Throttle body question? - Mustang Evolution
Old 07-24-2012, 01:30 PM   #1
bluemonster13's Avatar
Was thinking about getting a aftermarket tb. Is there any benefits to it? I read different things. Any advice would be great.
2013 Mustang GT Premium
brembo package
heat extractor hood
3.55 Gears
Borla "s" type catback exhaust
20% tint alll around.
bluemonster13 is offline   Reply With Quote
Old 07-24-2012, 01:34 PM   #2
Jake's Avatar
Im also wondering this, ive seen people say that it didnt make a difference at all!!
Jake is offline   Reply With Quote
Old 07-24-2012, 01:36 PM   #3
Yea I've seen that just no sure if its true.
brembo package
heat extractor hood
3.55 Gears
Old 07-24-2012, 01:56 PM   #4
Re: Throttle body question?
pretty confident that without a tune and increased airflow demands from the engine, you won't see jack in terms of increases.
Old 07-24-2012, 01:58 PM   #5
So a CAI + tune + throttle body= more hp??
brembo package
heat extractor hood
3.55 Gears
Old 07-24-2012, 01:58 PM   #6
slow281
sixpac's Avatar
Region: Nebraska
If you have a cai it will help that out a little bit noticeable? Probably not.. Basically just a bigger hole to flow threw
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-24-2012, 01:59 PM   #7
Ok thanks!
brembo package
heat extractor hood
3.55 Gears
Old 07-24-2012, 03:04 PM   #8
it's the engine that determines its airflow demands, not the CAI or the throttle body. You can do some of increasing this demand with a tune, or good old fashioned hot rodding like headers and exhaust. Bottom line, no increase in demand for air = 0 gain from any airflow part. This isn't a '90s Honda here, sucking life through a Macdonald's straw.
I don't think you'll see much gain on the TB as there's no way in hell a tune is going to increase the demand for air byond the stock TB's ability to flow. People run supercharged engines with the stock Tb all the time.
Tune is where most of the gain is in a Tune and CAI combo, like 90%+
Old 07-24-2012, 04:07 PM   #9
tgmeyer's Avatar
You'd probably seen some gain along with a tune and CAI, but probably more than anything you'd see a bump in your MPG. Not significant, but some. Increase MPG: Get air in and get it out!
tgmeyer is offline   Reply With Quote
Old 07-24-2012, 04:52 PM   #10
It's just not as simple as "air in, air out". When it comes to changing the TB, chances are just as good you'd see a drop in mpg from that, as you'd have reduced velocity at the throttle plate and you'd end up opening the throttle more to overcome it. Tunes, though, increasing mpg, yeah, I'd say that's highly likely and is reflected in alot of people's experience, including mine.
All this simple stuff around "engines are just air pumps" is a way of explaining a very complex fluid dynamics and physics problem for dummies. It isn't that simple and requires a great deal more insight to ensure improvements are made. This is the stuff Ford engineers sweat bullets over and spend millions of dollars and years testing before deciding on a final product spec. There might be a chance, if you're say, a descendent of Smokey Yunick, that you might make an item that improves on something they've done, especially since you don't operate with the same cost/emissions compliance/regulatory framework that they do but, better do your research and see what the consensus of opinion is in places like this.
I'll give you mine: leave the throttle body alone. Buy a good quality aftermarket tune with a CAI, (if you insist on an aftermarket CAI) and see how you feel.
Old 07-24-2012, 05:22 PM   #11
Thanks everyone! I was just curious. I'll just leave the tb alone. I already have borla s type catback. I just gonna look for a good quality CAI and tune now.
brembo package
heat extractor hood
3.55 Gears
Old 07-24-2012, 05:22 PM   #12
DWC_SmOziLLa's Avatar
Aftermarket throttle Bodies are a waste if money. The opening on the front of the intake manifold is only 80mm. The same size as the factory TB. Increasing the size of the TB totalling negates itself as soon as the air hits the change in size, it can also cause uneeded turbulence. Not to mention that the intake ports going from the heads to the IM are currently port matched and not changing in size. In a perfect world IM woul be 90mm and buying a 90mm TB to match could yeild 1-2% hp gains in NA form. This could benefit you more if you had FI. Use your money in other areas.
Old 07-24-2012, 05:25 PM   #13
I am thanks! I'm investing in a CAI and tune. Already have a catback exhaust.
brembo package
heat extractor hood
3.55 Gears
Old 07-24-2012, 08:03 PM   #14
The Blue Dragon
GrabberBlue5.0's Avatar
tune will change exhaust note... in a good way!
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 07-24-2012, 08:06 PM   #15
I have a 13' GT with borla s type catback. What do you recommend?
brembo package
heat extractor hood
3.55 Gears
Old 07-24-2012, 09:21 PM   #16
The Blue Dragon
I didn't mean that specific tuners will make an exhaust sound different, just that a tune in general will make it sound more aggressive. If you want tuner recommendations however I will give you that.
Lund/lethal, vmp are the top 2. Also most expensive and sometimes hard to get a hold of due to such high volume of customers. Lund is actually expanding right now to keep up with demand.
Evolution is another good tuner and if you want top notch customer service, AM is great, not the most powerful of tunes but very safe, and a larger operation in general so they will be easier to deal with as far as not having to wait as much. Also cannot forget Steeda.
Really just now starting to learn about C&L but from what I have heard the guy that owns and operates C&L actually started the bamachips program before selling it off to AM/bama and I hear he is also a phenomenal tuner. From the things I have read from him he has really done his R&D and knows the coyotes very well
If I'm forgetting any noteworthy tuners please chime in
---------- Post added at 11:21 PM ---------- Previous post was at 11:17 PM ----------
Just Reread the info about C&L, Doug was former owner of bamachips, he is just the tuner of C&L, just wanted to clear that up. Still great at tuning though
Old 07-24-2012, 09:25 PM   #17
Thanks for the info grabber. Greatly appreciated!
brembo package
heat extractor hood
3.55 Gears
Old 07-25-2012, 12:15 AM   #18
Edens5's Avatar
Save ur money for a SC. Do ur cosmetic mods n drop a SC on it.
Edens5 is offline   Reply With Quote
Old 07-25-2012, 12:24 AM   #19
Steeda and aed are IMO the best tunes out there. Sure maybe Lund is the most aggressive but also he has had engine failures running his tunes. Steeda has a relationship with ford directly and Shawn at aed had you datalog your car before and after your tune so he can write your tune directly for your car so it's not just a tune made for every car.
2011gt85 is offline   Reply With Quote
Old 07-25-2012, 10:03 AM   #20
Cool thanks!
brembo package
heat extractor hood
3.55 Gears
Old 07-25-2012, 10:19 AM   #21
claudermilk's Avatar
I have been wondering about that while researching options for my car. It seemed odd that the FRPP TB comes with that adapter to bring the opening back to 80mm--my thought was "ok, so what's the point?"
Seems like these are only worthwhile for those with more radical mods using FI.
Thanks for the information on this, and on the tuners. I'm also looking at what the landscape on them is (total newbie to the Mustang world).
claudermilk is offline   Reply With Quote
Old 07-25-2012, 11:09 AM   #22
Glad i could help
Old 08-01-2012, 08:33 PM   #23
coyote414's Avatar
Any explanations for the dyno graphs showing 20hp and 20 ft lb gains under the curve? I'm not saying its likely to get those gains, but how they were accomplished
coyote414 is offline   Reply With Quote
08:32 AM
