
Old 07-12-2012, 03:46 AM   #17
DaBluedude's Avatar
+1. I love my drilled and slotted rotors. They were cheap and the initial pad bite is nuts.
2003 Mach 1
11:27 AM
