Power Shifting vs Quick Shifting - Mustang Evolution
Old 07-11-2012, 09:09 PM   #1
BlueDemon's Avatar
Region: New Mexico
whats up guys/gals, quick question. I might be going out to the track this Sunday and was curious as to how much of a difference the shifting (power vs quick) really makes? I can shift pretty good (quick shift). I just don't want to screw up the clutch and tranny (power shift) ya know. Whats been your luck?
Any other advice is greatly appreciated.
Thanks in advance
2013 5.0, 6 speed manual, Brembo Pckg, 3.73 gears, American Thunder 40 series Flowmasters, 1 inch Lowering springs from Roush, J&M LCA, J&M Adj.Panhard bar, 20% Tint all around.
BlueDemon is offline   Reply With Quote
Old 07-11-2012, 09:17 PM   #2
Re: Power Shifting vs Quick Shifting
I wouldn't recommend power shifting unless you are completely comfortable with it, it's alot of abuse if you miss...
Old 07-11-2012, 09:39 PM   #3
Rynarok's Avatar
Depends on the application. If you are doing a track run, a good powershift can really rocket you out of a corner provided you can maintain enough traction to keep control.
A quickshift is more of an acceleration technique where you are already very high in the powerband and want to shift fast enough to not lose too many rpms between gears.
tl:dr Strip - probably quickshift. Track - depends on application.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 07-11-2012, 10:26 PM   #4
GE3G's Avatar
Stock with quick shifting.... It aint worth power shifting... Consequences are really high and it you wont shave off a whole lotta time
GE3G is offline   Reply With Quote
Old 07-11-2012, 10:46 PM   #5
Stockish302's Avatar
Thanks in advance
From what I know a Quick Shift is just shifting fast while still releasing the gas, and a Power Shift is just shift with no lift as fast as you can many only do it from 1-2 and from 3-4 if they are not very confident with doing the 2-3 shift. But I would only do it if your 100% confident in your shifting skills, I only powershifted on my turbo 2v to avoid lag with the turbo I had and even then tried to avoid the 2-3 shift if I could.
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 07-12-2012, 09:12 AM   #6
SilverBullet12's Avatar
I power shift my car when i race on drag radials, not on the road though cause it breaks loose.
I always powershift 1st to 2nd and 3rd to 4th racing. I RARELY find third powershifting. My best 1/4 time reg shifting was a 12.32 and best power shifting was 12.18. Only do it once your really comfortable with the car and i wouldnt do it on the street at all unless its 3rd to 4th, hearing a chirp between those gears makes me smile haha. My trans hasnt had any problems, just the shifter itself is a little loose from abuse it took. Nothing a short throw wont fix.
Good lUck!
SilverBullet12 is offline   Reply With Quote
Old 07-12-2012, 07:48 PM   #7
BlueDemon's Avatar
Region: New Mexico
Thanks for the advise guys I think Ill quick shift it to be safe.
Old 06-01-2016, 12:08 PM   #8
Power shifting
I used to do it with my 4 4 2 (tri-power) Muncie 4spd and Hurst Competition Plus shifter. I would never do it with my 2015 Mustang GT though.
reflections is offline   Reply With Quote
Old 06-02-2016, 09:09 AM   #9
noldevin's Avatar
Powershifting is how you become one of those "MT82's suck!" threads.
noldevin is offline   Reply With Quote
Old 06-02-2016, 09:11 AM   #10
I could do 11s on my fully loaded MT82 2012 with just quick shifting.....
2014 Premium GT, SGM, Brembo, Auto, Tech, Comfort, etc. GT500s, Steeda UCA, VMP auto N/A tune. 100 shot nitrous on BBR tune. Best e/t 11.42 at 120.64
Old 06-02-2016, 10:50 AM   #11
I power shift 1-2 and 3-4, but I wouldn't try it on a stock shifter without an upgraded bracket and trans mount. It does make a huge difference if you can nail it right.
2012 Kona Blue GT 6M 11.80 @ 116
Koni STR.t shocks/struts, Steeda springs, BMR LCA, and Panhard bar, BBK off road X-pipe, Pypes axleback, whiteline shifter/trans bushings, Bama 93r tune, JLT CAI, Barton shifter, Shaftmasters 1 piece DS, CHE axle brace, factory HID conversion, and track pack Brembo and Recaro swap
Dave M is offline   Reply With Quote
02:34 PM
