Barton 2 Post Bracket vs Standard Barton Bracket - Mustang Evolution
Old 07-17-2012, 07:41 AM   #1
SilverBullet12's Avatar
Is there an advantage to paying a little extra for the new style bracket?
[IMG][/IMG]
Thats the new bracket thats $110 and the older style s $74.99.
Anyone try the new bracket?
SilverBullet12 is offline   Reply With Quote
Old 08-15-2012, 06:14 PM   #2
gtstyles2's Avatar
I have no idea but I went to the AM show and saw it in person at the Barton stand... they said it was much better so I have one on order. Its on back order so who knows when I'll get it
Old 08-15-2012, 09:06 PM   #3
Re: Barton 2 Post Bracket vs Standard Barton Bracket
It's still just a big-*** rigid bracket. Not sure how it's "better" unless they are referring to the install. Install of the old one was a bit tricky ... probably easy with a lift, but to a lowered car on ramps it was a little frustrating just trying to get both my hands in there around the drive shaft.
mmike87 is offline   Reply With Quote
Old 08-19-2012, 03:18 PM   #4
gtstyles2's Avatar
So nobody here installed or used the two post bracket?
Old 08-19-2012, 04:08 PM   #5
silvrbullet2012's Avatar
I have the older one but was wondering if the new one came out is any better also. This would be good info.
silvrbullet2012 is offline   Reply With Quote
Old 08-21-2012, 10:32 AM   #6
Konawin's Avatar
I have the Barton bracket with stock shifter and original trans fluid. I still have notchiness when cold... I'm going to a synthetic fluid next...
Konawin is offline   Reply With Quote
Old 08-21-2012, 02:13 PM   #7
gtstyles2's Avatar
How many miles do u have?
Old 08-22-2012, 05:59 AM   #8
I think the stock fluid is already synthetic ... however Ford has put two different weight fluids in the transmission, eventually moving to a lighter weight fluid, I believe.
I have the Barton shifter as well as Barton Bracket 1.0 and I personally like the heavy duty, notchy, mechanical feel of the shifts. The instructions that came with the shifter indicate that is how it's supposed to feel. Comes down to preference, I guess.
Old 08-23-2012, 09:43 AM   #9
Konawin's Avatar
I'm at about 10,500 miles. I don't mind some notchiness heck, I had a 1980 Porsche 911SC that had to be double-clutched in gears 1-3 most of the time. It's the hesitancy to engage gears 2 and 3 that are disconcerting.
05:44 PM
