Hey everyone. I would like to replace my Rotors especially the front ones. Can anyone tell me what are the best? I have standard brakes on my 5,0 but I drive at very high speeds plus I added some parts like 302 intake 4.10 gears and so on. I'm currently in Germany and therefore go over 170 if traffic allows it (hunting porsche ;-) ). Does anyone have any ideas on what to buy if i don't want to upgrade to brembo?
Thanks
Do you mean 170 km/h? Unless you're driving like you are on a road course, I think the stock brakes are ok. I don't know what aftermarket brakes would be good for you, but you may want to consider brake cooling ducts. Just FYI, those mods have nothing to do with braking performance and I hope you're not slamming on your brakes at those speeds...you'll fry your pads in no time.
I think that's the point of the question. Upgraded pads would be the first thing to look at. I'm not an expert on what's out there for Mustangs (yet), but I'm sure someone here will have good suggestions. If I were looking right now I'd start with Hawk, EBC, Porterfield.
^All very good info, but start with the fluid. If you havent upgraded to DOT4, at those speeds, do so immediately. I boiled the stock DOT3 with, what I consider, light use.
You're mistaken. **** happens, even on the autobahn and you need to be able to slow down fast and straight. The stock brakes are in no way ok for this duty. Fine for NA, where we potter around generally and make one stop at a time, totally inadequate for use at sustained higher speeds.
I'd suggest the poster at the very least get upgraded pads like Hawks, braided lines will make the pedal feel better, upgrade the brake fluid, the Boss cooling ducts are a good idea and consider saving up for a major brake upgrade. The BBP on this car is, in my opinion, the minimum standard for the requirements of the situation you have.
Consider also, ditching the stock ASR tires for something dedicated for high speed/high performance, like a Michelin Pilot Sport or Continental Sport Contact. That's a big improvement in braking performance right there.
I agree with what you're saying...my comment on driving like he is on a road course relates to this. Road course = quick braking at high speeds. Otherwise, I agree with your suggestions. I was looking at it as a quick high speed run to 100 or so mph (assuming he is stating 170 km/h), followed by gradual braking. But I guess I misinterpreted the implications of the question. Sustained high speed driving and braking would require upgraded brakes, lines, fluid, and pads, among other things. Didn't mean to spread misinformation...thanks for providing more info to the OP.
Try BAER Decelarotors and Decelapads, I like to drive back roads on the spirited side (lol) and I've never had a problem with them and I love em. The rotors are cross-drilled and slotted, never had any brake fade issues
---------- Post added at 04:24 PM ---------- Previous post was at 04:24 PM ----------
Op. I would recomend much of what has been said here. Dot 4 or better fluid. Braided lines for sure. More agressive pads and a set of high quality drilled rotors is a good start. Baer makes a.great big brake kit for your car which I seriously recomend if you're going to be doing high speeds like this. The stockers are good for 70-0 but not so much from higher speeds than that. The brembo brake kit would even be a good investment for you.
Hey guys thanks for all the replies. I'm actually talking 170 mph plus (275 kmh) but of course not all the time. But I really want to see what the top speed of my pony is. I guess 210 mph should be possible. The brake fluid has been changed. I used racing standard. I looked online at those ebc rotors. They look great but what good is that if I can't stop.
---------- Post added at 07:40 PM ---------- Previous post was at 07:31 PM ----------
Ps: changing the tiers was the first thing i did. Currently I'm running on 255 in front and 275's (Dunlop Gt sport max) in the back. Very good tiers by the way. They stick like glue when you warm them up properly.
Well I didn't do anything on the bodywork but sure added some he's. According to the last dino 511 hp and 620 nm. Your right ford is limiting the cars but if you run any tune that's automaticly removed. As far as the speed reading goes there are two ways. First GPS and secondly the spedo test mode where you can show you speed digital where normaly your milige stands. But GPS is much more accurate. But I guess we slip of the subject. Has anyone tried the upgrade of the standard Rotors (12,5 I believe) to 14in Rotors?
well, that's what the BBP rotors are so, yeah, they work pretty good, for stock stuff. I'd say, they've saved the car a time or two since I've owned it.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
