Oil Life - Mustang Evolution
Old 07-18-2012, 11:46 PM   #1
mustangman5345's Avatar
Oil Life
So my car gave me the warning today that my oil only has 5% of its life left. But, since I put synthetic in it shouldn't last a little longer? So I guess the real question is, is the car programmed to assume that you're using regular oil and it just has the oil life sensor on a timer? Or does it actually measure the consistency of the oil?
mustangman5345 is offline   Reply With Quote
Old 07-19-2012, 01:23 AM   #2
11stangGT's Avatar
Region: Arkansas
I know that it's not a set amount of miles or anything like that.. My car had 40% left w 9k on it and a friend of mine who's younger and always hard on the car and had 4% I think it was w around 5k..
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 07-19-2012, 02:20 AM   #3
Edens5's Avatar
I change it every 3500 no matter what some sensor says.
Edens5 is offline   Reply With Quote
Old 07-19-2012, 07:08 AM   #4
So just trust it and do what it tells me? Haha what do you out in yours?
Old 07-19-2012, 07:28 AM   #5
audioAl's Avatar
Re: Oil Life
I use Castrol Edge 5w 30w in my V6, my Villager 3.0 I use Royal Purple 5w 30w. Syntec
oils last 5000 miles.
2014 DIB 3.7 "Blue Cyclone" on 275/40/18 RE 760 Sports/Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/J&M Bushings/ BMR cradle lockout/BMR CB006 brace/BMR cc bolts/S-04 pole position'
Old 07-19-2012, 08:44 AM   #6
Re: Oil Life
for my 2012 there is no setting for how many miles you want it to go, yours may have it as my wife's 2011 Edge has a setting (3,5,10k) you set that and it uses that to tell you when.
I know for the V6 the interval is 10k miles under normal conditions for the new 3.7L. Synch does last longer, but ford puts basically a semi synth in it from the factory.
Old 07-19-2012, 08:56 AM   #7
gweze001's Avatar
One of my relatives runs the service department at a major ford dealer and they recommend changing the oil every 5000 if you are using the motorcraft synthetic oils.
2010 GT, Airaid CAI with BAMA 87 Performance Tune, and Flowmaster Outlaws
gweze001 is offline   Reply With Quote
Old 07-19-2012, 09:28 AM   #8
Gotcha, well then I should have another 1000 or so for it. I guess I just need to change the settings. But for next change, get Castrol synthetic?
Old 07-20-2012, 11:23 PM   #9
guzie's Avatar
There are no settings for oil mileage. The computer determines oil life values based on driver use.
guzie is offline   Reply With Quote
Old 07-21-2012, 06:42 AM   #10
back n a stang's Avatar
Re: Oil Life
Oh boy....Oil thread! LOL!! No,if you are 5.0 and you drive it occassionally hard at redline or close redline shifts I would for sure not go over 5000.I personally recommend Mobil1 syn.! Can't say much for the 13 but if it's a 11-12 gt keep a close eye on your oil level the first 10,000.(Ring Flutter Break in)Be on very level ground when checking.Also know matter what 5.0 I highly recommend a JLT catch can.For sure the passenger side.Very few use on driver side.I don't.
05:11 PM
