Drivetrain Clunk - Mustang Evolution
Old 07-15-2012, 09:09 AM   #1
Drivetrain Clunk
This noise I hear when braking or lifting off the accelerator is driving me nuts.
What can I do the eliminate it or at least minimize it? Suspension is now stock.
Any suggestions appreciated.
Thanks.
2012 GT Coupe Premium 6 speed MT with 3.73 option, black on black
pcarman is offline   Reply With Quote
Old 07-15-2012, 09:19 AM   #2
wereKEV's Avatar
Re: Drivetrain Clunk
It could be the u joints .
wereKEV is offline   Reply With Quote
Old 07-15-2012, 09:37 AM   #3
U-joints are where? Driveshaft?
Old 07-15-2012, 09:53 AM   #4
it won't be, unless you have a TON of miles. it's the 2-piece driveshaft. You can sometimes drive around this by revving the motor a little higher before shifting. Complain to Ford and they may give you another DS that's got tighter tolerances or go with a 1 piece DS from any number of vendors like DSS, Shaftmasters, etc.
Old 07-15-2012, 10:08 AM   #5
It's not me, it's you.
primer2tone's Avatar
Mine does this too. It has ever since day one. It feels like the play between the weight of the car in the nutural state, meaning no power to the wheels in between gears with the clutch in or between gears in an auto or leaving park. I don't think a one piece driveshaft will remedy this because I think it's just the way the car is built. It sounds like the noise is coming from the transmission itself and not the driveshaft U joints. I may be wrong for I am not a mechanic, just a random Internet guy expressing my opinion. My F150 does the same thing and I haven't had any mechanical issues due to this.
Old 07-15-2012, 10:16 AM   #6
Usually when the 2-piece driveshaft (variations on this theme have been used in Mustangs since the Foxbody first came out) isn't responsible, it's slop in the rear end tolerances, which isn't easily curable without a new gearset with less tolerance stackup. Huge range of acceptable (meaning, no noise) levels of rear end slop in 8.8s.
Old 07-22-2012, 08:19 PM   #7
Blogger
99ford's Avatar
My Mustang does that and my Moms Lincoln Aviator does as well.
12:29 PM
